83006 0061000
83006 0061000
    BELDEN
    BELDEN - 83006 0061000 - HOOK-UP WIRE, 1000FT, 22AWG CU, BLUE
83006 0061000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 83006 Hook-up/Lead - UL AWM Style 1213 For more Information please call 1-800-Belden1 Description: Stranded silver-coated copper conductor insulation with extruded TFE Teflon. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 22 19x34 SPC - Silver Plated Copper Insulation Insulation Material: Insulation Material Wall Thickness (mm) TFE - Tetrafluoroethylene 0.254 Overall Insulation Overall Cabling Overall Nominal Diameter: 1.270 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: 1213 UL Rating: 105°C EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-16878/4 (Except For Stranding) MIL Spec Rating: 600 V, 200°C Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Related Documents: No related documents are available for this product Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 83006 001100 30 MT 0.181 KG BROWN E #22 STR TFE BRN Page 1 of 2 05-10-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 83006 Hook-up/Lead - UL AWM Style 1213 83006 0011000 305 MT 1.814 KG BROWN ES #22 STR TFE BRN 83006 001500 152 MT 0.907 KG BROWN ES #22 STR TFE BRN 83006 002100 30 MT 0.181 KG RED E #22 STR TFE RED 83006 0021000 305 MT 1.814 KG RED 83006 002500 152 MT 0.907 KG RED ES #22 STR TFE RED 83006 003100 30 MT 0.181 KG ORANGE E #22 STR TFE ORG 83006 0031000 305 MT 1.814 KG ORANGE ES #22 STR TFE ORG 83006 004100 30 MT 0.181 KG YELLOW E #22 STR TFE YEL 83006 0041000 305 MT 1.814 KG YELLOW ES #22 STR TFE YEL 83006 004500 152 MT 0.907 KG YELLOW ES #22 STR TFE YEL 83006 005100 30 MT 0.181 KG GREEN, DARK E #22 STR TFE GRNDK 83006 0051000 305 MT 1.814 KG GREEN, DARK ES #22 STR TFE GRNDK 83006 005500 152 MT 0.907 KG GREEN, DARK ES #22 STR TFE GRNDK 83006 006100 30 MT 0.181 KG BLUE, LIGHT E #22 STR TFE BLULT 83006 0061000 305 MT 1.814 KG BLUE, LIGHT ES #22 STR TFE BLULT 83006 006500 152 MT 0.907 KG BLUE, LIGHT ES #22 STR TFE BLULT 83006 007100 30 MT 0.181 KG VIOLET E #22 STR TFE VIO 83006 0071000 305 MT 1.814 KG VIOLET ES #22 STR TFE VIO 83006 008100 30 MT 0.181 KG GRAY E #22 STR TFE GRY 83006 0081000 305 MT 1.814 KG GRAY ES #22 STR TFE GRY 83006 009100 30 MT 0.181 KG WHITE E #22 STR TFE WHT 83006 0091000 305 MT 1.814 KG WHITE 83006 009500 152 MT 0.907 KG WHITE ES #22 STR TFE WHT 83006 010100 30 MT 0.181 KG BLACK E #22 STR TFE BLK 83006 0101000 305 MT 1.814 KG BLACK 83006 010500 152 MT 0.907 KG BLACK #22 STR TFE RED #22 STR TFE WHT #22 STR TFE BLK ES #22 STR TFE BLK Notes: E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25' S = STRIPING ADDERS FOR TYPES E AND EE: 123 STRIPES. MINIMUM ORDER10 Revision Number: 1 Revision Date: 05-14-2007 © 2011 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 2 of 2 05-10-2011
83006 0061000
PDF文档中包含以下信息: 1. 物料型号:型号为LTC6810。
2. 器件简介:LTC6810是一款同步开关稳压器控制器,用于管理多达6个DC-DC转换器。
3. 引脚分配:共有40个引脚,包括电源引脚、控制引脚和通信引脚。
4. 参数特性:包括工作电压范围、工作温度范围、静态电流等。
5. 功能详解:详细介绍了LTC6810的工作原理和功能,如同步开关控制、电流平衡等。
6. 应用信息:适用于需要高效率和高功率密度的场合,如服务器、通信设备等。
7. 封装信息:采用40引脚的TSSOP封装。
83006 0061000 价格&库存
很抱歉,暂时无法提供与“83006 0061000”相匹配的价格&库存,您可以联系我们找货
  • 305+11.82535305+1.52550
  • 610+10.33623610+1.33340
