Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
83267 Coax - 75 Ohm Coax
For more Information
please call
1-800-Belden1
Description:
75 ohm, 30 AWG stranded (7x38) .012" silver-plated copper-covered steel conductor, TFE Teflon®
insulation, silver-plated copper braid shield (95% coverage), TFE tape jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
30
7x38
Dia. (mm)
SPCCS - Silver Plated Copper Covered Steel 0.3048
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Teflon®
Dia. (mm)
TFE - Tetrafluoroethylene 1.6002
Outer Shield
Outer Shield Material:
Type Outer Shield Material
Coverage (%)
Braid SPC - Silver Plated Copper 95
Outer Jacket
Outer Jacket Material:
Outer Jacket Trade Name Outer Jacket Material
Teflon®
Overall Cabling
Overall Nominal Diameter:
2.616 mm
Mechanical Characteristics (Overall)
Operating Temperature Range:
-70°C To +200°C
Non-UL Temperature Rating:
200°C
Bulk Cable Weight:
16.370 Kg/Km
Max. Recommended Pulling Tension:
80.068 N
Min. Bend Radius (Install)/Minor Axis:
25.400 mm
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Page 1 of 3
05-10-2011
Military Specification:
MIL-C-17D
RG Type:
187A/U
Flame Test
UL Flame Test:
VW-1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm) Tolerance (Ohms)
75
±3
Nom. Inductance:
Inductance (µH/m)
0.3281
Nom. Capacitance Conductor to Shield:
Capacitance (pF/m)
63.9795
Nominal Velocity of Propagation:
VP (%)
69.5
Nominal Delay:
Delay (ns/m)
4.72464
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/km)
800.564
Nominal Outer Shield DC Resistance:
DCR @ 20°C (Ohm/km)
28.2166
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100m)
1
9.843
10
17.3893
50
27.8885
100
32.81
200
41.0125
400
52.496
700
64.6357
900
73.1663
1000
78.744
Max. Operating Voltage - Non-UL:
Voltage
900 V RMS
Notes (Overall)
Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
Related Documents:
No related documents are available for this product
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Page 2 of 3
Notes
Item Desc
05-10-2011
83267 009100
30 MT
0.862 KG
WHITE
E
#30 COAX RG-187A/U
83267 0091000
305 MT
4.990 KG
WHITE
E
#30 COAX RG-187A/U
Notes:
E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25'
Revision Number: 1
Revision Date: 04-25-2008
© 2011 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications
described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not
ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the
compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and
the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide
for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not
to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
Page 3 of 3
05-10-2011
很抱歉,暂时无法提供与“83267 009100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+50.01267100+6.41719
