Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
38214 Hook-up/Lead - UL Type PV Wire
For more Information
please call
1-800-Belden1
General Description:
14 AWG stranded (41x30) tinned copper conductors, XLPE insulation, non-integrally PVC jacketed,
sunlight resistant, photovoltaic wire.
Usage (Overall)
Suitable Applications:
Interconnection wiring of grounded and ungrounded photovoltaic power systems as described in Section
690.31(A) of the 2008 NEC.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
14
41x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
XLPE - Cross Linked Polyethylene 0.048
Separator
Separator Material over Conductor:
Y
Jacket
Jacket Material:
PVC - Polyvinyl Chloride
Jacket Thickness:
.033
Overall Cable
Overall Nominal Diameter:
0.243 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +90°C
UL Temperature Rating:
90°C Wet/Dry
Bulk Cable Weight:
36 lbs/1000 ft.
Max. Recommended Pulling Tension:
53.500 lbs.
Min. Bend Radius/Minor Axis:
2.438 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
600V, 90C
UL Type:
PV, USE-2, RHW-2
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
09/01/2009
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
Page 1 of 2
01-05-2017
Suitability
Sunlight Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
2.400
Max. Operating Voltage - UL:
Voltage
600 V RMS
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30 ambient 35 amps
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
38214 0105000
5,000 FT
185.000 LB
BLACK
C
#14 XLPE PVC
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 09-24-2010
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“38214 0105000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+12.288315000+1.58632
