1583A 0021000
1583A 0021000
    BELDEN
    BELDEN  1583A 0021000  UNSHIELDED MULTIPAIR CABLE 4PR 1000FT 300V RED
1583A 0021000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1583A Multi-Conductor - Category 5e Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e (200MHz), 4-Pair, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 24 AWG Solid Bare Copper Conductors, Polyolefin Insulation, Ripcord, PVC Jacket. Usage (Overall) Suitable Applications: Horizontal, 1000BaseT, Gigabit Ethernet, POE, POE+,100BaseTX, Fast Ethernet, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Video, RS-422 Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.190 Outer Jacket Ripcord: Yes Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: 0°C To +60°C Operating Temperature Range: -20°C To +60°C Bulk Cable Weight: 18 lbs/1000 ft. Max. Recommended Pulling Tension: 35 lbs. Min. Bend Radius/Minor Axis: 0.800 in. Min. Bend/Installation: 1.900 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR NEC Articles: 800 Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1583A Multi-Conductor - Category 5e Nonbonded-Pair Cable CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes Other Standards: ISO/IEC 11801 ed 2.1 (2008) Class D EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Other Specification: NEMA WC-63.1 Category 5e Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Riser C(UL) Flame Test: FT4 CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Suitability - Aerial: No Suitability - Burial: No Sunlight Resistance: No Oil Resistance: No Non-halogenated: No Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1583A Multi-Conductor - Category 5e Nonbonded-Pair Cable 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 2.000 65.3 62.3 63.0 60.3 20.000 4 4.100 56.3 53.3 51.0 49.2 23.000 8 5.800 51.8 48.8 46.0 43.0 24.500 10 6.500 50.3 47.3 43.0 40.8 25.000 16 8.200 47.3 44.3 39.0 36.0 25.000 20 9.300 45.8 42.8 36.5 33.5 25.000 25 10.400 44.3 41.3 33.9 30.9 24.300 31.25 11.700 42.9 39.9 31.0 28.2 23.600 62.5 17.000 38.4 35.4 22.0 19.0 21.500 100 22.000 35.3 32.3 14.0 10.3 20.100 155 28.100 32.5 29.5 4.4 1.4 15.800 200 32.400 30.8 27.8 4.0 1.0 15.000 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 63.8 60.8 4 100 ± 15 51.7 48.7 8 100 ± 15 45.7 42.7 10 100 ± 15 43.8 40.8 16 100 ± 15 39.7 36.7 20 100 ± 15 37.7 34.7 25 100 ± 15 35.8 32.8 31.25 100 ± 15 33.9 30.9 62.5 100 ± 15 27.8 24.9 100 100 ± 15 23.8 20.8 155 100 ± 25 19.9 16.9 200 100 ± 25 17.7 14.7 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Third party verified to ANSI/TIA-568-C.2, Category 5e. Values above 100 MHz are for engineering purposes only. Put Ups and Colors: Item # Putup Ship Weight Color 1583A 002U1000 1,000 FT 24.000 LB RED Notes Item Desc 1583A 0021000 1,000 FT 5.000 LB RED 1583A 003U1000 1,000 FT 24.000 LB ORANGE 1583A 0031000 1,000 FT 20.000 LB ORANGE 1583A 004U1000 1,000 FT 24.000 LB YELLOW 1583A 0041000 1,000 FT 20.000 LB YELLOW 1583A 005U1000 1,000 FT 24.000 LB GREEN, DARK 1583A 0051000 1,000 FT 20.000 LB GREEN, DARK 1583A 006U1000 1,000 FT 20.000 LB BLUE, LIGHT 1583A 0061000 1,000 FT 20.000 LB BLUE, LIGHT 1583A 0061640 1,640 FT 34.440 LB BLUE, LIGHT 1583A 0063000 3,000 FT 60.000 LB BLUE, LIGHT 1583A 008U1000 1,000 FT 20.000 LB GRAY C CAT5E 4PR U/UTP CMR BOX 1583A 0081000 1,000 FT 20.000 LB GRAY C CAT5E 4PR U/UTP CMR REEL 1583A 0081640 1,640 FT 34.440 LB GRAY C CAT5E 4PR U/UTP CMR REEL 1583A 0083000 3,000 FT 60.000 LB GRAY C CAT5E 4PR U/UTP CMR REEL 1583A 009U1000 1,000 FT 24.000 LB WHITE 1583A 0091000 1,000 FT 20.000 LB WHITE C CAT5E 4PR U/UTP CMR REEL 1583A 0093000 3,000 FT 60.000 LB WHITE C CAT5E 4PR U/UTP CMR REEL 1583A 010U1000 1,000 FT 24.000 LB BLACK 1583A 0101000 1,000 FT 20.000 LB BLACK 1583A 012U1000 1,000 FT 24.000 LB PINK 1583A 0121000 1,000 FT 20.000 LB PINK CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR BOX CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL CAT5E 4PR U/UTP CMR BOX C CAT5E 4PR U/UTP CMR REEL Notes: C = CRATE REEL PUT-UP. Page 3 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1583A Multi-Conductor - Category 5e Nonbonded-Pair Cable Revision Number: 6 Revision Date: 06-09-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 4 of 4 02-01-2017
1583A 0021000 价格&库存
很抱歉,暂时无法提供与“1583A 0021000”相匹配的价格&库存,您可以联系我们找货
