8336-CHR-100
8336-CHR-100
    BELDEN
    8336-CHR-100
8336-CHR-100 数据手册
Product: 8336 RS232, Low Cap, #24-6pr, SR-PVC, O/A Foil+Braid, PVC Jkt, CMG Product Description Computer EIA RS-232 Cable, 6-Pair, 24 AWG stranded (7x32) tinned copper conductors, semi-rigid PVC insulation, overall Beldfoil® (100% coverage) + tinned copper braid shield (65% coverage), PVC jacket. Technical Specifications Product Overview RS-232 extended distance applications; computer communications; low voltage analog signals (4-20ma, 0-10v, ...); low voltage digital control (24v, …); line level audio; panel wiring Suitable Applications: Physical Characteristics (Overall) Conductor Element AWG Stranding Pair(s) 24 7x32 Material No. of Pairs TC - Tinned Copper 6 Conductor Count: 12 Insulation Element Pair(s) Material Nominal Wall Thickness S-R PVC - Semi-Rigid Polyvinyl Chloride 0.0105 in Color Chart Number Color 1 White/Blue Stripe & Blue/White Stripe 2 White/Orange Stripe & Orange/White Stripe 3 White/Green Stripe & Green/White Stripe 4 White/Brown Stripe & Brown/White Stripe 5 White/Gray Stripe & Gray/White Stripe 6 Red/Blue Stripe & Blue/Red Stripe Outer Shield Material Type Layer Material Tape 1 Alum / Poly Braid 2 TC - Tinned Copper Material Trade Name Coverage [%] Beldfoil® 100 % 65 % Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.310 in 0.035 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 24 Ohm/1000ft 4.7 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 30 pF/ft 50 pF/ft Impedance Nominal Characteristic Impedance 75 Ohm Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] 60 ns/100m 60 % Current Max. Recommended Current [A] 1.6 Amps per conductor @ 25°C ambient Voltage UL Description UL Voltage Rating CMG 300 V UL AWM 2464 300 V Temperature Range UL Temp Rating: 80°C (UL AWM 2464) Operating Temp Range: -30°C to +80°C Mechanical Characteristics Bulk Cable Weight: 57 lbs/1000ft Max Recommended Pulling Tension: 95 lbs Min Bend Radius/Minor Axis: 3.25 in Standards NEC Articles: 800 NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG UL AWM Style: 2464 CSA AWM Specification: AWM I A CPR Euroclass: Eca Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-10-01 MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 FT4 Loading CSA Flammability: FT4 ISO/IEC Flammability: IEC 60332-1-2 UL voltage rating: 300 V Plenum/Non-Plenum Plenum (Y/N): Part Number No Variants Item # Color Putup Type Length UPC 8336 060100 Chrome Reel 100 ft 612825204510 8336 060500 Chrome Reel 500 ft 612825204534 8336 0601000 Chrome Reel Footnote: 1,000 ft 612825204527 C - CRATE REEL PUT-UP. History Update and Revision: Revision Number: 0.243 Revision Date: 05-27-2020 © 2020 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
8336-CHR-100 价格&库存
很抱歉,暂时无法提供与“8336-CHR-100”相匹配的价格&库存,您可以联系我们找货
