Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
39112 Hook-up/Lead - PPO Hook-up Wire 600V, 105°C AWM Style 11036
For more Information
please call
1-800-Belden1
General Description:
12 AWG stranded (65x30) tinned copper conductor, PPO insulation. Rated 105ºC, 600V. Rated 2500V
peak for electronic circuits, and internal wiring of electronic and electrical equipment.
Usage (Overall)
Suitable Applications:
Electrical panel builders, Electrical/electronic manufacturers, Appliance manufacturers, Furniture,
Computer manufacturers, Automotive companies and their sub-suppliers
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
12
65x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
PPO - Polyphenylene Oxide 0.012
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.111 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +105°C Dry
Bulk Cable Weight:
21.300 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
600 V, 105°C
UL Type:
AWM 11028
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2011
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
1.500
Max. Operating Voltage - UL:
Voltage
Page 1 of 2
01-09-2015
600 Vac
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30C ambient 51 amps
Notes (Overall)
Notes: Halogen-free.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
39112 001100
100 FT
2.200 LB
BROWN
C
#12 STR PPO BRN
39112 0011000
1,000 FT
23.000 LB
BROWN
C
#12 STR PPO BRN
39112 0015000
5,000 FT
110.000 LB
BROWN
CZ
#12 STR PPO BRN
39112 002100
100 FT
2.200 LB
RED
C
#12 STR PPO RED
39112 0021000
1,000 FT
23.000 LB
RED
C
#12 STR PPO RED
39112 0025000
5,000 FT
110.000 LB
RED
CZ
#12 STR PPO RED
39112 003100
100 FT
2.200 LB
ORANGE
C
#12 STR PPO ORG
39112 0031000
1,000 FT
23.000 LB
ORANGE
C
#12 STR PPO ORG
39112 0035000
5,000 FT
110.000 LB
ORANGE
CZ
#12 STR PPO ORG
39112 004100
100 FT
2.200 LB
YELLOW
C
#12 STR PPO YEL
39112 0041000
1,000 FT
23.000 LB
YELLOW
C
#12 STR PPO YEL
39112 0045000
5,000 FT
110.000 LB
YELLOW
CZ
#12 STR PPO YEL
39112 005100
100 FT
2.200 LB
GREEN, DARK
C
#12 STR PPO DRGN
39112 0051000
1,000 FT
23.000 LB
GREEN, DARK
C
#12 STR PPO DGRN
39112 0055000
5,000 FT
110.000 LB
GREEN, DARK
CZ
#12 STR PPO DGRN
39112 007100
100 FT
2.200 LB
VIOLET
C
#12 STR PPO VIO
39112 0071000
1,000 FT
23.000 LB
VIOLET
C
#12 STR PPO VIO
39112 0075000
5,000 FT
110.000 LB
VIOLET
CZ
#12 STR PPO VIO
39112 008100
100 FT
2.200 LB
GRAY
C
#12 STR PPO GRY
39112 0081000
1,000 FT
23.000 LB
GRAY
C
#12 STR PPO GRY
39112 0085000
5,000 FT
110.000 LB
GRAY
CZ
#12 STR PPO GRY
39112 009100
100 FT
2.200 LB
WHITE
C
#12 STR PPO WHT
39112 0091000
1,000 FT
23.000 LB
WHITE
C
#12 STR PPO WHT
39112 0095000
5,000 FT
110.000 LB
WHITE
CZ
#12 STR PPO WHT
39112 010100
100 FT
2.200 LB
BLACK
C
#12 STR PPO BLK
39112 0101000
1,000 FT
23.000 LB
BLACK
C
#12 STR PPO BLK
39112 0105000
5,000 FT
110.000 LB
BLACK
CZ
#12 STR PPO BLK
39112 013100
100 FT
2.200 LB
BLUE, DARK
C
#12 STR PPO DBLU
39112 0131000
1,000 FT
23.000 LB
BLUE, DARK
C
#12 STR PPO DBLU
39112 0135000
5,000 FT
110.000 LB
BLUE, DARK
CZ
#12 STR PPO DBLU
39112 189100
100 FT
2.200 LB
GREEN/YELLOW
C
#12 STR PPO GRN/YEL
39112 1891000
1,000 FT
23.000 LB
GREEN/YELLOW
C
#12 STR PPO GRN/YEL
39112 1895000
5,000 FT
110.000 LB
GREEN/YELLOW
CZ
#12 STR PPO GRN/YEL
Notes:
C = CRATE REEL PUT-UP.
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 0
Revision Date: 07-13-2012
© 2015 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
Page 2 of 2
01-09-2015
