BB3PHCT
BB3PHCT
    BELDEN
    BELDEN - BB3PHCT - CRIMP TOOL, TYCO 67 MULTIMATE TYPE II SERIES
BB3PHCT 数据手册
Product Bulletin PB 324 Belden® BNC High-Definition Connectors Belden, the brand Broadcast Engineers and A/V professionals trust, brings you innovation and superior performance with a new line of Belden Brilliance® HighDefinition BNC Connectors. Belden HD Brilliance Connectors with Belden Brilliance Coax Cables deliver unparalleled end-to-end performance for Broadcast Engineers and A/V Professionals A New Standard Designed specifically for Belden Brilliance Broadcast and Professional A/V Coaxial Cables, HD Brilliance Connectors maximize broadcast signal integrity, quality, performance and durability. Watertight Locking 1-Piece HD Brilliance BNC Compression Connectors The Watertight Locking Connector features a patentpending locking design feature, a screw-lock collar to physically “lock” the bayonet nut of the BNC in position. This limits movement of the BNC head and creates coaxial alignment from the cable through the BNC center pin, delivering superior return loss performance. In addition to the locking feature, the patent-pending Watertight Connector creates the industry’s first environmentally sealed BNC connector. Additional sealing rings prevent moisture from penetrating the bayonet nut of the BNC at the front of the connector while the TRUE 360° double bubble compression impedes moisture at the back of the connector. Locking 1-Piece HD Brilliance BNC Compression Connectors The patent-pending locking design features a screwlock collar to physically “lock” the bayonet nut of the BNC in position. This limits movement of the BNC head and creates coaxial alignment from the cable through the BNC center pin, delivering superior return loss performance. 1-Piece HD Brilliance BNC Compression Connectors The 1-piece design simplifies and speeds the installation by eliminating loose pins and sleeves. This allows for repeatable and consistent installations every time while delivering return loss performance on par with more time consuming, traditional 3-piece designs. 3-Piece HD Brilliance BNC Crimp Connectors The traditional 3-piece design many have come to know over the years, enhanced to fit perfectly with Belden Brilliance Cable, for strong and dependable signal delivery and performance. Key Benefits • True 75 Ω performance • Extended BNC head knurl nut design to ease identification and installation • Superior return loss through 4.5 GHz • Excellent holding force exceeding 100 lbs, depending on cable type • Fast installation with 1-piece design Connectors should not hinder signal performance, and Belden delivers this with unsurpassed return loss performance, faster, easier installations, excellent durability and innovative features. Testing and Innovation Belden understands that the industry is familiar and comfortable with 3-piece broadcast connector designs, which is why we included a 3-piece HD Connector in our offering. But we also know there are those out there who enjoy the benefits of innovation, and recognize new and better ways of installing connectors. Belden has built its reputation by consistently delivering innovation, quality and performance — exactly what is needed in the Broadcast and Professional A/V industry. And we deliver again with the addition of the Belden HD Brilliance Connector family. Belden engineers performed over 1600 tests, including hundreds of competitors’ connectors, to establish a “real” performance baseline for the industry. The findings helped Belden identify opportunities for improvement, resulting in the products you see today. It also proved that using the innovation of compression technology really can produce a better solution. Return Loss Performance A major concern of the engineer is signal loss. Signal loss occurs two ways: Attenuation and return loss. Return loss (RL) is a good way to represent the quality and consistency of the signal path. Better (more negative) RL measurements are the result of better impedance stability within the signal path and, therefore, lower reflected signal loss in the path. The data below represents the typical performance you can expect from the Belden line of HD Brilliance BNC Connectors. Again, this is not the maximum reading of a single connector, but rather the combined average of over sixty repeat tests. Offered in the traditional 3-piece design and easier to install 1-piece design, the performance of these connectors is better than -20 dB through 4.5 GHz, meeting the most stringent demands of the Broadcast Industry and exceeding the SMPTE specification requirements. Additionally, the unique Locking BNC by Belden offers not only assurance of the connection, but provides for superior electrical performance at high frequencies, further enhancing the signal transmission path provided by the Belden HD Brilliance solution. 2 For more details on RL Performance, see the “Precision Video Coaxial Cables — Return Loss” and “High-Definition and Return Loss” technical papers available on www.belden.com. Product Overview Belden HD Brilliance Connectors include three connector types, each offering varying levels of electrical performance and installation speed: Locking 1-Piece Design • Screw-lock collar provides superior electrical signal performance by creating coaxial alignment between the cable and connector center pin, delivering return loss results that exceed -20 dB at 4.5 GHz • A non-blind entry provides the assurance that the center conductor is properly inserted into the BNC center pin, making connector installation easy and repeatable on every installation • Improved insulator materials sustain maximum return loss performance • 1-Piece design eliminates pin, collar and connector as separate components, simplifying and speeding connection installation time 179DTBHDL 179 Digital Truck BNC with Locking Connector • Internal 360º compression rings provide excellent holding strength and eliminate ingress and egress from the back of the connector Internal Depiction of a Belden HD Brilliance Connector Modified BNC Head For The Locking Feature Insulator Non-Blind Entry Compression Sleeve Connector Pin Color Coded To The Cable Type 1-Piece Design Offers excellent return loss performance comparable with our 3-piece design, but with a faster, simpler installation, and the benefit of a custom fit with Belden Brilliance Cable tolerances. Same great 1-piece design features of non-blind entry, compression rings and improved insulator, providing easy and repeatable installation every time. The Belden 1-Piece compression technology is a fast and proven approach to a Belden end-to-end solution. 1694ABHDLW RG6 Watertight BNC HD Connector & BNCTL BNC Terminator w/ Lanyard 3-Piece Design Traditional pin, collar and connector approach, but designed specifically for Belden Cable tolerances for better performance and durability. Compatible with select competitive crimp tools and die sets. 1505ABHD3 RG59 BNC HD Connector Color Coding All Belden HD BNCs come with Belden’s patented extended head knurl nut design for easy gripping when installing. The connector color band also makes matching the proper connector with proper cable size simple. Product Warranty • Limited Lifetime Connector Warranty when partnered with Belden Brilliance Cable Belden branded with part number and color coded to the cable: = RG7 (Belden 1794A) = RG6 (Belden 1694A) = RG59 (Belden 1505A) = 28.5 AWG RGB/Mini Coax (Belden 179DT) = 23 AWG RGB/Mini Coax (Belden 1855A) • 10-Year Connector Warranty when used with other brands of cable 3 Product Offering The Belden HD Brilliance Connector offering currently targets Belden Brilliance Coaxial Cables most frequently used by Broadcast and Professional AV engineers worldwide. Connector part numbers reflect corresponding cable part numbers, but are not limited to these cables only. Locking 1-Piece Compression Part Number Description Type Finish Color Band Impedence (ohms) Pullout Strength RL@3 GHz RL@3.5 GHz RL@4 GHz RL@4.5 GHz QTY 1694ABHDLW RG-6 Watertight BNC HD Connector 1-Piece Locking Polished Nickel Green 75 103(+) -26 dB -29 dB -39 dB -29 dB 50 1694ABHDL RG-6 BNC HD Connector 1-Piece Locking Polished Nickel Green 75 103(+) -26 dB -29 dB -39 dB -29 dB 50 1695ABHDL RG-6 Plenum Size 2 BNC HD Connector 1-Piece Locking Polished Nickel Green 75 103(+) -26 dB -29 dB -39 dB -29 dB 50 1505ABHDL RG-59 BNC HD Connector 1-Piece Locking Polished Nickel Red 75 73(+) -26 dB -29 dB -39 dB -29 dB 50 1506ABHDL RG-59 Plenum Size 2/4 BNC HD Connector 1-Piece Locking Polished Nickel Red 75 73(+) -26 dB -29 dB -39 dB -29 dB 50 1855ABHDL 22-24 AWG BNC HD Connector 1-Piece Locking Polished Nickel Purple 75 67(+) -26 dB -29 dB -39 dB -29 dB 50 179DTBHDL 179 Digital Truck BNC HD Connector 1-Piece Locking Polished Nickel Yellow 75 Exceeds Cable Strength -26 dB -29 dB -39 dB -29 dB 50 Type Finish Color Band Impedence (ohms) Pullout Strength RL@3 GHz RL@3.5 GHz RL@4 GHz RL@4.5 GHz QTY * BNCTL, BNC Terminator with Lanyard purchased separately 1-Piece Compression Part Number Description 1794ABHD1 RG-7 BNC HD Connector 1-Piece Compression Polished Nickel White 75 103(+) -31 dB -31 dB -25 dB -21 dB 50 1694ABHD1 RG-6 BNC HD Connector 1-Piece Compression Polished Nickel Red 75 103(+) -31 dB -31 dB -25 dB -21 dB 50 1695ABHD1 RG-6 Plenum Size 2 BNC HD Connector 1-Piece Compression Polished Nickel Red 75 103(+) -31 dB -31 dB -25 dB -21 dB 50 1505ABHD1 RG-59 BNC HD Connector 1-Piece Compression Polished Nickel Green 75 73(+) -31 dB -31 dB -25 dB -21 dB 50 1506ABHD1 RG-59 BNC HD Connector 1-Piece Compression Polished Nickel Green 75 73(+) -31 dB -31 dB -25 dB -21 dB 50 1855ABHD1 22-24 AWG BNC HD Connector 1-Piece Compression Polished Nickel Green 75 67(+) -31 dB -31 dB -25 dB -21 dB 50 179DTBHD1 179 Digital Truck BNC HD Connector 1-Piece Compression Polished Nickel Purple 75 Exceeds Cable Strength -31 dB -31 dB -25 dB -21 dB 50 Type Finish Color Band Impedence (ohms) Pullout Strength RL@3 GHz RL@3.5 GHz RL@4 GHz RL@4.5 GHz QTY 3-Piece Crimp Part Number Connector Description 179DTBHD3 RG59BNC HD Connector 3-Piece Crimp Polished Nickel Red 75 72(+) -27 dB -27 dB -21 dB -23 dB 50 1855ABHD3 RG6BNC HD Connector 3-Piece Crimp Polished Nickel Green 75 90(+) -27 dB -27 dB -21 dB -23 dB 50 1505ABHD3* 22-24 AWG BNC HD Connector 3-Piece Crimp Polished Nickel Purple 75 75(+) -27 dB -27 dB -21 dB -23 dB 50 1694ABHD3* 179 Digital Truck BNC Connector 3-Piece Crimp Polished Nickel Yellow 75 See Cable Spec -27 dB -27 dB -21 dB -23 dB 50 * These connectors can be used with a Plenum Cable 1-Piece Compression and Cable Strip Tools Part Number Tool Description QTY PSA59/6 59/6 Strip Tool for RG59 or RG6 Cable 1 PS59/6/RGB RGB Strip Tool for RG59, RG6 and RGB/Mini Coax (22-26 AWG) 1 CPLCRBC-B Compression Tool for HD Brilliance BNC Connectors and Double Bubble F, RCA and BNC Connectors 1 3-Piece Crimp Tools Part Number Tool Description QTY BB3PHCT Belden HD Brilliance Three-Piece Hex Connector Tool 1 BB3PHCT-D Replacement Die for BB3PHCT 1 BB3PST Belden HD Brilliance Three-Piece Strip Tool 1 BB3PST-C Replacement Cassette for BB3PST 1 Available accessory: Belden’s strain relief boots with an extended, all-weather design provide enhanced connector strain relief protection at the base of the connector. Available in SLS-59/6 (RG59&6), and SLS-RGB-* (RGB/Mini Coax). * = Indicate color when ordering: Yellow, Red, White or Black. Belden Customer Support 1.800.685.9452 © Copyright 2012, Belden Inc. www.belden.com PB324
BB3PHCT
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种高速光耦器件,用于隔离数字信号传输。
3. 引脚分配:EL817有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作电压范围为3V至15V,传输速率可达20Mbps。
5. 功能详解:EL817内部包含发光二极管和光敏三极管,实现电-光-电转换。
6. 应用信息:适用于高速数据通信、工业控制等领域。
7. 封装信息:EL817采用DIP-8封装。
BB3PHCT 价格&库存
很抱歉,暂时无法提供与“BB3PHCT”相匹配的价格&库存,您可以联系我们找货
BB3PHCT
    • 1+3404.244751+440.33917
