DB59BNCSL2-F
DB59BNCSL2-F
    BELDEN
    CONN, 59BNC SL2, FEMALE
DB59BNCSL2-F 数据手册
® The Industry Leader in True 360º Compression Connectors & Tooling Systems www.icmcorp.net F-Conn Compression Connectors Universal Compression Connectors..........................................................................4 Plenum & Security (CCTV) Compression Connectors..............................................5 RGB/Mini Coax Compression Connectors................................................................6 Right Angle Compression Connectors......................................................................7 Speaker Compression Connectors...........................................................................8 Splice (Female) Compression Connectors ............................................................12 Double Bubble™ Compression Connectors Double Bubble™ Compression Connectors............................................................. 13 Plenum & Security/ CCTV Compression Connectors............................................. 14 DS3 & DS4 DB™ Compression Connectors............................................................ 14 Intelligent Transportation System (ITS) Connectors............................................... 15 50 Ohm Compression Connectors.......................................................................... 15 High Definition BNC DB™ Compression Connectors......................................... 16-17 Basic Connector Series RG11 Compression Connectors............................................................................. 19 Basic Compression Connector Series ................................................................... 20 Compression Connector Accessories Color Bands and Color O-Rings................................................................................9 Strain Relief Boots.................................................................................................. 18 Home Integration Products Wall Plate System............................................................................................... 9-12 High Density Wall Plates .........................................................................................11 Cable Pro Tools Cable Strip Tools......................................................................................................21 RTC 360 Basic Series Compression Tool............................................................... 22 CPLCRTC-B F-type & RCA Compression Tool....................................................... 23 CPLCRBC-B Double Bubble™ Compression Tool................................................. 23 CPLCCT-SLM Linear Compliant Compression Tool............................................... 24 CPLCCT-1-S Compression Tool............................................................................. 24 CPLCCT-SS59/11 RG59, 6, 7, 11 Compression Tool............................................. 25 CPLCCT-11BNC RG11 BwC Compression Tool..................................................... 25 CPLCRBC-ITS Compression Tool.......................................................................... 25 CPCAT5-PDT Punch Down Tool............................................................................. 26 CPRJ11-45 Strip/Crimp Tool................................................................................... 26 Compression Tool and Connector Kits...............................................................27-28 Installation Tools & Accessories HDMI Cable............................................................................................................. 29 Cable Caddies......................................................................................................... 30 Cable Pro Torque Wrenches .............................................................................31-32 Cable Pro Installation Tools................................................................................32-37 Splitters................................................................................................................... 38 CABLEREADY Cable Molding................................................................................ 39 Compression Connector Sizing Chart................................................................ 40-43 WWW.ICMCORP.NET Belden’s F-Conn Compression Connectors are the reason we are recognized today as an industry leader of TRUE 360º compression. These patented features allow us to provide a permanent connection from the start: • • • • • • • • TRUE 360º compression technology Designed to reduce forward reflection Provides superior pullout strength Internal compression rings eliminate ingress/egress NO soldering required Meet/ Exceed SCTE-IPC and Bellcore requirements One-piece design option eliminates loose pins and sleeves Patented non-blind entry assists with the insertion of the cable into the connector • High-quality, ISO 9001 certified manufacturing facility Connector Type Cable Size RGB F-CONN BASIC SERIES RG59 RG59Q RG6 RG6Q RG7 RG11 X X X X X X F-CONN COMMERCIAL/NICKEL (FS) X X X X X F-CONN GOLD (RG) X X X X X F-CONN DOUBLE BUBBLE X X X X X WALL PLATE SPLICE (FEMALE) X X X X X Compression Connectors Compression Connectors X Call for Tech Support 800.222.2142 3 WWW.ICMCORP.NET Compression Connectors Universal Compression Connectors INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V • F-Conn compression connectors are universal for PVC coax RG59 and RG6 • Available in F, RCA and BNC • Choice of nickel (FS) or gold (RG) connectors SECURITY CPLCCT-SLM PS59/6/RGB PSA59/6 Nickel Part# Gold Part# Connector Description Tip Req’d Tool Req’d FS59BNCU RG59BNCU RG59 Universal BNC (Red) NONE CPLCCT-SLM FS59RCAU RG59RCAU RG59 Universal RCA (Red) LMTIP-S/G CPLCCT-SLM FS59U RG59U RG59 Universal F (Red) LMTIP-S/G CPLCCT-SLM FS59IECUF RG59IECUF RG59 European IEC Connector, Female (Red) LMTIP-IEC CPLCCT-SLM RG59 European IEC Connector, Male (Red) LMTIP-IEC CPLCCT-SLM RG6 Universal BNC (Green) NONE CPLCCT-SLM FS59IECUM FS6BNCU FS6RCAU RG6RCAU RG6 Universal RCA (Green) LMTIP-S/G CPLCCT-SLM FS6U RG6U RG6 Universal F (Green) LMTIP-S/G CPLCCT-SLM FS6IECUF RG6IECUF RG6 European IEC Connector, Female (Green) LMTIP-IEC CPLCCT-SLM RG6 European IEC Connector, Male (Green) LMTIP-IEC CPLCCT-SLM FS6IECUM 4 RG6BNCU Call for Tech Support 800.222.2142 WWW.ICMCORP.NET INDUSTRY USE: COMMERCIAL SECURITY CPLCCT-SLM • Available in F, RCA and BNC for a variety of cable sizes • Specially engineered plenum connectors provide an easy custom fit • Plenum and Security (CCTV) connectors are available for SLM and DB Systems • The Security connectors are designed for CCTV coaxial cable with copper braiding and a solid copper center conductor • For ease of installation use the Cable Pro FIT-59 or FIT-6 Insertion Tool Part# Connector Description Tip Req’d Tool Req’d FS59RCASL RG59 Security (CCTV) RCA (Red) - Nickel LMTIP-S CPLCCT-SLM FS59BNCSL RG59 Security (CCTV) BNC (Red) - Nickel NONE CPLCCT-SLM CPLCCT-SLM FS59PL RG59 Plenum F-type Size 1 (Red) - Nickel LMTIP-S FS59PL2 RG59 Plenum F-type Size 2 (Red) - Nickel LMTIP-S CPLCCT-SLM FS59PL4 RG59 Plenum F-type Size 4 (Red) - Nickel LMTIP-S CPLCCT-SLM FS59RCAPL RG59 Plenum RCA Size 1 (Red) - Nickel LMTIP-S CPLCCT-SLM FS59RCAPL2 RG59 Plenum RCA Size 2 (Red) - Nickel LMTIP-S CPLCCT-SLM FS59RCAPL3 RG59 Plenum RCA Size 3 (Red) - Nickel LMTIP-S CPLCCT-SLM FS59BNCPL RG59 Plenum BNC Size 1 (Red) - Nickel NONE CPLCCT-SLM FS59BNCPL2 RG59 Plenum BNC Size 2 (Red) - Nickel NONE CPLCCT-SLM FS59BNCPL3 RG59 Plenum BNC Size 3 (Red) - Nickel NONE CPLCCT-SLM FS59BNCPL4 RG59 Plenum BNC Size 4 (Red) - Nickel NONE CPLCCT-SLM FS6PL RG6 Plenum F-type Size 1 (Green) - Nickel LMTIP-S CPLCCT-SLM CPLCCT-SLM FS6PL2 RG6 Plenum F-type Size 2 (Green) - Nickel LMTIP-S FS6RCAPL RG6 Plenum RCA Size 1 (Green) - Nickel LMTIP-S CPLCCT-SLM FS6RCAPL2 RG6 Plenum RCA Size 2 (Green) - Nickel LMTIP-S CPLCCT-SLM FS6BNCPL RG6 Plenum BNC Size 1 (Green) - Nickel NONE CPLCCT-SLM FS6BNCPL2 RG6 Plenum BNC Size 2 (Green) - Nickel NONE CPLCCT-SLM Compression Connectors Plenum and Security (CCTV) Compression Connectors NOTE: All cable for Belden compression connectors should be sized using the Belden Cable Sizing Chart located on pages 40-43 or at www.icmcorp.net/ICM_techinfo.com Call for Tech Support 800.222.2142 5 WWW.ICMCORP.NET Compression Connectors RGB/ Mini Coax Compression Connectors INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V • Available in two sizes: • RG15 (22-24 AWG), purple • RG1 (25-26 AWG), orange • F, RCA & BNC connector types • Multi-piece RGB connectors are for solid center wire or stranded cable • One-piece RGB connectors are for solid center conductor wire only, allowing installers to save time while retaining quality • RGB F pin-type connector for RG15 (22-24AWG wire) • Stringent testing standards demonstrate superior return loss numbers on all our RGB/ mini coax connectors Nickel Part# Gold Part# FS15 SECURITY CPLCCT-SLM Connector Description Tip Req’d Tool Req’d F, 1 Piece Solid Center Cond., RGB 22-24 AWG (Purple) LMTIP-S CPLCCT-SLM FS15BNC RG15BNC BNC, 1 Piece Solid Center Cond., RGB 22-24 AWG (Purple) NONE CPLCCT-SLM FS15RCA RG15RCA RCA, 1 Piece Solid Center Cond., RGB 22-24 AWG (Purple) LMTIP-S/G CPLCCT-SLM FS1BNC RG1BNC BNC, 1 Piece Solid Center Cond., RGB 24-26 AWG (Orange) NONE CPLCCT-SLM FS1RCA RG1RCA RCA, 1 Piece Solid Center Cond., RGB 24-26 AWG (Orange) LMTIP-S/G CPLCCT-SLM FSBNC15RGB RGBNC15RGB BNC, Multi-Piece, NONE CPLCCT-SLM LMTIP-S/G CPLCCT-SLM NONE CPLCCT-SLM LMTIP-S/G CPLCCT-SLM RGB 22-24 AWG (Purple) FSRCA15RGB RGRCA15RGB RCA, Multi-Piece, RGB 22-24 AWG (Purple) FSBNC1RGB RGBNC1RGB BNC, Multi-Piece, RGB 24-26 AWG (Orange) FSRCA1RGB RGRCA1RGB RCA, Multi-Piece, RGB 24-26 AWG (Orange) NOTE: All cable for Belden compression connectors should be sized using the Belden Cable Sizing Chart located on pages 40-43 or at www.icmcorp.net/ICM_techinfo.com 6 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Right Angle Compression Connectors PROFESSIONAL A/V • Designed to allow for adequate cable bend radius when space is limited • A great solution for flush mounts, TV rack mounts, plasma/LCD televisions, and dome security camera installations • Features a positive stop design to help guide the cable into the connector and prevent it from being over-compressed • F, RCA and BNC are available for RG59, RG6 and RGB/ mini coax cable sizes SECURITY CPLCCT-SLM Part# Connector Description Tip Req’d Tool Req’d FSRCA15RA RCA 15RGB, Right Angle, Multi-piece, 22-24 AWG (Purple) - Nickel LMTIP-RA CPLCCT-SLM FSBNC15RA BNC 15RGB, Right Angle, Multi-piece, 22-24 AWG (Purple) - Nickel LMTIP-RA CPLCCT-SLM FSRCA1RA RCA 1RGB, Right Angle, Multi-piece, 25-26 AWG (Orange) - Nickel LMTIP-RA CPLCCT-SLM FSBNC1RA BNC 1RGB, Right Angle, Multi-piece, 25-26 AWG (Orange) - Nickel LMTIP-RA CPLCCT-SLM FS59URA RG59 F-type Universal Right Angle (Red) Nickel LMTIP-RA CPLCCT-SLM FSRCA59URA RG59 RCA Universal Right Angle (Red) - Nickel LMTIP-RA CPLCCT-SLM FSBNC59URA RG59 BNC Universal Right Angle (Red) - Nickel LMTIP-RA CPLCCT-SLM FS6URA RG6 F-type Universal Right Angle (Green) Nickel LMTIP-RA CPLCCT-SLM FSRCA6URA RG6 RCA Universal Right Angle (Green) Nickel LMTIP-RA CPLCCT-SLM FSBNC6URA RG6 BNC Universal Right Angle (Green) Nickel LMTIP-RA CPLCCT-SLM Compression Connectors INDUSTRY USE: COMMERCIAL NOTE: All cable for Belden compression connectors should be sized using the Belden Cable Sizing Chart located on pages 40-43 or at www.icmcorp.net/ICM_techinfo.com Call for Tech Support 800.222.2142 7 WWW.ICMCORP.NET Speaker Connector Series Speaker Compression Connector Series INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V CPLCCT-SLM • Patented design makes other audio connectors obsolete • Fits 12, 14 and 16 AWG cable • Two color rings per connector. CEA color-coding compatible • Screw-on tips (spade, banana, and pin type) allow for quick connector format conversion • Speaker binding post is designed to work in conjunction with the speaker connector line • Based on the same universal tool platform series (CPLCCT-SLM) as all Belden connectors • Works with Belden’s Wall Plate System and corresponding modular speaker installations Speaker Installation Speaker Series Part# Connector Description Tip Req’d Tool Req’d RGSPU 4 Speaker Connectors* LMTIP-G CPLCCT-SLM RGSPURA 4 Right Angle Speaker Connectors* LMTIP-RA CPLCCT-SLM *Each 4 pack includes 12, 14, and 16 AWG Sleeves - (4)Red / (6)Black Colored Rings RGSBPOST Female Speaker Binding Post 2 pack (1 red / 1 black)** LMTIP-G CPLCCT-SLM **Each 2 pack includes 2 posts, (1) Red screw nut and (1) Black screw nut also (2) Red 12 AWG, (2) Green 14 AWG, and (2) Yellow 16 AWG Sleeves. (Requires module clip to fit Wall Plate System) Screw-on Speaker Tips 8 Part# Connector Description RGSPL SPADE TIP RGSPB BANANA TIP RGSPP PIN TIP Call for Tech Support 800.222.2142 WWW.ICMCORP.NET FSCR-* Compression Connector Color Bands PROFESSIONAL A/V • Choose from an assortment of patented color bands to make cables and wires easy to identify • Simply slide the selected color band on over the compressed connector for easy identification Part# Description FSCR-* Universal Color Band - * *Available in B-Blue, BK-Black, BN-Brown, G-Green, GY-Grey, LG-Light Green, LP-Light Purple, O-Orange, P-Purple, PK-Pink, R-Red, T-Tan, W-White and Y-Yellow HIPO* Color O-Rings • Variety of color O-rings specifically designed for our splice connectors Part# Description HIPO* Universal Color O-Ring - * * = specify color choice: B-Blue, G-Green, K-Black, O-Orange, P-Purple, R-Red, W-White, Y-Yellow HIP Wall Plate System Components INDUSTRY USE: COMMERCIAL PROFESSIONAL A/V Compression Connector Color Bands / Wall Plate System INDUSTRY USE: COMMERCIAL As the single source for all your custom residential installation needs, Belden’s Home Integration Products (HIP) brings you an entire line of high-quality products that work together seamlessly. Call for Tech Support 800.222.2142 9 WWW.ICMCORP.NET Wall Plate System CHOOSE YOUR WALL PLATE DESIGN! Keystone Wall Plates • The Keystone Wall Plate Series features a simple, one-piece design Part# Description HIPBLANK-* Blank Wall Plate, Single Gang - * HIPWP* Wall Plate, Single Port - * HIPWP2* Wall Plate, Dual Port - * HIPWP3* Wall Plate, Triple Port - * HIPWP4* Wall Plate, Quad Port - * HIPWP6* Wall Plate, Six Port - * *= specify color choice: AL-Almond, BK-Black, IV-Ivory, LA-Light Almond, WH-White Decora Wall Plates and Inserts • The Decora Series is a superior quality wall plate system giving professional installers complete control over the installation project Decora Wall Plates Part# Description HIPDWP* Decora Wall Plate, Single Gang HIPDWP2* Decora Wall Plate, Double Gang HIPDWP3* Decora Wall Plate, Triple Gang HIPDWP4* Decora Wall Plate, Quad Gang * = specify color choice: AL-Almond, BK-Black, IV-Ivory, WH-White Decora Inserts Part# Description HIPDI* Decora Insert Single Port HIPDI2* Decora Insert Double Port HIPDI3* Decora Insert Triple Port HIPDI4* Decora Insert Quad Port HIPDI6* Decora Insert Six Port * = specify color choice: AL-Almond, BK-Black, IV-Ivory, WH-White 10 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET High Density Wall Plates Wall Plate System • Single and Dual high density wall plates available with an easy snap-on cover Single High Density Wall Plates Part# Description HIPHDWP-* Single High Density Wall Plate - * * = specify color choice: BK-Black, IV-Ivory, LA-Light Almond, WH-White Dual High Density Wall Plates Part# Description HIPHDDWP-* Single High Density Wall Plate - * * = specify color choice: BK-Black, IV-Ivory, LA-Light Almond, WH-White CHOOSE YOUR WALL PLATE OPTIONS! Wall Plate Modules • Interchangeable modular clips, inserts and plugs work with both Keystone and Decora Wall Plate Systems • Modular clips, inserts and plugs feature a clip mount for ease of installation • Professional installers have the option to use a full include range of audio, video and network formats that the RJ11, RJ45, CAT5e and CAT6 Punch Down Jack • Available in the corresponding wall plate colors and work with Belden’s splice (female) connectors Universal Insert Modules Part# Description HIPU*M Universal Insert Module * = specify color choice: AL-Almond, BK-Black, IV-Ivory, LA-Llight Almond, WH-White Blank Insert Modules Part# Description BLANKMOD-* Blank Insert Module * = specify color choice: AL-Almond, BK-Black, IV-Ivory, LA-Light Almond, WH-White Call for Tech Support 800.222.2142 11 WWW.ICMCORP.NET Wall Plate System - Splice (Female) Connectors Phone/ Data Insert Modules Part# Connector Description Tool Req’d HIPRJ11-50* RJ11 w/ 50 Micron Gold Plate NO TOOL HIPRJ45-50* RJ45 w/ 50 Micron Gold Plate NO TOOL HIPPDRJ11W RJ11 Phone Punch Down Jack - WHITE CPCAT5-PDT HIPPDC5EO RJ45 Cat5e Punch Down Jack - ORANGE CPCAT5-PDT HIPPDC5EB RJ45 Cat5e Punch Down Jack - BLUE CPCAT5-PDT HIPPDC5EW RJ45 Cat5e Punch Down Jack - WHITE CPCAT5-PDT HIPPDC6O RJ45 Cat6 Punch Down Jack - ORANGE CPCAT5-PDT * = specify color choice: AL-Almond, BK-Black, WH-White, O-Orange, B-Blue CHOOSE YOUR SPLICE CONNECTOR! Splice (Female) Compression Connectors CPLCCT-SLM • Designed for use with our patented Wall Plate System and Cable Pro’s Linear Compliant Compression Tool (CPLCCT-SLM) • F, RCA and BNC for RG59, RG6 and RGB/ mini coax cables • Splices are offered in nickel (FS) or gold (RG) • By utilizing a standalone female splice, installers are able to directly connect two wires eliminating a coupler or splice barrel, thus reducing signal loss and saving installation time Splice (Female) Compression Connectors 12 Part# Connector Description Tip Req’d Tool Req’d FS15RCASST (Nickel) RG15RCASST (Gold) RCA 15RGB, Splice 22-24 AWG (Purple) LMTIP-WP CPLCCT-SLM FS15BNCSST (Nickel) RG15BNCSST (Gold) BNC 15RGB, Splice 22-24 AWG (Purple) NONE CPLCCT-SLM FS1RCASST (Nickel) RG1RCASST (Gold) RCA 1RGB, Splice 24-26 AWG (Orange) LMTIP-WP CPLCCT-SLM FS1BNCSST (Nickel) RG1BNCSST (Gold) BNC 1RGB, Splice 24-26 AWG (Orange) NONE CPLCCT-SLM Call for Tech Support 800.222.2142 WWW.ICMCORP.NET RG59 F-type, Universal Splice (Red) LMTIP-WP CPLCCT-SLM FS59RCAUS (Nickel) RG59RCAUS (Gold) RG59 RCA, Universal Splice (Red) LMTIP-WP CPLCCT-SLM FS59BNCUS (Nickel) RG59BNCUS (Gold) RG59 BNC, Universal Splice (Red) NONE CPLCCT-SLM FS6US (Nickel) RG6US (Gold) RG6 F-type, Universal Splice (Green) LMTIP-WP CPLCCT-SLM FS6RCAUS (Nickel) RG6RCAUS (Gold) RG6 RCA, Universal Splice Connector (Green) LMTIP-WP CPLCCT-SLM FS6BNCUS (Nickel) RG6BNCUS (Gold) RG6 BNC, Universal Splice Connector (Green) NONE CPLCCT-SLM Double Bubble™ Compression Connectors INDUSTRY USE: SECURITY BROADCAST CATV SATELLITE LAW ENFORCEMENT COMMERCIAL • Double Bubble™ compression connectors are designed for structured wiring, security cameras and other exposed wiring installations • F, RCA and BNC for RG59 and RG6 cables • BNC and RCA connectors for RGB/ mini coax cables CPLCRBC Double Bubble™ Compression Connectors FS59US (Nickel) RG59US (Gold) PS59/6/RGB Double Bubble Compression Connectors Part# Connector Description Tip Req’d Tool Req’d DB1RCA RGB/ Mini Coax (25-26AWG) RCA (Orange) LMTIP-S CPLCRBC-B DB1BNC RGB/ Mini Coax (25-26AWG) BNC (Orange) NONE CPLCRBC-B DB15RCA RGB/ Mini Coax (22-24AWG) RCA (Purple) LMTIP-S CPLCRBC-B DB59U RG59 F-type Double Bubble™ connector LMTIP-S CPLCRBC-B DB59RCAU RG59 RCA Double Bubble™ connector LMTIP-S CPLCRBC-B DB59BNCU RG59 BNC Double Bubble™ connector NONE CPLCRBC-B DB6U RG6 F-type Double Bubble™ connector LMTIP-S CPLCRBC-B DB6RCAU RG6 RCA Double Bubble™ connector LMTIP-S CPLCRBC-B NOTE: All cable for Belden compression connectors should be sized using the Belden Cable Sizing Chart located on pages 40-43 or at www.icmcorp.net/ICM_techinfo.com Call for Tech Support 800.222.2142 13 Double Bubble™ Compression Connectors WWW.ICMCORP.NET Plenum and Security (CCTV) Compression Connectors INDUSTRY USE: SECURITY CATV SATELLITE BROADCAST CPLCRBC • Specially engineered plenum connectors make installations easier • F, RCA and BNC for a variety of RG59 and RG6 cable sizes • Security (SL) connectors are designed for RG59 CCTV coaxial cables with copper braiding and solid copper center conductor in RCA and BNC Part# Connector Description Tip Req’d Tool Req’d DB59RCASL RG59 Security RCA LMTIP-S CPLCRBC-B DB59BNCSL RG59 Security BNC NONE CPLCRBC-B DB59PL2/4 RG59 Plenum Size 2/4 F-type LMTIP-S CPLCRBC-B DB59RCAPL2/3/4 RG59 Plenum Size 2/4 RCA LMTIP-S CPLCRBC-B DB59BNCPL2/4 RG59 Plenum Size 2/4 BNC NONE CPLCRBC-B DB59BNCPL3 RG59 Plenum Size 3 BNC NONE CPLCRBC-B DB6PL2 RG6 Plenum Size 2 F-type LMTIP-S CPLCRBC-B DB6RCAPL2 RG6 Plenum Size 2 RCA LMTIP-S CPLCRBC-B DB6BNCPL2 RG6 Plenum Size 2 BNC NONE CPLCRBC-B NOTE: All cable for Belden compression connectors should be sized using the Belden Cable Sizing Chart located on pages 40-43 or at www.icmcorp.net/ICM_techinfo.com DS3 & DS4 BNC Compression Connectors INDUSTRY USE: SECURITY BROADCAST • The premier solution for high volume, digital signal quality • Designed to fit a variety of DS3 & DS4 cable manufacturers 14 TELEPHONY CPLCRBC Part# Connector Description Tip Req’d Tool Req’d DBDS3BNC BNC for DS3 Cable NONE CPLCRBC-B DBDS4BNC BNC for DS4 Cable NONE CPLCRBC-B DBDS4BNCPL BNC for DS4 Plenum Cable NONE CPLCRBC-B Call for Tech Support 800.222.2142 WWW.ICMCORP.NET ITS BNC Compression Connectors INDUSTRY USE: TOLL ROADS & CAMERAS Belden offers the Intelligent Transportation Systems (ITS) BNC compression connector as the superior connection solution for a broad range of wire-line communications-based information, control and electronic equipment. CPLCRBC-ITS • Designed for Belden 8281 & 8281B cable • DB59BNCSL2-M (male) is a standard BNC connector • DB59BNCSL2-F (female) is a splice BNC connector - compress with LMTIP-WP adapter tip • ITS BNC will fit both stranded and solid ITS cables • Use the FIT-SL2 tool to assist with inserting the connector onto the ITS cable • Use the PS11 Cable Strip tool PS11 Part# Connector Description Tip Req’d Tool Req’d DB59BNCSL2-M RG59 Security Male BNC NONE CPLCRBC-ITS DB59BNCSL2-F RG59 Security Female (Splice) BNC LMTIP-WP CPLCRBC-ITS DB58UHF 50 Ohm Compression Connectors INDUSTRY USE: SECURITY LAW ENFORCEMENT • • • • MOBILE RADIO Mini-UHF Plug One-piece design and non-blind entry 360 compression around cable jacket RBCTIP-UHF adapter tip required - included with connector purchase CPLCRBC Part# Connector Description Tip Req’d Tool Req’d DB58UHF 50 Ohm Connector RBCTIP-UHF CPLCRBC-B Double Bubble™ Compression Connectors Intelligent Transportation Systems Call for Tech Support 800.222.2142 15 WWW.ICMCORP.NET BNC High-Definition Broadcast Connectors BNC High-Definition Broadcast Connectors INDUSTRY USE: SECURITY BROADCAST PRO A/V Designed specifically for Belden Brilliance Broadcast and Professional A/V coaxial cables, HD Brilliance Connectors maximize broadcast signal integrity, quality, performance and durability. Three connector types, each offering varying levels of electrical perofrmance and installation speed. • True 75 Ω performance • Extended BNC head knurl nut design to ease identification and installation • Superior return loss through 4.5 GHz, exceeds SMPTE standards • Excellent holding force exceeds 100 lbs., depending on cable type • Fast installation with 1-piece design CPLCRBC BBCOMT Best: Locking 1-Piece Design • Screw-lock collar provides superior electrical signal performance by creating coaxial alignment between the cable and connector center pin, delivering exceptional return loss performance on the cable • A non-blind entry ensures the center conductor is properly inserted into the center pin, simplifying the installation • Improved insulator materials sustain maximum return loss performance • 1-Piece design eliminates pin, collar and connector as separate components to make the installation faster and more efficient • Internal 360 compression rings provide excellent holding strength and eliminate ingress and egress from the back of the connector Locking 1-Piece Compression Part# 16 Connector Description Tip Req’d Tool Req’d CPLCRBC 1505ABHDL RG59 HD BNC (Red) - Nickel NONE 1506ABHDL RG59 Plenum Size 2/4 HD BNC (Red) - Nickel NONE CPLCRBC 1694ABHDL RG6 HD BNC (Green) - Nickel NONE CPLCRBC 1695ABHDL RG6 Plenum Size 2 HD BNC (Green) - Nickel NONE CPLCRBC 1855ABHDL 22-24AWG HD BNC (Purple) - Nickel NONE CPLCRBC 179DTBHDL 179 Digital Truck HD BNC (Yellow) - Nickel NONE CPLCRBC Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Better: 1-Piece Design 1-Piece Compression Part# Connector Description Tip Req’d Tool Req’d 1505ABHD1 RG59 HD BNC (Red) - Nickel NONE CPLCRBC 1506ABHD1 RG59 Plenum Size 2/4 HD BNC (Red) - Nickel NONE CPLCRBC 1694ABHD1 RG6 HD BNC (Green) - Nickel NONE CPLCRBC 1695ABHD1 RG6 Plenum Size 2 HD BNC (Green) - Nickel NONE CPLCRBC 1855ABHD1 22-24AWG HD BNC (Purple) - Nickel NONE CPLCRBC 1794ABHD1 RG7 HD BNC (White) - Nickel NONE CPLCRBC 179DTBHD1 179 Digital Truck HD BNC (Yellow) - Nickel NONE CPLCRBC Good: 3-Piece Design Traditional pin, collar and connector approach, but designed specifically for Belden cable tolerances for better return loss performance and durability. Compatible with most existing crimp tools and die sets. BNC High-Definition Broadcast Connectors Offers excellent return loss performance, but with a faster, simpler installation, and the benefit of a custom fit with Belden Brilliance cable. Same great 1-piece design features of non-blind entry, compression rings and improved insulator, providing easy and repeatable installation every time. The Belden 1-Piece compression technology is a fast and proven approach to a Belden end-to-end solution. BB3PHCT BB3PST 3-Piece Crimp Part# Connector Description Tip Req’d Tool Req’d 1505ABHD3 RG59 HD BNC (Red) - Nickel NONE BB3PHCT 1506ABHD3 RG59 Plenum Size 2/4 HD BNC (Red) - Nickel NONE BB3PHCT 1694ABHD3 RG6 HD BNC (Green) - Nickel NONE BB3PHCT 1695ABHD3 RG6 Plenum Size 2 HD BNC (Green) - Nickel NONE BB3PHCT 1855ABHD3 22-24AWG HD BNC (Purple) - Nickel NONE BB3PHCT 179DTBHD3 179 Digital Truck HD BNC (Yellow) - Nickel NONE BB3PHCT NOTE: All cable for Belden compression connectors should be sized using the Belden Cable Sizing Chart located on pages 40-43 or at www.icmcorp.net/ICM_techinfo.com Call for Tech Support 800.222.2142 17 WWW.ICMCORP.NET Strain Relief Boots Compression Connector Accessories Strain Relief Boots INDUSTRY USE: SECURITY BROADCAST A/V COMMERCIAL Belden’s strain relief boots provide enhanced strain relief and connector protection for your installation. The boot is an optional cable termination sleeve designed and manufactured to protect the cable’s bend radius so as not to damage the cable and connection caused by wire strain. SLS-59/6 Strain Relief Boots For RG59 and RG6 Coaxial Cable. • Extended design includes three tiers that can be cut to customize for RG59 or RG6 cable diameters • Extended weather resistant boot (black) with enhanced strain relief SLS-RGB* Strain Relief Boots For RGB/ Mini Coaxial Cable. • Made with a weather resistant material to provide superior protection at the base of the connector • Available in four colors, and features an extended boot design to provide enhanced strain relief • Custom fit for F-Conn’s FS and DB series (F, RCA and BNC) RGB/ mini coax compression connectors 18 Call for Tech Support 800.222.2142 *Indicate color when ordering: Yellow, Red, White or Black WWW.ICMCORP.NET RG11 Compression Connectors BROADCAST COMMERCIAL FS11V Standard RG11 F-type FS11PL F-type for plenum cables FS11RA F-type right angle Universal 7/16” nut eliminates extra installation tools • Use the Cable Pro PS11 cable strip tool to prep RG11 connectors • 30% more threads create a secure, weather-tight termination and increased pull-out strength • One-piece design simplifies installation • • • • CPLCCT-SS59/11 PS11 Part# Connector Description Tool Req’d FS11V RG11 75 Ohm F-type Connector CPLCCT-SS59/11 FS11PL RG11 Plenum F-type Connector CPLCCT-SS59/11 FS11RA RG11 Right Angle F-type Connector CPLCCT-SS59/11 RG11 Connector Series INDUSTRY USE: CATV RG11 BNC Compression Connector INDUSTRY USE: CATV BROADCAST A connector this tough requires the strength of the CPLCCT-11BNC tool to create a superior, long-lasting connection. CPLCCT-11BNC Part# Connector Description Tool Req’d FS11BNC RG11 75 Ohm BNC Connector CPLCCT-11BNC Call for Tech Support 800.222.2142 19 WWW.ICMCORP.NET Basic Compression Connector Series Basic Compression Connector Series 20 INDUSTRY USE: CATV • Designed for standard and quad size cables • Option of “O” ring located on the front nut of the connector • Available in F-type and RCA connectors • Compress with the RTC 360 or CPLCRTC tool Part# Connector Description Tool Req’d RG59NR RG59 F-type Connector for Headend Cable RTC 360/ CPLCRTC RG59WR RG59 F-type Connector w/ Internal Sealing Rings for 67% to Quad Shield, Indoor RTC 360/ CPLCRTC RG59WRO RG59 F-type Connector w/ Internal Sealing Rings for 67% to Quad Shield, External O-Ring for Outdoor RTC 360/ CPLCRTC RG59-RCAWR RG59 RCA Connector w/ Internal Sealing Rings RTC 360/ CPLCRTC RG6WR RG6 F-type Connector w/ Internal Sealing Rings for 60% to Tri-Shield, Indoor RTC 360/ CPLCRTC RG6WRO RG6 F-type Connector w/ Internal Sealing Rings for 60% to Tri-Shield, External O-Ring for Outdoor RTC 360/ CPLCRTC RG6-RCAWR RG6 RCA Connector w/ Internal Sealing Rings RTC 360/ CPLCRTC RG6NR RG6 F-type Connector, for Quad Shield, Indoor RTC 360/ CPLCRTC RG6NRO RG6 F-type Connector, for Quad Shield, External ORing for Outdoor RTC 360/ CPLCRTC F11WR RG11 F-type Connector for 60% to Quad Shield, Twist-On No Tool Required F81-RS F81 Splice w/ Round Seizure No Tool Required F81-RS/NW F81 Splice w/ Round Seizure and Nut/Washer No Tool Required Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Cable Pro Cable Strip Tools PSA59/6 Cable Strip Tool • Preps RG59, RG6 and RG58 cable • Adjustable dial locates the perfect setting for cable preparation • Patented cable stop creates a precise 1/4”-1/4” cable preparation each and every time • Integrated side flaring tool for RG6 cable • Includes an extra replacement blade cartridge Part# Description PSA59/6 Preps RG59, RG6 and RG58 cable PSCA59/6 Replacement Cartridge for PSA59/6 tool Cable Strip Tools • Lightweight and compact for easy transportation and storage • Integrated rollers ensure the strip tool rolls around the cable to create a clean, even cut • NO screws, keys or other adjustment pieces to manage PS59/6/RGB Cable Strip Tool • Preps RG59, RG6 and RGB/ mini coax cable • Patented cable stop creates a precise 1/4”-1/4” cable preparation every time • Includes TWO extra blade cartridges! (1) Cartridge (PSC-RGB/ red) specifically for RGB/ mini coax cables (1) Cartridge for RG59 and RG6 cables Part# Description PS59/6/RGB Preps RG59, RG6 and RGB/ mini coax cables PSC59/6/RGB Replacement cartridge for PS59/6/RGB tool PSC-RGB Replacement cartridge for PS59/6/RGB tool to prep RGB/ mini coax cables Call for Tech Support 800.222.2142 21 WWW.ICMCORP.NET Cable Strip Tools / Compression Tools PS11 Cable Strip Tool • Preps RG11 cable • Heavy-duty spring provides resistance against every day wear and tear • Patented cable stop creates a precise 1/4”-1/4” cable preparation every time • Includes an extra replacement blade cartridge Part# Description PS11 Preps RG11 cables PSC11 Replacement cartridge for PS11 tool to prep RG11 cable Cable Pro Compression Tools Belden uses the finest materials and metals available on the market to manufacture superior quality custom installation compression tools and connectors providing exceptional solutions for professional installers. RTC 360 Compression Tool INDUSTRY USE: CATV COMMERCIAL The RTC 360 continues to provide professional installers with an exceptional product and connection they can depend on. • Compress with F-Conn’s Basic Series Connectors • Made in the USA • 1-year warranty 22 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET CPLCRTC-B Compression Tool COMMERCIAL • Smaller, economical version of the RTC 360 tool • Manufactured of 4100 series aircraft grade Chromoly alloy for maximum strength and durability • Tool body is over molded with an ergonomic, hard plastic shell to ensure a comfortable grip and easy compression • Fixed compression dies inside the head of the tool allow for an easy, consistant compression • Compress with F-Conn’s Basic Series of F and RCA • Made in the USA • 1-year warranty Compression Tools INDUSTRY USE: CATV CPLCRBC-B Double Bubble™ Compression Tool INDUSTRY USE: SECURITY BROADCAST CATV COMMERCIAL • A perfect solution for structured wiring, security cameras, satellite and other exposed wiring installations • Manufactured of 4100 series aircraft grade Chromoly alloy • Compress with F-Conn’s DB™ Connector Series • Available in F, RCA and BNC • Creates a secure, permanent “double bubble” connection with the DB™ connector • Self-adjusting plunger head provides a precise and constant compression each and every time • Includes 1 interchangeable adapter tip for compression of F and RCA type connectors • Made in the USA • 1-year warranty Part# Description CPLCRBC-B Double Bubble™ Compression Tool - Blue LMTIP-S Silver adapter tip for F-Conn’s silver/nickel connectors RBCTIP-UHF Adapter tip for F-Conn’s 50 Ohm connectors Call for Tech Support 800.222.2142 23 WWW.ICMCORP.NET Compression Tools CPLCCT-SLM Linear Compliant Compression Tool INDUSTRY USE: PRO A/V SECURITY CATV COMMERCIAL • Manufactured of solid steel for maximum strength and durability • Crafted so that it is lightweight and easy to use • Self-adjusting plunger head provides a precise and constant compression each and every time • Includes four interchangeable adapter tips to compress a full line of connectors • Compress with F-Conn’s FS and RG Series Connectors • Made in the USA • 1-year warranty Part# Description CPLCCT-SLM Linear Complaint Compression Tool LMTIP-S Silver adapter tip for F-Conn’s silver/nickel connectors LMTIP-G Gold adapter tip for F-Conn’s gold connectors LMTIP-WP Wall Plate adapter tip for F-Conn’s splice connectors LMTIP-RA Right Angle adapter tip for F-Conn’s right angle connectors LMTIP-HOLDER Holder for adapter tips LMTIP-KIT Kit includes Holder + 5 tips - G, S, RA, WP, IEC CPLCCT-1-S Compression Tool INDUSTRY USE: CATV • For FS Series F-type and RCA compression connectors • No adjustment for compression! • Crafted so that it is lightweight and easy to use • Self-adjusting plunger head provides a precise and constant compression each and every time • Made in the USA • 1-year warranty 24 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET CPLCCT-SS59/11 Compression Tool • Compress connectors for FS Series RG59, RG6, RG7 and RG11 cables with an easy flip of the die • Compress the F-Conn RG11 right angle connector • Compatible with other brands of compression connectors • Made in the USA • 1-year warranty Compression Tools INDUSTRY USE: CATV CPLCCT-11BNC Specialty Compression Tool INDUSTRY USE: CATV • Compresses the FS11BNC, RG11 BNC-type connector • No adjustments required! • Self-adjusting plunger head provides a precise and constant compression • Made in the USA • 1-year warranty CPLCRBC-ITS Specialty Compression Tool INDUSTRY USE: TOLL ROAD SECURITY • Designed specifically for the Double Bubble™ ITS BNC male & female connector • Designed for Belden 8281 & 8281B cable • Use the LMTIP-WP adapter tip for the DB59BNCSL2-F (female) splice ITS connector • Made in the USA • 1-year warranty Call for Tech Support 800.222.2142 25 WWW.ICMCORP.NET Specialty Telephone Tools CPCAT5-PDT Punch Down Tool INDUSTRY USE: TELEPHONE • Punch Down tool is designed for the termination of telephone wire on 66 and 110 style of terminating blocks • Includes a storage compartment to place spare bits • Blades are made of hardened SNCM-21 element, are inter-changeable and reversible • Includes 66 and 110 termination bits and are easily interchangeable • Adjustable high/ low impact setting accommodates termination requirements CPRJ11-45 Strip/Crimp Tool INDUSTRY USE: TELEPHONE • • • • DATA Termination of RJ11 & RJ45 Short stop creates 1/4" cable prep Long stop creates 1/2" cable prep Cut, Strip and Crimp, without changing tools or die sets • Easy to use without compromising the quality of the connection • Comfortable grip handles 26 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Compression Connector and Tool Kits STARTERKIT Starter Kits Belden is recognized worldwide for our innovative line of 360º compression connectors, tools and accessories that work together as a complete system. The Belden Starter Kit contains Cable Pro CPLCCT-SLM compression tool, PS59/6/RGB cable strip tool, and a variety of F-Conn compression connectors to create a high-quality, custom AV installation. STARTERKIT INCLUDES: • CPLCCT-SLM Compression Tool • PS59/6/RGB Cable Strip Tool • PSC59/6/RGB (Blue Spare Cartridge) • PSC-RGB (Red Spare Cartridge) • Wall Plate Inserts & Color Bands • FS59U (10) • FS59BNCU (5) • FS6U (10) • FS6BNCU (5) • FS6RCAU (5) • • • • • • • • • FS6URA FSBNC6URA FSRCA6URA FS6US FS6RCAUS FS1RCA FS1BNC FS15RCA FS15BNC (5) (5) (5) (5) (5) (5) (5) (5) (5) DBSTARTERKIT The Belden DB Starter Kit contains a Cable Pro CPLCRBC-B compression tool, PSA59/6 cable strip tool, and a variety of DB compression connectors to create a secure connection for structured wiring, security and satellite installations. DBSTARTERKIT INCLUDES: • • • • • CPLCRBC-B Compression Tool PSA59/6 Cable Strip Tool FIT-59 Flaring/ Insertion Tool DB59U (25) DB59BNCU (10) • • • • DB59RCAU DB59BNCSL DB6U DB6BNCU (10) (10) (25) (10) Call for Tech Support 800.222.2142 27 WWW.ICMCORP.NET Tech Express Kits Cable Pro Tech Express Tool Kits Belden continues to expand our product line to ensure professional installers have the tools they need to create a permanent, quality installation. SLMPSAKIT Tech Express Tool Kit • CPLCCT-SLM Compression Tool and adapter tips • PSA59/6 Cable Strip Tool and extra blade cartridge • These tools work together as a complete integrated system with F-Conn’s FS and RG series of compression connectors DBPSAKIT Tech Express Tool Kit • CPLCRBC-B Compression Tool and adapter tips • PSA59/6 Cable Strip Tool and extra blade cartridge • These tools work together as a complete integrated system with F-Conn’s DB series of compression connectors 28 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET NEW Belden HDMI Cables • Belden High-Speed HDMI Cables with Ethernet are HDMI version 1.4a • High-Speed HDMI Cables are UL/ CUL CMG/ FT4 listed • High-Speed HDMI Cables achieve speeds of 340 MHz or up to 10.2 Gbps for superior performance • Supports standard and high speed applications to create bold, bright colors, crystal-clear picture and intense, high-resolution sound HDMI Cables Belden strives to provide our customers with the most innovative products. The home theater market is constantly evolving with new advancements in technology. Choosing the right HDMI cable is important when creating the ultimate home theater experience. • Supports 3D gaming and other 3D video applications • Transmits digital content at extremely high resolution (4K) • Physical properties include nickel plated contacts and flexible black PVC outer jacket • Automatic format adjustment and backward compatibility for seamless integration with most electronic devices High-Speed HDMI® Cables with Ethernet and 3D Capabilities** Part# Description BJH2E3 3Ft. High-Speed HDMI Cables with Ethernet and 3D Capabilties BJH2E6 6Ft. High-Speed HDMI Cables with Ethernet and 3D Capabilties BJH2E10 10Ft. High-Speed HDMI Cables with Ethernet and 3D Capabilties BJH2E12 12Ft. High-Speed HDMI Cables with Ethernet and 3D Capabilties Basic through Pro Series HDMI Cables Part# Description H-H*M Basic Series HDMI to HDMI Cable - * Meter HDMI-HOME-*M HDMI M to M Home Series - * Meter, V1.3B Certified w/ 15 Micron Gold Plating, CL3 Rated, 28 AWG HDMI-PRO-*M HDMI M to M PRO Series - * Meter, V1.3B Certified w/ 15 Micron Gold Plating, CL3 Rated, 26 AWG H-HB10M HDMI M to M Home Series 10 Meter, V1.3B Certified H-HB15M HDMI M to M Home Series 15 Meter, V1.3B Certified *M = Available in 1M, 2M, 4M, 6M lengths ** Limited quantities are available. Call to confirm stock prior to ordering. Call for Tech Support 800.222.2142 29 WWW.ICMCORP.NET Cable Caddies Cable Pro Cable Caddies Belden Cable Pro Cable Caddies are engineered using high quality, lightweight steel tubing and incorporates a unique folding mechanism. This allows professional installers to easily fold and transport the caddie to each cable installation location. Wheeled versions of the cable caddie are available to make moving from each location a breeze. CC2016B & CC2016BW Cable Caddie: • • • • • • • Holds one 20” x 16” reel Compact unit Made of sturdy 3/4” tubing CC2016B does not include wheels CC2016BW features 6” wheels Holds up to 100 lbs. Made in the USA CC2024 Cable Caddie: • • • • • Holds one 20” x 24” reel Made of Sturdy 1” tubing Features 6” wheels for easy movement Holds up to 100 lbs. Made in the USA CC2036D Cable Caddie: • • • • • • 30 Holds a variety of reel combinations Adjustable bar heights Two simplified ways to load reels Made of Sturdy 1” tubing Holds up to 100 lbs. per reel Made in the USA Call for Tech Support 800.222.2142 CC2016BW WWW.ICMCORP.NET Torque Wrenches INDUSTRY USE: CATV SATELLITE • “Speed” head for quick tightening without having to remove the wrench from the connector • Use to tighten 7/16" F-type fittings • Torque inch/pounds preset at factory (10-60 in./lbs.) • Medium carbon steel (heat treated) with black oxide finish • Blue cushioned grip • Made in the USA Torque Wrenches TROE716SH Speed Head Torque Wrench TROE716 / TROE916 True Torque Open End Torque Wrench INDUSTRY USE: CATV SATELLITE • Available in 7/16" or 9/16" configuration for F-fittings • Manufactured using chromemoly, a high-quality metal to provide installers with a durable, quality tool • Ergonomically designed to have a True Torque Grip giving you total control and precision when used • Torque inch/pounds are preset at the factory based on your specifications from 10-60 in./lbs • Made in the USA Call for Tech Support 800.222.2142 31 WWW.ICMCORP.NET Torque Wrenches / Installation Tools TROE716E Easy Open End Torque Wrench INDUSTRY USE: CATV SATELLITE • Available in 7/16” configuration for F-fittings • Coated with black oxide to offer the ultimate protection against daily wear and tear • A soft, blue, rubber grip provides a smooth gripping surface • Torque inch/pounds are preset at the factory based on your specifications from 10-60 in./lbs • Made in the USA Cable Pro Installation Tools Belden manufactures a full line of high-quality Cable Pro installation tools for the professional installer. Made in the USA. Trap Wrench • Made of lightweight 6061 aluminum • 2 steel pins, press fitted into the aluminum tube, to remove traps • Anodized for superior protection and easy identification • Fits 7/16" hex F-fittings • Knurled hand grips assure controlled handling • Made in the USA 32 Part# Description TW716 Trap Wrench - Red TWS716 Super Trap Wrench - Black Hex Head is made of hardened steel Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Trap Wrench - Red TWS716 Super Trap Wrench - Black Hex Head is made of hardened steel TWC716 Combo Trap Wrench - Blue For Metal Security Sleeves Combines standard trap wrench design with a security sleeve Security socket is made of hardened steel TWC716-EX Combo Trap Wrench - Blue For Plastic Security Sleeves Combines standard trap wrench design with a security sleeve Security socket is made of hardened steel Installation Tools TW716 Can Wrench • Used to open pedestals and tighten ground straps and taps • Made in the USA Part# Description CNW6 Can Wrench (3/8” & 7/16”) CNW8 Can Wrench (1/2” & 9/16”) Swivel 7/16” Torque Wrench • Use to torque 7/16” F-type fittings • Designed to work with multi-part taps • All torque wrenches are preset in the factory to desired torque in./lbs. • Made in the USA Part# Description TRS716-* 7/16” Torque Wrench TRS716SS-EX-* 7/16” Torque Wrench removes plastic sleeves TRS716SS-* 7/16” Torque Wrench removes metal sleeves Call for Tech Support 800.222.2142 33 WWW.ICMCORP.NET Installation Tools Fixed/Swivel 3/8” Socket Drive Torque Wrench • Ability to use different size sockets • All torque wrenches are preset in factory to desired torque in./lbs. • Made in the USA Part# Description TRFE3/8-* Fixed 3/8” Socket Drive Torque Wrench TRS3/8 Swivel 3/8” Socket Drive Torque Wrench Headend Extended Socket Wrench • Use in headend or behind rack for installation and removal of 7/16” F-type or BNC fittings • Socket extends 8” from handle with (1) 1/4” socket • Made in the USA Part# Description HT-716 Headend Extended F Connector Socket HT-BNC Headend Extended BNC Connector Socket Security Wrench • Made of chrome 4130 steel • All include steel spring handle and tightens to 40 in./lbs. • Made in the USA 34 Part# Description SWU716 Universal Security Wrench for metal sleeves SWU716-EX Thick Wall Security Sleeve for plastic sleeves DSW716 Dual Security Wrench combines 7/16” and 1/2” socket 7/16” socket fits standard F-type fittings 1/2” socket fits LRC seal nut and Gilbert TAC fittings SW-SACHS Sach Security Wrench MSW716 Mini Security Wrench Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Gilbert Terminating Tool Part# Description GTT-4 4” Gilbert Terminating Tool GTT-7 7” Gilbert Terminating Tool Installation Tools • Use with theft proof Gilbert GTP Locking Terminators • Features solid steel spring ears • Available in two lengths: 4” and 7” • Made in the USA Telephone Tool • Tool has a 5/32” hex end to open telephone pedestals and boxes • Made in the USA Part# Description 532HEX Telephone Tool Viewsonics Terminating Tool • Use with Viewsonics Locking Terminators • Available in two lengths: 4” and 7” • Tools are made of zinc plated steel • Made in the USA Part# Description VTT-4 4” ViewsonicsTerminating Tool VTT-7 7” Viewsonics Terminating Tool Call for Tech Support 800.222.2142 35 WWW.ICMCORP.NET Installation Tools Siamese Stripper • Siamese strippers separate RG59 and RG6 wisted pair cable, coaxial siamese cable and messenger coaxial cable • Made in the USA Part# Description SS596 RG59 and RG6 Siamese Cable Separator Installation Tool • Tools speed the installation and the removal of drop cable • Available in 7/16” and 9/16” sizes • Made from 6061 aluminum and features knurled surfaces, a cable slot, and a hard anodized finish • Made in the USA Part# Description IT716 7/16” Installation Tool IT916 9/16” Installation Tool Pen Toner Continuity Testers • Female or right angle male push-on connector • Loud audio tone identifies the line carrying signal • Battery inlcuded 36 Part# Description CPPT-1 Pen Toner Call for Tech Support 800.222.2142 WWW.ICMCORP.NET Part# Description TS-18 Toner Set (Buzz Box and Battery Box) Installation Tools Toner Boxes Continuity Testers • Toner boxes feature loud audio signal • LED display detects splitters and shorts in drops • Two 9-volt betteries (18 volts) allow for testing longer drops Flaring and Insertion Tool • Flaring expands jacket to ease the insertion of connectors on to Plenum, Quad and standard size cables in cold weather - Specify size and part# • Insertion simplifies pushing the connector on to the cable • Made in the USA Part# Description FIT-6 Flaring/ Insertion Tool for RG6 Cable FIT-59 Flaring/ Insertion Tool for RG59 Cable FIT-11 Flaring/ Insertion Tool for RG11 Cable FIT-SL2 Flaring/ Insertion Tool for DB59BNSL-2 Connectors Call for Tech Support 800.222.2142 37 Splitters WWW.ICMCORP.NET HIP Video Splitters INDUSTRY USE: CATV SATELLITE SECURITY A/V • • • • 1 GHz and 3 GHz product offerings Horizontal and Vertical configurations • 2, 3, & 4 port horizontal • 2, 3, 4, 6, & 8 port vertical >-120 dB RFI Shielding Die-cast housing with built-in mounting tabs and integrated grounding lug • High port to port isolation • Excellent insertion loss performance 1 GHz Product • 5 MHz - 1,000 MHz • Digital or Analog RF Signal Transmission • CATV, Antenna, A/V or Security Applications 3 GHz Product - Satellite • 5 MHz - 3,000 MHz • Digital Satellite RF Signal Transmission • PC Power Passing on 1 port 38 Passives HV Horizontal Series 1GHz HV Series Vertical 1GHz Satellite Horizontal Series 3 GHz Satellite Vertical Series 3 GHz 2 Way HIP 2H HIP 2V HIP-S2 H HIP-S2 V 3 Way HIP 3H HIP 3V HIP-S3 H HIP-S3 V 4 Way HIP 4H HIP 4V HIP-S4 H HIP-S4 V 6 Way HIP 6V HIP-S6 V 8 Way HIP 8V HIP-S8 V Call for Tech Support 800.222.2142 WWW.ICMCORP.NET CableReady Molding System CABLEREADY is an industry leader in developing innovative solutions to the challenges that installers must face when working with cable molding. CABLEREADY molding is available in straight run, transitions, right angles, tee fittings, and much more to ensure a professional solution to any installation. Our molding is made of 26 gauge Galvalume steel. Galvalume lasts longer and is more durable than G90 hot dipped galvanized steel or plastic molding systems. All CABLEREADY molding products can be used for indoor and outdoor applications. In the past, system operators, installers and apartment owners have settled for plastic moldings that were difficult to install, re-enter and re-install with an effective product life of only two to three years. Users have had to put up with plastic moldings that would crack, shift, discolor, warp and literally fall off the walls of buildings. CableReady® Cable Molding Products CABLEREADY® offers a series of protective molding developed to meet the needs of the cabling industry. All CABLEREADY products are guaranteed against cracking, peeling, or fading, due to ultraviolet rays or harsh weather conditions for 15 years. Made in the USA. CABLEREADY’s unique molding holds patent numbers: 5,523,529 and 5,732,747 and 6,437,247 Call for Tech Support 800.222.2142 39 WWW.ICMCORP.NET Connector Sizing Chart F-Conn Compression Connector Sizing Chart (Inches) Type RG1 (24-26AWG*) ORANGE RG15 (22-24AWG*) PURPLE Basic Series Description Size Double Bubble Center Conductor Dielectric Outer Jacket MIN-MAX .015-.025 .065-.078 .095-.110 DB1RCA Center Conductor Dielectric Outer Jacket MIN-MAX .015-.025 .095-.105 .145-.160 DB15RCA *This AWG is a reference point only please make sure you spec the cable to ensure proper fit. RG59 PLENUM RED RG59 PLENUM 2 RED RG59 PLENUM 3 RED RG59 PLENUM 4 RED RG59 SECURITY RED RG59 STANDARD RED RG59 QUAD RED RG59 UNIVERSAL RED Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .147-.157 .190-.220 Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .130-.137 .190-.220 DB59PL2/4 DB59BNCPL2/4 DB59RCAPL2/4 Center Conductor Dielectric Outer Jacket MIN-MAX .0210-.0240 .130-.137 .190-.220 DB59PL2/4 DB59BNCPL3 DB59RCAPL3 Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .134-.141 .190-.220 DB59PL2/4 DB59BNCPL2/4 DB59RCAPL2/4 Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .137-.148 .232-.248 DB59BNCSL DB59RCASL Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .144-.157 .232-.252 RG59WR RG59WRO RG59-RCAWR Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .144-.157 .257-.273 RG59NR Center Conductor Dielectric Outer Jacket MIN-MAX .0317-.0339 .144-.157 .232-.273 Connector/ Cable Cross Reference Chart available at www.icmcorp.net 40 *Actual cable sizes may Call for Tech Support 800.222.2142 DB59U DB59BNCU DB59RCAU WWW.ICMCORP.NET vary from manufacturer specifications and testing may be required to verify correct connector fit. Gold Series Commercial Splice/Insert Gold Splice/Insert FSRCA1RGB FSBNC1RGB FS1RCA FS1BNC RGRCA1RGB RGBNC1RGB RG1RCA RG1BNC FS1RCASST FS1BNCSST RG1RCASST RG1BNCSST FSRCA15RGB FSBNC15RGB FS15RCA FS15BNC RGRCA15RGB RGBNC15RGB RG15RCA RG15BNC FS15RCASST FS15BNCSST RG15RCASST RG15BNCSST RG59U RG59BNCU RG59RCAU RG59IECUM RG59IECUF FS59US FS59BNCUS FS59RCAUS RG59US RG59BNCUS RG59RCAUS FS59PL FS59BNCPL FS59RCAPL Connector Sizing Chart Commercial Series FS59PL2 FS59BNCPL2 FS59RCAPL2 FS59PL2 FS59BNCPL3 FS59RCAPL3 FS59PL4 FS59BNCPL4 FS59RCAPL4 FS59BNCSL FS59U FS59BNCU FS59RCAU FS59URA FSBNC59URA FSRCA59URA FS59IECUM FS59IECUF Call for Tech Support 800.222.2142 41 WWW.ICMCORP.NET F-Conn Compression Connector Sizing Chart (Inches) Connector Sizing Chart Type RG59/ MINI CENTER CONDUCTOR RG59 ITS CONNECTOR RG6 PLENUM GREEN RG6 PLENUM 2 GREEN RG6 STANDARD GREEN RG6 QUAD GREEN RG6 UNIVERSAL GREEN RG11 UNIVERSAL BLACK RG11 PLENUM GRAY DS3 CONNECTOR DS4 CONNECTOR 42 Size Center Conductor Dielectric Outer Jacket MIN-MAX .021-.024 .144-.157 .232-.273 DB59BNCBU Center Conductor Dielectric Outer Jacket MIN-MAX .024-.034 .190-.200 .295-.305 DB59SL2-M DB59SL2-F Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .183-.193 .220-.250 Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .165-.172 .220-.250 Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .180-.193 .265-.286 RG6WR RG6WRO RG6-RCAWR Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .180-.193 .289-.305 RG6NR RG6NRO Center Conductor Dielectric Outer Jacket MIN-MAX .0399-.0418 .180-.193 .265-.305 Center Conductor Dielectric Outer Jacket MIN-MAX .0634-.0647 .280-.294 .390-.417 Center Conductor Dielectric Outer Jacket MIN-MAX .0634-.0647 .280-.294 .339-.355 Center Conductor Dielectric Outer Jacket MIN-MAX .014-.020 .070-.085 .120-.140 DBDS3BNC Center Conductor Dielectric Outer Jacket MIN-MAX .317-.0339 .145-.155 .220-.240 DBDS4BNC Call for Tech Support 800.222.2142 Basic Series *Actual cable s Description Double Bubble DB6PL2 DB6BNCPL2 DB6RCAPL2 DB6U DB6BNCU DB6RCAU F11WR WWW.ICMCORP.NET sizes may vary from manufacturer specifications and testing may be required to verify correct connector fit. Gold Series Commercial Splice/Insert Gold Splice/Insert FS6U FS6BNCU FS6RCAU FS6IECUM FS6IECUF FS6US FS6BNCUS FS6RCAUS RG6US RG6BNCUS RG6RCAUS FS6PL FS6BNCPL FS6RCAPL FS6PL2 FS6BNCPL2 DB6RCAPL2 FS6U FS6BNCU FS6RCAU FS6URA FSBNC6URA FSRCA6URA FS6IECUM FS6IECUF Connector Sizing Chart Commercial Series FS11V FS11BNC FS11PL Call for Tech Support 800.222.2142 43 6260 Downing Street Denver, Colorado USA 80216 800.222.2142 303.288.4769 (fax) www.icmcorp.net sales@icmcorp.net To view our full line of Enterprise Solutions and Cables please visit www.belden.com Belden Product Families This publication contains the most current products and specifications as of this printing. Items may be added, deleted, discontinued, or revised without notice. Please contact Belden to verify product specifications and availability. 07012011
DB59BNCSL2-F 价格&库存
很抱歉,暂时无法提供与“DB59BNCSL2-F”相匹配的价格&库存,您可以联系我们找货
