7GC-BC50
7GC-BC50
    BELDEN
    BELDEN - 7GC-BC50 - Multicore Cable, Unscreened, 7 Core, 1 mm², 164 ft, 50 m
7GC-BC50 数据手册
MachFlex 350 YY Cables Unshielded PVC Control Cables Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • DIN VDE 0295, IEC 60228, BS6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS&REACH&CE Directives Construction and Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5) 2. Insulation Material & Color Insulation Material & Colour PVC (polyvinyl chloride). A) All black color with number coding = without protective conductor. B) Black color with number coding plus 1 green & yellow = with protective conductor. 3. Jacket / Sheath Material PVC (polyvinyl chloride) 4. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 5. Voltage Rating (Uo/U) 300 / 500 V 6. Oil Resistant DIN EN 50290-2-22 (TM54) 7. Temperature Range -30 °C TO +70 °C (Occasional movement) -40 °C TO +80 °C (Fixed installation) 8. Bending Radius 10 x OD (Occasional movement) 4 x OD (Fixed installation) 9. Other Properties Good UV resistance, chemical resistance & flexibility MachFlex 350 YY Unshielded PVC Control Cables UNSHIELDED CABLE WITH (G) PROTECTIVE GROUND 1 = Conductor 2 = Insulation 3 = Inner Sheath 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 4.9 5.3 5.9 6.4 8.6 10.8 Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code 3GA 4GA 5GA 7GA 12GA 20GA APAC Part Code 3G0.5 4G0.5 5G0.5 7G0.5 12G0.5 20G0.5 Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 5.4 5.9 6.5 7.2 9.6 12.1 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code 3GB 4GB 5GB 7GB 12GB 20GB APAC Part Code 3G0.75 4G0.75 5G0.75 7G0.75 12G0.75 20G0.75 Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 28.80 3 5.8 38.40 4 6.4 48.00 5 7.1 67.00 7 7.8 115.00 12 10.5 192.00 20 13.2 Conductor 2.50 mm2 EMEA Part Code 3GC 4GC 5GC 7GC 12GC 20GC APAC Part Code 3G1.0 4G1.0 5G1.0 7G1.0 12G1.0 20G1.0 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 6.4 43.00 4 7.0 58.00 5 7.8 72.00 7 8.5 101.00 12 11.5 173.00 20 14.5 288.30 Conductor 4.00 mm2 EMEA Part Code 3GD 4GD 5GD 7GD 12GD 20GD APAC Part Code 3G1.5 4G1.5 5G1.5 7G1.5 12G1.5 20G1.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 72.00 3 8.3 96.00 4 9.2 120.00 5 10.1 168.00 7 11.2 288.00 12 15.2 480.00 20 19.2 Conductor 6.00 mm2 EMEA Part Code 3GE 4GE 5GE 7GE 12GE 20GE APAC Part Code 3G2.5 4G2.5 5G2.5 7G2.5 12G2.5 20G2.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 115.00 3 9.8 154.00 4 10.9 192.00 5 12.0 269.00 7 13.3 345.90 9 16.6 461.00 12 18.1 Conductor 10.00 mm2 EMEA Part Code 3GF 4GF 5GF 7GF 9GF 12GF APAC Part Code 3G4 4G4 5G4 7G4 9G4 12G4 No. of Cores 3 4 5 7 9 EMEA Part Code 3GG 4GG 5GG 7GG 9GG APAC Part Code 3G6 4G6 5G6 7G6 9G6 No. of Cores 3 4 5 7 9 EMEA Part Code 3GH 4GH 5GH 7GH 9GH APAC Part Code 3G10 4G10 5G10 7G10 9G10 EMEA Part Code 3GJ 4GJ 5GJ 7GJ APAC Part Code 3G25 4G25 5G25 7G25 Nom. Overall Diameter (mm) 11.8 13.1 14.5 16.0 20.1 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 18.1 20.2 22.4 24.8 Nom. Overall Diameter (mm) 14.8 16.5 18.3 20.3 25.5 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 Copper Weight (kg/km) 460.50 614.00 768.00 1,075.00 EMEA Part Code 3GI 4GI 5GI 7GI APAC Part Code 3G16 4G16 5G16 7G16 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 22.3 24.9 27.7 30.6 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00 1,680.00 MachFlex 350 YY Unshielded PVC Control Cables UNSHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND 1 = Conductor 2 = Insulation 3 = Inner Sheath 2 3 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 4.9 5.3 5.9 6.4 8.6 10.8 Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code 3XA 4XA 5XA 7XA 12XA 20XA APAC Part Code 3X0.5 4X0.5 5X0.5 7X0.5 12X0.5 20X0.5 Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 5.4 5.9 6.5 7.2 9.6 12.1 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code 3XB 4XB 5XB 7XB 12XB 20XB APAC Part Code 3X0.75 4X0.75 5X0.75 7X0.75 12X0.75 20X0.75 Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 5.8 28.80 4 6.4 38.40 5 7.1 48.00 7 7.8 67.00 12 10.5 115.00 20 13.2 192.00 Conductor 2.50 mm2 EMEA Part Code 3XC 4XC 5XC 7XC 12XC 20XC APAC Part Code 3X1.0 4X1.0 5X1.0 7X1.0 12X1.0 20X1.0 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 6.4 43.00 4 7.0 58.00 5 7.8 72.00 7 8.5 101.00 12 11.5 173.00 20 14.5 288.30 Conductor 4.00 mm2 EMEA Part Code 3XD 4XD 5XD 7XD 12XD 20XD APAC Part Code 3X1.5 4X1.5 5X1.5 7X1.5 12X1.5 20X1.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.3 72.00 4 9.2 96.00 5 10.1 120.00 7 11.2 168.00 12 15.2 288.00 20 19.2 480.00 Conductor 6.00 mm2 EMEA Part Code 3XE 4XE 5XE 7XE 12XE 20XE APAC Part Code 3X2.5 4X2.5 5X2.5 7X2.5 12X2.5 20X2.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.8 115.00 4 10.9 154.00 5 12.0 192.00 7 13.3 269.00 9 16.6 345.90 12 18.1 461.00 Conductor 10.00 mm2 EMEA Part Code 3XF 4XF 5XF 7XF 9XF 12XF APAC Part Code 3X4 4X4 5X4 7X4 9X4 12X4 No. of Cores 3 4 5 7 9 EMEA Part Code 3XG 4XG 5XG 7XG 9XG APAC Part Code 3X6 4X6 5X6 7X6 9X6 No. of Cores 3 4 5 7 9 EMEA Part Code 3XH 4XH 5XH 7XH 9XH APAC Part Code 3X10 4X10 5X10 7X10 9X10 EMEA Part Code 3XJ 4XJ 5XJ 7XJ APAC Part Code 3X25 4X25 5X25 7X25 Nom. Overall Diameter (mm) 11.8 13.1 14.5 16.0 20.1 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 18.1 20.2 22.4 24.8 Copper Weight (kg/km) 460.50 614.00 768.00 1,075.00 Nom. Overall Diameter (mm) 14.8 16.5 18.3 20.3 25.5 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code 3XI 4XI 5XI 7XI APAC Part Code 3X16 4X16 5X16 7X16 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 22.3 24.9 27.7 30.6 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00 1,680.00
7GC-BC50
物料型号:MachFlex 350 YY
器件简介:该系列电缆设计用于偶尔弯曲和固定位置安装的应用,如精密控制传感器、多轴控制机器、温度控制器、控制面板、机械切割工具、辅助设备、电机速度控制、生产机械等。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 导体材料:绞合裸铜(DIN VDE 0295 Class 5) - 绝缘材料:PVC(聚氯乙烯),颜色为黑色,带编号,有或没有保护导体 - 护套材料:PVC(聚氯乙烯) - 阻燃性:符合VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2标准 - 额定电压:300/500V - 耐油性:DIN EN 50290-2-22(TM54) - 温度范围:-30°C至+70°C(偶尔移动);-40°C至+80°C(固定安装) - 弯曲半径:10xOD(偶尔移动);4xOD(固定安装) - 其他特性:良好的紫外线抗性、化学抗性和柔韧性
功能详解:文档中未提供具体的功能详解
应用信息:适用于需要精确控制的多种工业应用,包括但不限于传感器、机器控制、温度控制等。
封装信息:提供了不同导体截面积(如2.5 mm²、4 mm²、6 mm²等)和芯数(3、4、5、7、9、12、20)的电缆规格,以及相应的EMEA和APAC地区部件代码。
7GC-BC50 价格&库存
很抱歉,暂时无法提供与“7GC-BC50”相匹配的价格&库存,您可以联系我们找货
7GC-BC50
  • 1+15.846611+2.05660
  • 25+13.1474625+1.70630
  • 50+11.7543550+1.52550
  • 100+10.36125100+1.34470
库存:701
7GC-BC50
    • 1+1239.05916
    • 5+1189.48930
    库存:500
