1505ANH.00305
1505ANH.00305
    BELDEN
    BELDEN - 1505ANH.00305 - Coaxial Cable, Brilliance®, RG59, 20 AWG, 75 ohm, 1000 ft, 304.8 m
1505ANH.00305 数据手册
1505ANH FRNC Precision Video Cable Rev. 2/ 2005-01-05 DRAFT 2/2 Application Precision video cables are used in critical analog and digital video circuits and high quality applications such as live broadcast (HDTV/SDI) in network studios and pre- or post-production facilities. Construction & Dimensions 1 2 3.1 3.2 4 1. Conductor 2. Dielectric 3.1 Foil 3.2 Braid 4. Jacket 1. Inner Conductor Innenleiter - Conduttore Interno – Conducteur – Conductor - Проводник Material solid, bare copper Diameter 0.8 mm (20 AWG) RG Type 59/U 2. Dielectric Dielektrikum – Dielettrico – Diélectrique – Dieléctrico - Диэлектрик Material gas injected HDPE Diameter over insulation 3.68 mm 3. Outer Conductor Aussenleiter - Conduttore Esterno - Conducteur extérieur - Conductor externo - Внешний проводник Material foil + braid Diameter screen 4.5 mm 3.1 Shielding foil Coverage: 3.2 Shielding braid Coverage Duofoil® 100% tinned copper braid 95% 4. Jacket Aussenmantel – Guaina – Gaine – Revestimiento - Оболочка Material FRNC (LSNH) Diameter: 5.92 + 0.2 mm Color and text: see table Marking Requirements and test methods Electrical characteristics Mean characteristic impedance: 75 ± 1.5 Ω Wellenwiderstand - Impedenza Caratteristica Principale - Impédance nominale - Características eléctricas - Электрические характеристики Nominal capacitance conductor to shield: 53 pF/m Kapazitaet - Capacità Nominale Conduttore/Schermo - Capacité nominale entre conducteur et blindage - Capacitancia nominal de conductor a blindaje - Номинальная емкость “проводник-экран” Nominal velocity of propagation: 83% Ausbreitungsgeschwindigkeit - Velocità Nominale di Propagazione - Vitesse de propagation nominale - Velocidad nominal de propagación - Номинальная скорость распространения сигнала Nominal Delay: 4.003 ns/m  Belden Wire & Cable B.V. Netherlands Tel. +31-(0)77-3878-555 - Fax. +31-(0)77-3878-488 - E-mail: Venlo.salesinfo@beldencdt.com All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner. All printing errors are subject to correction. Technical specifications are subject to change without notice. 1505ANH FRNC Precision Video Cable Rev. 2/ 2005-01-05 DRAFT 2/2 Nom. inner conductor DC resistance @ 20 ˚C: 32 Ω/km Gleichstromwiderstand Innenleiter - Resistenza Nominale DC del Conduttore Interno - Résistance du conducteur intérieur - Resistencia CC nominal del conductor interno - Номин. сопротивление пост. тока внутреннего проводника при Nom. outer conductor DC resistance @ 20 ˚C: 12 Ω/km Gleichstromwiderstand Aussenleiter - Resistenza Nominale DC del Conduttore Esterno - Résistance du conducteur extérieur Resistencia CC nominal del conductor externo - Номин. сопротивление пост. тока внутреннего проводника при Return loss at 5- 850 MHz: 851-3000 MHz: ≥ 23 dB ≥ 21 dB Rueckflussdaempfung - Perdite Cumulative di Riflessione - Taux de réflexion du signal - Pérdida de retorno - Обратные потери на Nominal Attenuation: Wellendaempfung - Attenuazione Nominale – Affaiblissement - Atenuación nominal - Номинальное затухание MHz 1 3.58 5 71.5 135 270 dB/100m 0.9 1.9 2.0 6.8 8.8 12.4 Flame Resitance: MHz 360 540 720 1500 2250 3000 dB/100m 14.4 18.0 20.1 30.5 38.0 43.9 CEI 20-22 III (acc. EN50266-2-4,IEC 60332-3-24 cat.C) CEI 20-37/2/5/7 (acc. EN50267-2-1, 50268-2, NES 713) Mechanical and physical characteristics Temperature range - storage/operation Temperature range - installation -30°C to +70°C -5 °C to + 70˚C Minimum bending radius 10x Ø cable Biegeradius - Raggio Minimo di Curvatura - Rayon de courbure minimum - Radio de curvatura mínimo - Минимальный радиус изгиба Nominal cable weight 46.1 kg/km Gewicht - Peso Nominale del Cavo – Poids - Peso nominal del cable - Номинальный вес кабеля Ordering information MARKING Jacket colour Text black BELDEN 1505ANH FRNC CEI 20-22III CEI 20-37/2/5/7 Meter marking: yes, MM-YY: month and year of manufacturing PACKAGING (PUT-UP, +/-2%) 305m reels Each reel is labelled with the following data: Belden Logo, Belden code number, item description, length on the reel and date of manufacturing.  Belden Wire & Cable B.V. Netherlands Tel. +31-(0)77-3878-555 - Fax. +31-(0)77-3878-488 - E-mail: Venlo.salesinfo@beldencdt.com All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner. All printing errors are subject to correction. Technical specifications are subject to change without notice.
1505ANH.00305 价格&库存
很抱歉,暂时无法提供与“1505ANH.00305”相匹配的价格&库存,您可以联系我们找货
