10GXS12006A1000
10GXS12006A1000
    BELDEN
    CAT6A 4PR U/UTP CMR RIB
10GXS12006A1000 数据手册
Product: 10GXS12 10GXS Category 6A Enhanced Cable, 4 Pair, U/UTP, CMR Product Description 10GXS Category 6A Enhanced Premise Horizontal Cable (625MHz), 4 Pair, 23 AWG Solid Bare Copper Conductors, U/UTP, Riser-CMR, PVC Jacket Technical Specifications Product Overview Suitable Applications: Premise Horizontal Cable, Ethernet up to 10GBASE-T, Wi-Fi 6, Wi-Fi 5, PoE++, PoE+, PoE, Noisy Environments, Data Center EoR and MoR, Network Backbone, HDBaseT, HDBaseT 4K UHD Patent: This product has one or more applicable patents. More information on patents can be found at https://www.belden.com/resources/patents. Construction Details Conductor Size Stranding 23 AWG Solid Material Number of Pairs BC - Bare Copper 4 Insulation Material Color Code PO - Polyolefin White & Blue, White & Orange, White & Green, White & Brown Outer Shield Shield Type Tape Outer Jacket Separator Material Nom. Diameter Ripcord Center Member (Patented EquiSpline®), EquiBlock™ Barrier Technology PVC - Polyvinyl Chloride 0.275 in (6.99 mm) Yes Overall Cable Diameter (Nominal): 0.275 in (6.99 mm) Electrical Characteristics Electricals Max. Conductor DCR Max. Capacitance Unbalance 82 Ohm/km 45 pF/100m Delay Frequency 100 MHz Max. Delay Max. Delay Skew Nom. Velocity of Prop. Typical Delay Skew 537.6 ns/100m 45 ns/100m 65% 30 ns/100m High Frequency Frequency [MHz] Max. Insertion Loss (Attenuation) Min. PSNEXT [dB] Min. PSACR [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Max./Min. Input Impedance (unFitted) Max./Min. Fitted Impedance Min. PSANEXT [dB] Min. PSAACRF [dB] Min. TCL [dB] Min. ELTCTL [dB] 1 2.1 dB/100m 75.3 73.2 74.8 20.0 100 ± 15 Ohm 105 ± 10 Ohm 75.0 77.0 40.0 35.0 4 3.8 dB/100m 66.3 62.5 62.8 23.0 100 ± 15 Ohm 100 ± 15 Ohm 75.0 76.2 40.0 23.0 8 5.3 dB/100m 61.8 56.5 56.7 24.5 100 ± 15 Ohm 100 ± 15 Ohm 75.0 70.1 40.0 16.9 10 5.9 dB/100m 60.3 54.4 54.8 25.0 100 ± 15 Ohm 100 ± 15 Ohm 75.0 68.2 40.0 15.0 16 7.4 dB/100m 57.2 49.8 50.7 25.0 100 ± 15 Ohm 100 ± 15 Ohm 75.0 64.1 38.0 10.9 20 8.3 dB/100m 55.8 47.5 48.8 25.0 100 ± 15 Ohm 100 ± 15 Ohm 75.0 62.2 37.0 9.0 25 9.3 dB/100m 54.3 45.0 46.8 24.3 100 ± 15 Ohm 100 ± 15 Ohm 75.0 60.2 36.0 7.0 31.25 10.4 dB/100m 52.9 42.5 44.9 23.6 100 ± 15 Ohm 100 ± 10 Ohm 75.0 58.3 35.1 5.1 62.5 14.8 dB/100m 48.4 33.6 38.9 21.5 100 ± 15 Ohm 100 ± 10 Ohm 73.6 52.3 32.0 100 18.9 dB/100m 45.3 26.4 34.8 20.1 100 ± 15 Ohm 100 ± 10 Ohm 70.5 48.2 30.0 200 27.0 dB/100m 40.8 13.8 28.8 18.0 100 ± 22 Ohm 100 ± 10 Ohm 66.0 42.2 27.0 250 30.4 dB/100m 39.3 9.0 26.8 17.3 100 ± 32 Ohm 100 ± 10 Ohm 64.5 40.2 26.0 300 33.5 dB/100m 38.1 4.6 25.3 16.8 100 ± 32 Ohm 100 ± 10 Ohm 63.3 38.7 25.2 350 36.3 dB/100m 37.1 0.8 23.9 16.3 100 ± 32 Ohm 100 ± 10 Ohm 62.3 37.3 24.6 400 39.0 dB/100m 36.3 22.8 15.9 100 ± 32 Ohm 100 ± 10 Ohm 61.5 36.2 24.0 450 41.5 dB/100m 35.5 21.7 15.5 100 ± 32 Ohm 100 ± 10 Ohm 60.7 35.1 23.5 500 43.9 dB/100m 34.8 20.8 15.2 100 ± 32 Ohm 100 ± 10 Ohm 60.0 34.2 23.0 550 46.2 dB/100m 33.2 20.0 14.9 100 ± 32 Ohm 100 ± 10 Ohm 59.4 33.4 600 48.4 dB/100m 32.6 19.2 14.7 100 ± 32 Ohm 100 ± 10 Ohm 58.8 32.6 625 49.5 dB/100m 32.4 18.9 14.5 100 ± 32 Ohm 100 ± 10 Ohm 58.6 32.3 750 54.7 dB/100m 32.2 17.3 14.0 57.4 30.7 860 58.9 dB/100m 31.3 16.1 13.6 56.5 29.5 Voltage UL Voltage Rating 300 V (CMR), 300 V (CL3R) Mechanical Characteristics Temperature UL Temperature 90°C Operating Installation Storage -20°C To +75°C 0°C To +50°C -20°C To +75°C Bend Radius Stationary Min. Installation Min. 1.25 in (31.8 mm) 2.75 in (69.9 mm) Max. Pull Tension: 25 lbs (11 kg) Bulk Cable Weight: 35 lbs/1000ft Standards and Compliance Environmental Suitability: Riser, Indoor Sustainability: Product Lens™, Environmental Product Declaration (EPD) Available Flammability / Reaction to UL 1666 Riser, FT4, FT4, IEC 60332-1-2 Fire: CPR Compliance: CPR Euroclass: Eca NEC / UL Compliance: Article 800, CMR;CMR-LP (0.6A);CL3R-LP (0.6A) CEC / C(UL) Compliance: CMR ICEA Compliance: S-116-732-2013 IEEE Compliance: IEEE 802.3bt Type 1, Type 2, Type 3, Type 4 NEMA Compliance: ANSI/NEMA WC-66 Data Category: Category 6A TIA/EIA Compliance: ANSI/TIA-568.2-D Category 6A ISO/IEC Compliance: ISO/IEC 11801-1, IEC 61156-5 CENELEC Compliance: Segregation class according EN50174-2 = a European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU (RoHS 2 amendment), REACH, EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE), REACH: 2020-01-16 APAC Compliance: China RoHS II (GB/T 26572-2011) Other Standard Compliance(s): Verified Channel/Category 6A Plenum Number: 10GXS13 Product Notes Notes: History Electrical values are expected performance based on cable testing and representative performance within a typical Belden system. Values above 625 MHz are for Engineering Information Only. Print Includes Descending Footage/Meter Markings from Max. Put-Up Length to 0. Update and Revision: Revision Number: 0.290 Revision Date: 12-15-2021 Variants Item # 10GXS12 0101000 Color Black 10GXS12010A1000 Black 10GXS12 0061000 Putup Type Length UPC Reel 1,000 ft 612825004226 Reel-in-Box 1,000 ft 612825004318 Blue, Light Reel 1,000 ft 612825004189 10GXS12006A1000 Blue, Light Reel-in-Box 1,000 ft 612825004271 10GXS12 0081000 Reel 1,000 ft 612825004202 10GXS12008A1000 Gray Reel-in-Box 1,000 ft 612825004295 10GXS12 0051000 Reel 1,000 ft 612825004172 10GXS12005A1000 Green Reel-in-Box 1,000 ft 612825004264 10GXS12 0031000 Reel 1,000 ft 612825004158 10GXS12003A1000 Orange Reel-in-Box 1,000 ft 612825004240 10GXS12 0071000 Reel 1,000 ft 612825004196 10GXS12007A1000 Purple Reel-in-Box 1,000 ft 612825004288 10GXS12 0021000 Reel 1,000 ft 612825004141 10GXS12002A1000 Red Reel-in-Box 1,000 ft 612825004233 10GXS12 0091000 Reel 1,000 ft 612825004219 10GXS12009A1000 White Reel-in-Box 1,000 ft 612825004301 10GXS12 0041000 Reel 1,000 ft 612825004165 Reel-in-Box 1,000 ft 612825004257 Gray Green Orange Purple Red White Yellow 10GXS12004A1000 Yellow © 2022 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
10GXS12006A1000 价格&库存
很抱歉,暂时无法提供与“10GXS12006A1000”相匹配的价格&库存,您可以联系我们找货
