7808WB 0101000
7808WB 0101000
    BELDEN
    RF240 WIRELESS 50 OHM COAX WB
7808WB 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7808WB Coax - RG-8X Type For more Information please call 1-800-Belden1 General Description: RG-8X type, 15 AWG solid .057" bare copper conductor, gas-injected foam HDPE insulation, Duobond® II + tinned copper braid shield (95% coverage), flooded water-resistant polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 15 Solid BC - Bare Copper .057 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .150 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper Outer Shield Flooding Grease: 95 PO - Polyolefin Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Overall Cable Overall Nominal Diameter: 0.240 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 36 lbs/1000 ft. Max. Recommended Pulling Tension: 74 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 8/X Suitability Suitability - Outdoor: Yes Suitability - Aerial: Yes - When supported by a messenger Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7808WB Coax - RG-8X Type Suitability - Burial: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .060 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 23.0 Nominal Velocity of Propagation: VP (%) 86 Nominal Delay: Delay (ns/ft) 1.18 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.8 Maximum VSWR: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR 5 6000 1.25:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5.000 0.580 10.000 0.770 30.000 1.300 50.000 1.600 150.000 2.800 220.000 3.400 450.000 4.900 900.000 7.000 1500.000 9.100 1800.000 10.100 2000.000 10.700 2500.000 12.000 3000.000 13.400 3500.000 14.600 4500.000 16.700 5800.000 19.500 6000.000 19.800 Max. Power Rating: Freq. (MHz) Rating (W) 30.000 1526.000 50.000 1186.000 150.000 673.000 220.000 556.000 450.000 382.000 900.000 268.000 1500.000 205.000 1800.000 187.000 2000.000 177.000 2500.000 156.000 3000.000 143.000 3500.000 100.000 4500.000 116.000 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7808WB Coax - RG-8X Type 5800.000 102.000 6000.000 100.000 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Sweep Test Sweep Testing: 100% sweep tested to 6 GHz. Misc. Information (Overall) Notes (Overall) Notes: Belden® The Wire in Wireless® Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7808WB 0101000 1,000 FT 39.000 LB BLACK C RF240 WIRELESS 50 OHM COAX WB 7808WB 010500 500 FT 19.500 LB BLACK C RF240 WIRELESS 50 OHM COAX WB Notes: C = CRATE REEL PUT-UP. Revision Number: 5 Revision Date: 01-06-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
7808WB 0101000 价格&库存
很抱歉,暂时无法提供与“7808WB 0101000”相匹配的价格&库存,您可以联系我们找货
