A
Splice Closures
& Sheath
Repair
Splice Closures & Sheath Repair
Buried Closures
KLIK-IT® Buried Service Wire Closures
A range of filled, two-piece closures designed permanent splice encapsulation of 2 to 25
pair buried service drops. Economical and easy-to-install, these closures go together quickly
and are ready for burial as soon as the splice is completed.
Design Features:
•• Tough durable two-piece plastic housing- “clicks” tightly closed
•• Pre-packed with grease type re-enterable encapsulant
25 Pair KLIK-IT
•• Water resistant
•• Grease surrounds the splice connectors preventing corrosion and electrical shorting
•• Re-enterable
•• Optional strain relief and bonding hardware on some models
•• Packaged in shrink-wrap for longer shelf-life and ease of transportation
•• Straight and butt splice versions available
Butt Splice
•• Models C8825 and C88320 conform to Bellcore TR-NWT-000251
In-Line Splice
Part Number
Description
Max Pair Splice Style
Strain
Relief
Bonding
Outer Pack
Inner
Pack
Min Order
QTY
BUTT SPLICE KLIK-IT
C8811
Standard KLIK-IT II
5
Butt
No
Barrel
72
72
C8811BCT
Wide Neck KLIK-IT II
5
Butt
Yes
None
72
72
C8811G
Standard KLIK-IT II with Bond Stud Coin
5
Butt
No
Bond Coin
72
72
C8816
Standard KLIK-IT II w/out grounding
5
Butt
No
None
72
72
C8816KB
Standard KLIK-IT II with Strain Relief
5
Butt
Yes
None
72
72
C8820
Standard KLIK-IT III
5
Butt
Yes
Integral
72
72
C885611X
KLIK-IT II 6 pair
6
Butt
No
Split Bolt
72
72
C8812
Large Capacity KLIK-IT
25
Butt
No
None
15
15
STRAIGHT SPLICE KLIK-IT
C8813
Standard KLIK-IT SS
5
Straight
No
Barrel
1152
48
48
C8815
Standard KLIK-IT SS w/out Grounding
5
Straight
No
None
1152
48
48
C8825
Standard KLIK-IT SSIII
5
Straight
Yes
Integral
1152
48
48
Straight
No
None
1152
48
48
STRAIGHT SPLICE KLIK-IT FOR COPPER AND COAX CABLE
C8826U
KLIT-IT SSC with with Coax Connector
Customer Support: 800.800.6652
5
www.ppc-online.com
A15
A BELDEN BRAND
很抱歉,暂时无法提供与“C8811”相匹配的价格&库存,您可以联系我们找货
