34412 002100
34412 002100
    BELDEN
    BELDEN - 34412 002100 - Hook-Up Wire
34412 002100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 34412 Hook-up/Lead - UL AWM Style 3191 For more Information please call 1-800-Belden1 Description: CSPE - Chlorosulphonated Polyethylene insulation has excellent heat resistance, color stability and electrical properties and is recommended for Class 130(B) insulation systems. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 12 65x30 TC - Tinned Copper Insulation Insulation Material: Insulation Material CSPE - Chlorosulphonated Polyethylene Overall Insulation Overall Cable Overall Nominal Diameter: 0.190 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: 3191 UL Rating: 600 V, 105°C CSA Rating: 600 V, 105°C CSA Type: CL1053 EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Related Documents: No related documents are available for this product Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 34412 002500 500 FT 19.000 LB RED CF #12 STR CSPE 105C 600V 34412 005500 500 FT 19.000 LB GREEN, DARK F #12 STR CSPE 105C 600V 34412 010100 100 FT 4.200 LB BLACK 34412 0103000 3,000 FT 111.000 LB BLACK #12 STR CSPE 105C 600V CIU Page 1 of 2 #12 STR CSPE 105C 600VLK 01-06-2012 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 34412 Hook-up/Lead - UL AWM Style 3191 34412 010500 500 FT 19.000 LB BLACK F #12 STR CSPE 105C 600V Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200' U = TOPCOAT ADDERS ON STOCK SOLID COLORS. MINIMUM ORDER 10000' PER COLORCOMBINATION. (SEE TOPCOAT ADDER TABLE) Revision Number: 1 Revision Date: 01-11-2011 © 2012 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-06-2012
34412 002100 价格&库存
很抱歉,暂时无法提供与“34412 002100”相匹配的价格&库存,您可以联系我们找货
