76304WS 0081000
76304WS 0081000
    BELDEN
    CBL 4COND 22AWG SHLD MACHFLEX
76304WS 0081000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 76304WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (19x34) tinned copper conductors, PVC insulation, Aluminum/Polyester Foil Shield, Tinned copper spiral shield, 90% coverage, oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 22 19x34 TC - Tinned Copper Insulation Insulation Material: Insulation Material Wall Thickness (mm) PVC - Polyvinyl Chloride 0.254 Insulation Color Code Chart: Number Color 1 Black 2 Red 3 White 4 Green Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Tape 2 Serve TC - Tinned Copper Aluminum/Mylar 100.000 90.000 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 1.016 Overall Cable Overall Nominal Diameter: 5.867 mm Mechanical Characteristics (Overall) Bulk Cable Weight: 56.552 Kg/Km Max. Recommended Pulling Tension: 128.998 N Min. Bend Radius/Minor Axis: 45.720 mm Min. Bend/Installation: 45.720 mm Min. Bend Radius (Continuous Flexing): 45.720 mm Flex Cycle Rating: 6 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: AWM/STYLE 10002, AWM/STYLE 2661, CSA AWM I/II A/B, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Flame Test CSA Flame Test: FT4 Suitability Suitability - Burial: Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 76304WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles 0.558 Nom. Capacitance Conductor to Conductor: Freq. (MHz) Capacitance (pF/m) 0.001 124.678 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 50.199 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 17.061 Max. Operating Voltage - UL: Voltage 300V Notes (Overall) Notes: Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic) Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
76304WS 0081000 价格&库存
很抱歉,暂时无法提供与“76304WS 0081000”相匹配的价格&库存,您可以联系我们找货
