CAPFCF-B25
CAPFCF-B25
    BELDEN
    CAT6/6A FIELD CRIMPED PLUG KIT
CAPFCF-B25 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION CAPFCF-B25 Modular Connectors - FIELD CRIMPED PLUG 8MOD (RJ45) CAT6/6A SHIELDED KIT For more Information please call 1-800-Belden1 General Description: FIELD CRIMPED PLUG 8MOD (RJ45) CAT6/6A SHIELDED (25-PACK) Usage (Overall) Suitable Applications: TIA Category 6 & TIA Category 6A, ISO Class E, ISO Class EA, ISO Class D, 1000BASE-T, 10GBase-T Related Parts: Boot CB6MM, Boot CB7MM & Boot CB8MM , Recommended CAT6 & CAT6A Shielded cables (Solid & Stranded). Physical Characteristics (Connectivity) Dimensions Dimensions: Height (mm) Width (mm) Length (mm) 7.925 11.684 22.606 Materials Materials: Description Type Material Plug RJ45 Polycarbonate Contact Phosphor Bronze Alloy Plated with 50u inch Gold Shield Hard Brass Plated with Tin Color Color: Clear Weight Weight: 0.074 kg Included Parts Included Parts: RJ45 Plug, Load Bar, Wire guide, Installation Guide, Copper tape (shield), Boot CB8MMBK. Packaging Packaging: Kit of 25 units per Bag. Mechanical Characteristics (Connectivity) Termination Interface: Termination Connection RJ45 Durabilities Mated Connection 1000 Cycles Operating Temperature Range: -40°C To +85°C Tool Compatibility: Crimping Tool CTPFC01 Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 94V-0 Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 Telecommunications Standards: Category 6 - TIA 568.C.2, Category 6A - TIA 568.C.2, ISO/IEC 11801:2002 Ed.2 Other Specification: Complies with ANSI/TIA-1096-A Requirements. Suitability Suitability - Indoor: Yes - Indoor Page 1 of 2 07-31-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION CAPFCF-B25 Modular Connectors - FIELD CRIMPED PLUG 8MOD (RJ45) CAT6/6A SHIELDED KIT Transmission Characteristics (Connectivity) Mated Connection Table - Footnote: * Category 6 - TIA 568.C.2 when tested with Recommended CAT6 Cables. Category 6A - TIA 568.C.2 when tested with Recommended CAT6A Cables. Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 10 m-Ohm Notes (Overall) Notes: For additionnal information about this product, refer to Installation Guide PX106197, or visit our web at http//:www.belden.com Notes (Cont'd.): Suitable for Conductors with insulation OD range 0.044~0.048 in. and for Cable OD range 0.23~0.31 in. (6~8 mm ). Please refer to the cable-plug compatibility guide ‘Plug Compatibility Matrix V1 ECOS BDC 0415 A AG’ for proper pairings. Product Family Part Number List: Description Part Number 8MOD (RJ45) FIELD CRIMPED PLUG KIT CAT5E SHIELDED (25-PACK) C5PFCF-B25 8MOD (RJ45) FIELD CRIMPED PLUG KIT CAT5E/6 UTP (25-PACK) C6PFCU-B25 8MOD (RJ45) FIELD CRIMPED PLUG KIT CAT6/6A UTP (25-PACK) CAPFCU-B25 8MOD (RJ45) FIELD CRIMPED PLUG KIT CAT6/6A SHIELDED (25-PACK) CAPFCF-B25 BOOT 6MM FOR FIELD CRIMPED PLUG, BLACK (100-PACK) CB6MMBK-B100 BOOT 7MM FOR FIELD CRIMPED PLUG, BLACK (100-PACK) CB7MMBK-B100 BOOT 8MM FOR FIELD CRIMPED PLUG, BLACK (100-PACK) CB8MMBK-B100 CRIMPING TOOL FOR FIELD RJ45 PLUG CTPFC01 Put Ups and Colors: Item # Putup Ship Weight CAPFCF-B25 25 EA 4.075 LB Revision Number: 0 Color Notes Item Desc CAT6/6A FIELD CRIMPED PLUG KIT Revision Date: 04-23-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 07-31-2017
CAPFCF-B25 价格&库存
很抱歉,暂时无法提供与“CAPFCF-B25”相匹配的价格&库存,您可以联系我们找货
CAPFCF-B25
  • 1+1556.416861+202.26034
  • 10+1323.0561310+171.93452
  • 25+1240.3121025+161.18172
  • 50+1181.2046650+153.50056
