1633ENH.00305
1633ENH.00305
    BELDEN
    BELDEN - 1633ENH.00305 - Networking Cable, FTP, Screened, Cat5e, 24 AWG, 0.2 mm², 1000 ft, 305 m
1633ENH.00305 数据手册
Product Datasheet P/N - 43132 Rev.3A Page 1 of 2 Date 01-05-2001 Belden 1633E CAT 5 enhanced FTP PVC Application • • Horizontal and building backbone cable. Support current Category 5 and Category 5 enhanced applications, such as: 10 Base-T, 100 Base-T, 1000 Base-T (Gigabit Ethernet), FDDI, ATM Standards • • Aktuelle Normung: Zukünftige Normung: ISO/IEC 11801, EN 50173 ISO/IEC 11801 2nd edition, EN 50173 2nd edition und prEN 50288-3-1 Construction & Dimensions • • • • • • • • • Construction: Conductor: Conductor diameter: Conductor insulation material: Diameter over insulation: Drain wire: Shield: Jacket material: Outer diameter: shielded 4 twisted pairs solid bare copper AWG 24 (0,52 mm) Polyethylene (PE) 1.10 mm ± 0.05 mm AWG 26 tinned copper Aluminium/polyester foil PVC (Flame retardant) 6.0 mm ± 0.3 mm Colour code Pair 1 Pair 2 Pair 3 Pair 4 White-Blue/Blue White-Orange/Orange White-Green/Green White-Brown/Brown Electrical characteristics (at 20 ºC) Attenuation Frequency 1) Maximum Typical 1 4.0 2.0 4 4.0 3.8 10 6.3 6.0 16 8.0 7.6 20 9.0 8.5 31.25 11.4 10.8 62.5 16.5 15.0 100 21.3 19.2 MHz dB/100m dB/100m NEXT Frequency 1) Minimum Typical 1 60.0 70 4 56.3 62 10 50.3 57 16 47.2 54 20 45.8 52 31.25 42.9 49 62.5 38.4 45 100 35.3 43 MHz dB dB Power Sum NEXT Frequency 1 1) Minimum 57.0 Typical 68 4 53.3 60 10 47.3 55 16 44.2 52 20 42.8 50 31.25 39.9 47 62.5 35.4 43 100 32.3 41 MHz dB dB Power Sum ELFEXT Frequency 1 1) Minimum 60.8 Typical 73 4 48.8 61 10 40.8 53 16 36.7 47 20 34.8 45 31.25 30.9 41 62.5 24.9 37 100 20.8 33 MHz dB dB ACR Frequency 1) Minimum Typical 1 56.0 68.0 4 52.3 58.2 10 44.0 51.0 16 39.2 46.4 20 36.8 43.5 31.25 31.5 38.2 62.5 21.8 30.0 100 14.0 23.8 MHz dB/100m dB/100m Power Sum ACR Frequency 1 1) Minimum 53.0 Typical 66.0 4 49.3 56.2 10 41.0 49.0 16 36.2 44.4 20 33.8 41.5 31.25 28.5 36.2 62.5 18.8 28.0 100 11.0 21.8 MHz dB/100m dB/100m 1) : Values according to cable requirements of ISO/IEC 11801 category 5 enhanced Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner. All printing errors are subject to correction. Technical apecifications are subject to change without notice. Product Datasheet P/N - 43132 Rev.3A Page 2 of 2 Date 01-05-2001 Belden 1633E CAT 5 enhanced FTP PVC Electrical characteristics (at 20 ºC) Nominal mutual capacitance at 1 kHz Maximum conductor DCR NVP - Nominal Velocity of Propagation SKEW – Propagation delay difference (100 MHz) Impedance 1 - 100 MHz 50 nF/km 93,5 Ohm/km 0.70 c typical ≤ 15 ns/100m 100 ± 15 Ohm General and environmental characteristics Temperature range - operation Temperature range - installation Minimum bending radius - operation Minimum bending radius - installation Maximum pulling tension Flame retardancy Energy of flame Weight (approx.) Maximum operating voltage Maximum continuous current per conductor (25°C) -20°C - +60°C +0°C - +50°C 24 mm 48 mm 80 N IEC 332-1 515 kJ/m 43 kg/km 48 V rms 1.4 A Ordering information MARKING Text on the cable jacket Inkjet printing BELDEN 1633E FTP CAT5E 4PR AWG24 ISO/IEC 11801 EN 50173 VERIFIED 100 OHM Meter marking: JACKET COLOUR Colour Grey Yes RAL code RAL 7032 PACKAGING (PUT UP) Belden code Delivery length 43132 xxxx 240 500 m 43132 xxxx 241 1000 m xxxx: Belden colour code Belden colour code 3251 Weight 21.0 kg 42.0 kg Remark Non returnable reel Non returnable reel Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner. All printing errors are subject to correction. Technical apecifications are subject to change without notice.
1633ENH.00305 价格&库存
很抱歉,暂时无法提供与“1633ENH.00305”相匹配的价格&库存,您可以联系我们找货
1633ENH.00305
    • 1+3587.57728
    库存:6080
