7809WB 010500
7809WB 010500
    BELDEN
    RF300 WIRELESS 50 OHM COAX WB
7809WB 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7809WB Coax - Intermediate Type For more Information please call 1-800-Belden1 General Description: Intermediate type, 13 AWG solid .072" bare copper conductor, gas-injected foam HDPE insulation, Duobond® II + tinned copper braid shield (95% coverage), flooded water-resistant polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 13 Solid BC - Bare Copper .072 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .190 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper Outer Shield Flooding Grease: 95 PO - Polyolefin Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Overall Cable Overall Nominal Diameter: 0.300 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 46 lbs/1000 ft. Max. Recommended Pulling Tension: 135 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Series Type: RF 300 Suitability Suitability - Outdoor: Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7809WB Coax - Intermediate Type Suitability - Aerial: Yes - When supported by a messenger Suitability - Burial: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) 0.060 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 23.0 Nominal Velocity of Propagation: VP (%) 86 Nominal Delay: Delay (ns/ft) 1.17 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.1 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.4 Maximum VSWR: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR 5 6000 1.25:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5.000 0.450 10.000 0.600 30.000 1.000 50.000 1.300 150.000 2.200 220.000 2.700 450.000 3.900 900.000 5.600 1500.000 7.300 1800.000 8.100 2000.000 8.600 2500.000 9.700 3000.000 10.800 3500.000 11.800 4500.000 13.500 5800.000 15.800 6000.000 16.000 Nom. Power Rating: Freq. (MHz) Rating (W) 30 2161 50 1658 150 928 220 758 450 522 900 367 1500 278 1800 253 2000 239 2500 212 3000 194 3500 179 Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7809WB Coax - Intermediate Type 4500 157 5800 137 6000 135 Max. Power Rating: Freq. (MHz) Rating (W) 30.000 2161.000 50.000 1658.000 150.000 928.000 220.000 758.000 450.000 522.000 900.000 367.000 1500.000 278.000 1800.000 253.000 2000.000 239.000 2500.000 212.000 3000.000 194.000 3500.000 179.000 4500.000 157.000 5800.000 137.000 6000.000 135.000 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Sweep Test Sweep Testing: 100% Sweep tested to 6 GHz. Misc. Information (Overall) Notes (Overall) Notes: 100% Sweep tested. 6 GHz. Belden® The Wire in Wireless® Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7809WB 0101000 1,000 FT 59.000 LB BLACK C RF300 WIRELESS 50 OHM COAX WB 7809WB 010500 500 FT 30.500 LB BLACK C RF300 WIRELESS 50 OHM COAX WB Notes: C = CRATE REEL PUT-UP. Revision Number: 5 Revision Date: 01-06-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
7809WB 010500 价格&库存
很抱歉,暂时无法提供与“7809WB 010500”相匹配的价格&库存,您可以联系我们找货
