Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
C601108004 Cable Assemblies - CAT6+ Modular Cord
For more Information
please call
1-800-Belden1
General Description:
CAT6+ Patch Cord, Bonded-Pair, 4 Pair, 24 AWG Solid, CMR, T568A/B-T568A/B, Gray, 4 ft. (1.2 m).
Usage (Overall)
Suitable Applications:
IBDN System 4800, IBDN System 2400,TIA Category 6, ISO Class E, 1000BASE-T
Related Parts:
CAT6+ Modular Jacks, CAT6+ Patch Panels
Multi Conductor
Physical Characteristics
Conductor
AWG:
# Pairs AWG Stranding Conductor Material
4
24
Solid
BC - Bare Copper
Insulation
Insulation Material:
Insulation Material
PO - Polyolefin
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Outer Jacket Color Code Chart:
Color
Gray
Overall Cabling
Overall Cabling Fillers:
Cross Web
Overall Diameter
Overall Nominal Diameter:
6.045 mm
Individual Cable Diameter:
6.350 mm
Physical Characteristics (Connectivity)
Materials
Materials:
Description
Type
Material
Plug
RJ45
Polycarbonate
Boot
Rubber
Front Connection Blades Phosphor Bronze with 50u inch Gold over Nickel Plating
Color
Boot Color:
Translucent
Wiring Scheme
Wiring Scheme:
T568A/B-T568A/B
Weight
Weight:
0.027 kg
Packaging
Packaging:
Individually packaged in a clear plastic bag.
Mechanical Characteristics (Connectivity)
Plug / Jack Compatibility:
RJ45
Termination Interface:
Termination Connection
RJ45
Durabilities
Mated Connection 750 Cycles
Page 1 of 3
07-31-2017
Storage Temperature Range:
-40°C To +70°C
Installation Temperature Range:
-10°C To +60°C
Operating Temperature Range:
-10°C To +60°C
Max. Recommended Pull Tension:
111.205 N
Min. Bend Radius (Overall Cable):
26.416 mm
Environmental/Mechanical Characteristics:
Test (Method)
TIA 568-D.3
Belden
Thermal Cycling (FOTP-3)
n/a
-40 to 75°C cycling for 7 days
Temperature Life (FOTP-4) 60°C for 4 days
85°C for 7 days
Humidity (FOTP-5)
90-95% at 40°C for 4 days
95% @ 75°C for 7 days
Durability (FOTP-21)
500 cycles
6 x 200 cycles (3 Elevations)
Cable Retention (FOTP-6)
5.0 kg @ 0 deg.
1.94 kg @90 deg.
Flex (FOTP-1)
0.5 kg @ 90° to -90° for 100 cycles 0.9 kg @ 90° to -90° for 100 cycles
Twist (FOTP-36)
1.5 kg for 10 cycles
Overall Length Tolerances:
Range
Tolerance
Range
Sx & Dx Patchcord Sx & Dx Patchcord MPO Trunk
Tolerance
Range
MPO Trunk
Multi-Fiber Cable Assembly Multi-Fiber Cable Assembly
Tolerance
0 to 2 meters
+0.2 / -0 meter
0 to 2 meters
+0.2 / -0 meter 0 to 2 meters
2.1 to 5.0 meters
+0.3 / -0 meter
2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters
+0.3 / -0 meter
5.1 to 40 meters
+0.4 / -0 meter
5.1 to 20 meters
+0.4 / -0 meter
Over 40.1 meters
+ 1.0% / -0%
Over 20.1 meters + 1.0% / -0%
+0.4 / -0 meter 5.1 to 20 meters
Over 20.1 meters
+0.2 / -0 meter
+ 1.3 / -0 meter
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
Riser
Other Standards:
FCC Part 68, Subpart F, IEC 60603-7
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2006
MII Order #39 (China RoHS):
EUP 50
Telecommunications Standards:
Category 6 - TIA 568.C.2, ISO/IEC 11801:2002 Ed.2
Safety Listing:
ACA, Bi-national Standard Listed
Suitability
Suitability - Indoor:
Yes
Transmission Characteristics (Connectivity)
Optical Connector Performance:
Description
OM1
OM2
OM3
OM4
OS2 / UPC OS2 / APC
Maximum Insertion Loss (dB) 0.5 dB 0.5 dB 0.5 dB 0.15 dB 0.5 dB
0.5 dB
Minimum Reflectance (dB)
- 65 dB
-20 dB -20 dB -20 dB -20 dB
-50 dB
Performance Table 1:
Max.
Min.
Min
Min.
Min.
Frequency Max.
Insertion Loss Insertion Loss PSNEXT PSNEXT
PSACRF PSACRF
(MHz)
TIA* (dB)
Belden (dB)
TIA* (dB) Belden (dB) TIA* (dB) Belden (dB)
1.000
2.400
2.000
72.300
73.300
64.800
67.800
4.000
4.500
3.700
63.300
64.300
52.800
55.800
8.000
6.400
5.200
58.800
61.300
46.700
49.700
10.000
7.100
5.900
57.300
59.800
44.800
47.800
16.000
9.100
7.400
54.200
56.600
40.700
43.700
20.000
10.200
8.300
52.800
55.100
38.800
41.800
25.000
11.400
9.300
51.300
53.500
36.800
39.800
31.250
12.800
10.400
49.900
52.000
34.900
37.900
62.500
18.500
14.900
45.400
47.100
28.900
31.900
100.000
23.800
19.000
42.300
43.800
24.800
27.800
200.000
34.800
27.500
37.800
38.900
18.800
21.800
250.000
39.400
31.000
36.300
37.300
16.800
19.800
300.000
34.200
36.100
18.300
Performance Table - Footnote:
100 Meter Cable Specifications - * TIA-EIA-568-C.2 Category 6 Standard -------- PSACRF is formally
PSELFEXT
Performance Table 2:
Min.
Min.
Min.
Min.
Frequency (MHz) Return Loss Return Loss Balanced TCL Balanced TCL
TIA* (dB)
Belden (dB)
1.000
20.000
20.000
40.000
40.000
Page 2 of 3
07-31-2017
4.000
23.000
23.000
40.000
40.000
8.000
24.500
24.500
40.000
40.000
10.000
25.000
25.000
40.000
40.000
16.000
25.000
25.000
38.000
38.000
20.000
25.000
25.000
37.000
37.000
25.000
24.200
24.300
36.000
36.000
31.250
23.300
23.600
35.100
35.100
62.500
20.700
21.500
32.000
32.000
100.000
19.000
20.800
30.000
30.000
200.000
16.400
18.700
27.000
27.000
250.000
15.600
18.000
26.000
26.000
300.000
17.500
Dielectric Strength:
1,000 V RMS @ 60 Hz for 1 minute
Current Rating:
1.500 A
Insulation Resistance:
500 M-Ohm Minimum
Max. Contact Resistance:
20 m-Ohm
Notes (Overall)
Notes: C601108004 is subdivided as following C6-01-1-08-004 C6 stands for performance, 01 stands for cable type, 1 stands for termination type, 08 stands for color, 004 stands
for length Use last 3 digits of the code to specify length in feet - 001-015 ft in increments of 1 ft than 20 ft or 25 ft
Notes (Cont'd.):
www.belden.com/p
Product Family
Product List:
Length
Yellow
2 ft. (0.6 m)
C601104002 C601105002 C601106002 C601108002 C601109002 C601100002 C601107002
Green
Blue
Gray
White
Black
Purple
4 ft. (1.2 m)
C601104004 C601105004 C601106004 C601108004 C601109004 C601100004 C601107004
7 ft. (2.1 m)
C601104007 C601105007 C601106007 C601108007 C601109007 C601100007 C601107007
10 ft. (3.0 m) C601104010 C601105010 C601106010 C601108010 C601109010 C601100010 C601107010
15 ft. (4.6 m) C601104015 C601105015 C601106015 C601108015 C601109015 C601100015 C601107015
25 ft. (7.6 m) C601104025 C601105025 C601106025 C601108025 C601109025 C601100025 C601107025
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
C601108004
1 EA
0.159 LB
GRAY 1SR
Revision Number: 1
Notes
Item Desc
PATCHCORD BCAT6+ CMR GRY 4FT
Revision Date: 03-11-2014
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
07-31-2017
很抱歉,暂时无法提供与“C601108004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+140.094091+17.52256
