Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1924A Multi-Conductor - FleXnake® Super-Flexible, High-Performance Cable
For more Information
please call
1-800-Belden1
General Description:
24 AWG stranded (41x40) bare copper conductor, polyolefin insulation, individually shielded with double
serve “French Braid” (93% coverage), TC drain wire, numbered/color-coded PVC jackets, overall Black
PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
24
24
41x40
BC - Bare Copper
.0225
Total Number of Conductors:
48
Insulation
Insulation Material:
Insulation Material Wall Thickness (in.) Dia. (in.)
PO - Polyolefin
.008
.040
Inner Shield
Inner Shield Material:
Type
Inner Shield Material Coverage (%)
French Braid BC - Bare Copper
95
Inner Shield Drain Wire AWG:
AWG
24
Inner Shield Drain Wire Stranding:
19x26
Inner Shield Drain Wire Conductor Material:
TC - Tinned Copper
Inner Jacket
Inner Jacket Material:
Nom Wall (in.) Nom. Dia. (in.)
PVC - Polyvinyl Chloride .014
.119
Inner Jacket Color Code Chart:
Number Color
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Purple
8
Gray
9
White
10
Black
11
Tan
12
Pink
13
Gray/Brown
14
Gray/Red
15
Gray/Orange
16
Gray/Yellow
17
Gray/Green
18
Gray/Blue
19
Gray/Purple
Gray/Gray
21
Gray/White
22
Gray/Black
23
Gray/Tan
Page 1 of 3
08-26-2016
24
Gray/Pink
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride .090
Overall Cable
Overall Nominal Diameter:
0.825 in.
Pair
Pair Color Code Chart:
Color
Red and Black
Pair Lay Length & Direction:
Lay Length (in.) Twists (twist/ft)
1.000
12.000
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +60°C
Bulk Cable Weight:
397 lbs/1000 ft.
Max. Recommended Pulling Tension:
700 lbs.
Min. Bend Radius/Minor Axis:
8.250 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
60
Nom. Inductance:
Inductance (µH/ft)
.18
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
26.1
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
47.5
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
25.5
Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C:
7.200 Ohm/1000 ft
Max. Operating Voltage - UL:
Voltage
300 V RMS
Page 2 of 3
08-26-2016
Max. Recommended Current:
Current
1.05 Amps per conductor @ 25°C
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1924A B59500
500 FT
214.500 LB
BLACK, MATTE
C
24 #24 JKTED PR PVC
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 04-17-2008
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“1924A B59500”相匹配的价格&库存,您可以联系我们找货
