9964 009500
9964 009500
    BELDEN
    CBL 4COND 20AWG SHLD
9964 009500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9964 Multi-Conductor - Communication and Instrumentation Cable For more Information please call 1-800-Belden1 Description: 20 AWG stranded (19x32) tinned copper conductors, conductors cabled, nylon skin over insulation, PVC insulation, tinned copper braid shield (90% shield coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 20 19x32 TC - Tinned Copper Insulation Insulation Material: Layer # Insulation Material Wall Thickness (mm) 1 PVC - Polyvinyl Chloride 0.2794 2 Nylon 0.1016 Insulation Resistance: 700 megohms/1000 ft. @ 500 VDC Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 90 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.635 Overall Cabling Overall Cabling Lay Length & Direction: Length (mm) Twists (m.) 50.7998 1.8288 Overall Cabling Color Code Chart: Number Color 1 White 2 Black 3 Red 4 Green Overall Nominal Diameter: 5.740 mm Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +105°C UL Temperature Rating: 105°C Bulk Cable Weight: 52.831 Kg/Km Max. Recommended Pulling Tension: 266.892 N Min. Bend Radius (Install)/Minor Axis: 57.150 mm Page 1 of 3 05-10-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9964 Multi-Conductor - Communication and Instrumentation Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-16878E/17 (insulated conductor) Flame Test UL Flame Test: UL1685 UL Loading, VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 131.24 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 328.1 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 29.529 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 16.0769 Max. Operating Voltage - UL: Voltage 600 V RMS Max. Recommended Current: Current 3.8 Amps per conductor @ 25°C Related Documents: No related documents are available for this product Put Ups and Colors: Item # Putup Ship Weight Color 9964 009100 30 MT 1.950 KG WHITE 9964 0091000 305 MT 17.690 KG WHITE 9964 009500 152 MT 8.165 KG WHITE Notes Item Desc 4 #20 PVC SHLD PVC C 4 #20 PVC SHLD PVC 4 #20 PVC SHLD PVC Notes: C = CRATE REEL PUT-UP. Page 2 of 3 05-10-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9964 Multi-Conductor - Communication and Instrumentation Cable Revision Number: 2 Revision Date: 09-19-2008 © 2011 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 05-10-2011
9964 009500
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并转换成电信号输出。
3. 引脚分配:EL817共有3个引脚,分别为VCC、OUT和GND。
4. 参数特性:工作电压为3-6V,工作电流为0.1mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号,并将其转换成电信号输出,用于遥控设备。
6. 应用信息:EL817广泛应用于电视、空调等家用电器的遥控。
7. 封装信息:EL817采用SOP-8封装。
9964 009500 价格&库存
很抱歉,暂时无法提供与“9964 009500”相匹配的价格&库存,您可以联系我们找货
