1031A 0061000
1031A 0061000
    BELDEN
    CBL 3COND 16AWG SHLD
1031A 0061000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1031A Triad - 300V Power-Limited Tray Cable For more Information please call 1-800-Belden1 General Description: 16 AWG triads stranded (7x24) bare copper conductors, twisted triads, overall Beldfoil shield (100% coverage), PVC insulation, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors # Triads AWG Stranding Conductor Material 1 1 16 7x24 BC - Bare Copper Total Number of Conductors: 3 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.016 Inner Shield Inner Shield Color Code Chart: Number Color 1 Black & Red & White and Numbered Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 18 7x26 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.037 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.285 in. Pair Pair Lay Length & Direction: Twists (twist/ft) 6 Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 58.300 lbs/1000 ft. Max. Recommended Pulling Tension: 61 lbs. Min. Bend Radius/Minor Axis: 1.140 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG, ITC-ER, PLTC-ER CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1031A Triad - 300V Power-Limited Tray Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Burial: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .156 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 54.1 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 97.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.7 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.9 Max. Operating Voltage - UL: Voltage 300 V RMS Notes (Overall) Notes: Alternate color coding available upon request. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1031A 0061000 1,000 FT 60.000 LB BLUE, LIGHT C 3 #16 PVC FS PVC 1031A 00610000 10,000 FT 600.000 LB BLUE, LIGHT C TRANSFER REVIEW (20 TO 30) 1031A 0101000 1,000 FT 58.000 LB BLACK C 3 #16 PVC FS PVC 1031A 01010000 10,000 FT 600.000 LB BLACK CZ 3 #16 PVC FS PVC 1031A 0105000 5,000 FT 295.000 LB BLACK CZ 3 #16 PVC FS PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 3 Revision Date: 03-15-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1031A Triad - 300V Power-Limited Tray Cable All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1031A 0061000 价格&库存
很抱歉,暂时无法提供与“1031A 0061000”相匹配的价格&库存,您可以联系我们找货
