7997A 0101000
7997A 0101000
    BELDEN
    BELDEN  7997A 0101000  UNSHIELDED CABLE MULTIPAIR, 4PAIR, 24AWG, 1000FT, 300V New
7997A 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7997A Multi-Conductor - Category 5e Nonbonded-Pair Outside Plant Cable For more Information please call 1-800-Belden1 General Description: CAT5e (200MHz), 4-Pair, U/UTP-Unshielded, OSP Rated, Premise Horizontal Cable, 24 AWG Solid Bare Copper Conductors, Polyolefin Insulation, Gel-Filled, Polyethylene Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, 200MHz Category 5e, Outside Plant, Duct Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Outer Jacket Diameter: Nom. Dia. (in.) 0.226 Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +60°C Installation Temperature Range: -20°C To +60°C Operating Temperature Range: -40°C To +60°C Bulk Cable Weight: 26 lbs/1000 ft. Max. Recommended Pulling Tension: 35 lbs. Min. Bend Radius/Minor Axis: 2.300 in. Min. Bend/Installation: 2.300 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7997A Multi-Conductor - Category 5e Nonbonded-Pair Outside Plant Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Other Specification: REA-200 Approved Jacket Material Suitability Suitability - Indoor: No Suitability - Outdoor: Yes Suitability - Aerial: Yes - Black only, when supported by messenger wire. Suitability - Burial: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 14 Maximum Capacitance Unbalance (pF/100 m): 66 Nominal Velocity of Propagation: VP (%) 65 Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 8.9 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 2.0 70.3 68.3 70.3 66.3 20.0 4 4.0 61.3 59.3 59.3 55.3 23.0 8 5.7 56.8 54.8 53.1 49.1 24.5 10 6.4 55.3 53.3 50.9 46.9 25.0 16 8.1 52.2 50.2 46.1 42.1 25.0 20 9.1 50.8 48.8 43.7 39.7 25.0 25 10.2 49.3 47.3 41.1 37.1 24.3 31.25 11.4 47.9 45.9 38.5 34.5 23.6 62.5 16.4 43.4 41.4 29.0 25.0 21.5 100 21.0 40.3 38.3 21.3 17.3 20.1 155 26.6 37.4 35.4 12.9 8.9 18.8 200 30.5 35.8 33.8 7.3 3.3 18.0 *350 41.4 32.1 30.1 16.3 *400 44.6 31.3 29.3 15.9 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 67.8 64.8 4 100 ± 15 100 ± 15 55.8 52.8 8 100 ± 15 100 ± 15 49.7 46.7 Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7997A Multi-Conductor - Category 5e Nonbonded-Pair Outside Plant Cable 10 100 ± 15 100 ± 15 47.8 44.8 16 100 ± 15 100 ± 15 43.7 40.7 20 100 ± 15 100 ± 15 41.8 38.8 25 100 ± 15 100 ± 15 39.8 36.8 31.25 100 ± 15 100 ± 15 37.9 34.9 62.5 100 ± 15 100 ± 15 31.9 28.9 100 100 ± 15 100 ± 15 27.8 24.8 155 100 ± 22 100 ± 15 24.0 21.0 200 100 ± 22 100 ± 15 21.8 18.8 *350 100 ± 22 100 ± 15 *400 100 ± 22 100 ± 15 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Verified to ANSI/TIA-568-C.2, Category 5e. * Frequencies above 200 MHz are for reference only Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7997A 0101000 1,000 FT 27.000 LB BLACK C CAT5E 4PR U/UTP OSP REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-11-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-01-2017
7997A 0101000 价格&库存
很抱歉,暂时无法提供与“7997A 0101000”相匹配的价格&库存,您可以联系我们找货
