1526A 01010000
1526A 01010000
    BELDEN
    CBL 3COND 20AWG SHLD
1526A 01010000 数据手册
Part Number: 1526A 300V, (1 triad) 20 AWG (7x28) BC, PVC/PVC, Foil Shld, PLTC-ER, CMG Product Description One 20 AWG triad stranded (7x28) bare copper conductors, twisted triads, PVC insulation, overall Beldfoil® shield (100% coverage), PVC Jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 20 7x28 Material No. of Triads BC - Bare Copper 1 Conductor Count: 3 Total Number of Pairs: N/A Total Number of Triads: 1 AWG Size: 20 Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.0175 in Color Chart Number Color 1 Red 2 White 3 Black Color Chart 2 Number 1 Color Black & White & Red Outer Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness Ripcord PVC - Polyvinyl Chloride 0.231 in 0.037 in Yes Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 9.5 Ohm/1000ft 6.5 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Shield 30 pF/ft Inductance Nominal Inductance 55 pF/ft Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 22 7x30 mm 0.19 µH/ft Current Max. Recommended Current [A] 4.8 Amps per conductor @ 25°C Voltage UL Voltage Rating 300V RMS Temperature Range UL Temp Rating: 105°C Operating Temp Range: -30°C To +105°C Mechanical Characteristics Bulk Cable Weight: 32 lbs/1000ft Max Recommended Pulling Tension: 42 lbs Min Bend Radius/Minor Axis: 2.2 in Standards NEC Articles: 800 NEC/(UL) Specification: PLTC-ER, ITC-ER, CMG CEC/C(UL) Specification: CMG UL AWM Style: 2464 Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Burial: Yes Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Sunlight Resistance: Yes Flammability, LS0H, Toxicity Testing C(UL) Flammability: FT4 UL Flammability: UL1685 UL Loading ICEA Flammability: T-29-520 IEEE Flammability: 1202 Part Number Plenum (Y/N): No Variants Item # Color Footnote 1526A 01010000 BLACK C Z Footnote: C - CRATE REEL PUT-UP. Footnote: Z - FINAL PUT-UP MAY VARY (= OR -) 10% FOR SPOOLS OR REELS AND (+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
1526A 01010000 价格&库存
很抱歉,暂时无法提供与“1526A 01010000”相匹配的价格&库存,您可以联系我们找货
