82723 877U1000
82723 877U1000
    BELDEN
    CBL 2PR 22AWG SHLD
82723 877U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82723 Multi-Conductor - Double-Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, plenum, FEP insulation, twisted pairs, individually shielded w/Beldfoil® (100% coverage), 22 AWG stranded TC drain wire, Flamarrest® jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 22 7x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene 0.007 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: 7x32 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® Nom. Wall Thickness (in.) LS PVC - Low Smoke Polyvinyl Chloride 0.017 Overall Cable Overall Nominal Diameter: 0.153 in. Pair Pair Color Code Chart: Number Color 1 Red & Black 2 Green & White Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +90°C Bulk Cable Weight: 19 lbs/1000 ft. Max. Recommended Pulling Tension: 46 lbs. Min. Bend Radius/Minor Axis: 1.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP NEC Articles: 800 CEC/C(UL) Specification: CMP Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82723 Multi-Conductor - Double-Pair Cable EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 8723 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 36 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 43 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 75 Nominal Velocity of Propagation: VP (%) 62 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.7 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C temperature rise 2.3 Amps per conductor @25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 82723 877U1000 1,000 FT 20.000 LB NATURAL Notes Item Desc 2 PR #22 FEP FS FLRST 82723 877U2000 2,000 FT 40.000 LB NATURAL 2 PR #22 FEP FS FLRST 82723 877U500 500 FT 10.500 LB NATURAL 82723 8771000 1,000 FT 20.000 LB NATURAL 82723 8775000 5,000 FT 100.000 LB NATURAL 2 PR #22 FEP FS FLRST C 2 PR #22 FEP FS FLRST 2 PR #22 FEP FS FLRST Notes: C = CRATE REEL PUT-UP. Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82723 Multi-Conductor - Double-Pair Cable Revision Number: 3 Revision Date: 08-02-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
82723 877U1000 价格&库存
很抱歉,暂时无法提供与“82723 877U1000”相匹配的价格&库存,您可以联系我们找货
