AX102269
AX102269
    BELDEN
    10GX JACK MDVO GRAY
AX102269 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX102269 Modular Connectors - 10GX Modular Jack - MDVO style For more Information please call 1-800-Belden1 General Description: 10GX Modular Jack, Category 6A, RJ45, MDVO Style, Gray Usage (Overall) Suitable Applications: IBDN System 10GX, TIA Category 6A, ISO Class E, 10GBASE-T Related Parts: Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels Physical Characteristics (Connectivity) Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 0.780 0.770 1.170 Materials Materials: Description Type Material Front Connection Flexible PCB Flexible PCB with 50u inch Gold over Nickel Rear Connection IDC Phosphor Bronze with Tin Plating over Nickel Connector Body Plastic - UL94V-0 N/A Color Color: Gray Wiring Scheme Wiring Scheme: T568A/B Weight Weight: 0.016 lbs. Included Parts Included Parts: 1 X-Bar + 1 Dust Cap Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Mechanical Characteristics (Connectivity) Footprint/Type: MDVO-Style Plug / Jack Compatibility: RJ45, RJ11 Termination Interface: Termination Connection Durabilities Front Mated Connection 750 cycles Rear IDC Connection 20 terminations Cable/Connector Retention: 15 lbs. Connector/Hardware Retention: 20 lbs. Plug/Connector Retention: 11.250 lbs. Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Tool Compatibility: Belden 110 Connecting Tool Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 Page 1 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX102269 Modular Connectors - 10GX Modular Jack - MDVO style MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 6A - TIA 568.B.2-10, ISO/IEC 11801:2002 Amendment 2 Third Party Performance Verification: ETL - Verified Category 6A Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Mated Connection Table 1: Max. Min. Min. Min. Min. Frequency Max. Insertion Loss Insertion Loss NEXT NEXT FEXT FEXT (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 0.100 0.050 75.000 77.000 75.000 80.000 4.000 0.100 0.050 75.000 77.000 71.100 75.100 8.000 0.100 0.050 75.000 77.000 65.000 69.000 10.000 0.100 0.050 74.000 77.000 63.100 67.100 16.000 0.100 0.060 69.900 72.900 59.000 63.000 20.000 0.100 0.070 68.000 71.000 57.100 61.100 25.000 0.100 0.080 66.000 69.000 55.100 59.100 31.250 0.110 0.090 64.100 67.100 53.200 57.200 62.500 0.160 0.140 58.100 61.100 47.200 51.200 100.000 0.200 0.180 54.000 57.000 43.100 47.100 200.000 0.280 0.260 48.000 51.000 37.100 41.100 250.000 0.320 0.300 46.000 49.000 35.100 39.100 300.000 0.350 0.330 42.900 46.700 33.600 37.600 400.000 0.400 0.380 37.900 42.900 31.100 35.100 500.000 0.450 0.430 34.000 40.000 29.100 33.100 625.000 0.480 37.100 Mated Connection Table - Footnote: 31.200 * TIA/EIA-568-B.2-10-2008 Category 6A Standard. ** Worst-case performance for a 10GX mated connection using 10GX modular plugs. Mated Connection Table 2: Min. Min. Min. Min. Min. Min. Min. Frequency Min. Return Loss Return Loss PSANEXT PSANEXT PSAACRF PSAACRF Balanced TCL Balanced TCL (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 4.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 8.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 10.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 16.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 20.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 25.000 30.000 34.100 70.500 72.000 67.000 72.000 40.000 45.000 31.250 30.000 34.100 70.500 72.000 67.000 72.000 38.100 45.000 62.500 30.000 34.100 70.500 72.000 67.000 72.000 32.100 39.100 100.000 28.000 30.000 70.500 72.000 67.000 72.000 28.000 35.000 200.000 22.000 24.000 64.500 66.000 61.000 66.000 22.000 29.000 250.000 20.000 22.000 62.500 64.000 59.000 64.000 20.000 27.000 300.000 18.500 20.500 61.000 62.500 57.500 62.500 18.500 25.500 400.000 16.000 18.000 58.500 60.000 55.000 60.000 16.000 23.000 500.000 14.000 16.000 56.500 58.000 53.000 58.000 14.000 21.000 625.000 13.000 56.100 56.100 Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm 19.100 Notes (Overall) Notes: Please see Installation Guide PX103771 Product Family Part Number List: Item Number Color AX102269 Gray AX102270 Almond Page 2 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX102269 Modular Connectors - 10GX Modular Jack - MDVO style AX102271 White AX102272 Black AX102273 Orange (TIA 606) AX102274 Red (TIA 606) AX102275 Yellow (TIA 606) AX102276 Green (TIA 606) AX102277 Blue (TIA 606) AX102278 Purple (TIA 606) AX102562 Ivory Put Ups and Colors: Item # Putup Ship Weight AX102269 1 EA 0.024 LB Revision Number: 0 Color Notes Item Desc 10GX JACK MDVO GREY Revision Date: 01-07-2010 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-27-2017
AX102269 价格&库存
很抱歉,暂时无法提供与“AX102269”相匹配的价格&库存,您可以联系我们找货
