Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
3076F Multi-Conductor - DataBus® ISA/SP-50 FOUNDATION Fieldbus or PROFIBUS Cable
For more Information
please call
1-800-Belden1
General Description:
1 pair 18 AWG stranded (7x26) tinned copper conductors, polyolefin insulation, polyolefin filler, Beldfoil®
shield (100% coverage), tinned copper drain wire, binder, PVC jacket. Fieldbus Foundation Registered
Product.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
1
18
7x26
TC - Tinned Copper 0.046
Total Number of Conductors:
2
Insulation
Insulation Material:
Insulation Material
PO - Polyolefin
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
7x28
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Outer Jacket Diameter:
Nom. Dia. (in.)
0.280
Overall Cable
Overall Cabling Fillers:
Polypropylene
Overall Cabling Lay Length & Direction:
Length (in.) Twists (twist/ft)
2.250
5.300
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +105°C
UL Temperature Rating:
105°C
Bulk Cable Weight:
38 lbs/1000 ft.
Max. Recommended Pulling Tension:
60 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM, CMX-Outdoor, PLTC-ER
NEC Articles:
725, 727, 800
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
Page 1 of 3
01-05-2017
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Other Specification:
ITC-ER
Flame Test
UL Flame Test:
UL1666 Riser
C(UL) Flame Test:
FT4
IEEE Flame Test:
1202, IEEE 383 Vertical Tray Flame Test (70,000 BTU)
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Suitability - Burial:
Yes - UL
Sunlight Resistance:
Yes
Oil Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Unaveraged Impedance:
Freq. (MHz) Impedance (Ohm)
0.031
100.000
Nom. Inductance:
Inductance (µH/ft)
.19
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
45.0
Nom. Mutual Capacitance:
Capacitance (pF/ft)
24.0
Maximum Capacitance Unbalance:
Capacitance (pF/ft)
1.200
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
5.86
Nominal Outer Shield DC Resistance:
7.500
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
0.039
0.080
Max. Attenuation:
.091 0.039
0.091
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Description
Current
Page 2 of 3
01-05-2017
Per Conductor 5.2 Amps
Other Electrical Characteristic 1:
Max Propagation Delay Change From 7.812 kHz to 39.06 kHz: 518 pS/ft
Other Electrical Characteristic 2:
31.25 KBits/sec
Notes (Overall)
Notes: Fieldbus: Orange jacket. Profibus PA: Intrinsically Safe Blue jacket. Jacket diameter tolerance: +/- .010
Related Documents:
FieldbusCertificate-3076F.pdf - This is a Foundation H1 Cable Registration Certification for 3076F.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
3076F 0031000
1,000 FT
48.000 LB
ORANGE
C
TW PR #18 PP FS PVC
3076F 00310000
10,000 FT
510.000 LB
ORANGE
CN
TW PR #18 PP FS PVC
3076F 003250
250 FT
14.000 LB
ORANGE
C
TW PR #18 PP FS PVC
3076F 0032500
2,500 FT
120.000 LB
ORANGE
C
TW PR #18 PP FS PVC
3076F 003500
500 FT
25.500 LB
ORANGE
C
TW PR #18 PP FS PVC
3076F 0035000
5,000 FT
240.000 LB
ORANGE
CN
TW PR #18 PP FS PVC
3076F 0061000
1,000 FT
48.000 LB
BLUE, LIGHT
C
TW PR #18 PP FS PVC
Notes:
C = CRATE REEL PUT-UP.
N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN.
Revision Number: 7
Revision Date: 06-18-2014
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“3076F 003500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.079011+6.76870
- 50+41.2980450+5.36750
- 100+36.86394100+4.79120
- 152+32.60372152+4.23750
