8916 0014000
8916 0014000
    BELDEN
    HOOK-UP 14AWG STR BRN
8916 0014000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8916 Hook-up/Lead - UL AWM Style 1015 For more Information please call 1-800-Belden1 General Description: 14 AWG stranded (41x30) tinned copper conductor, PVC insulation. Rated 105ºC, 600V. Rated 2500V peak for electronic circuits, and internal wiring of electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 14 41x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Min. Avg. Wall (in.) PVC - Polyvinyl Chloride 0.033 0.030 Overall Insulation Overall Cable Overall Nominal Diameter: 0.138 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 19 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600 V, 105°C UL Type: MTW or TW CSA Rating: 600 V, 105°C CSA Type: AWM I A/B or TEW EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.400 Max. Operating Voltage - UL: Voltage 600 VRMS Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8916 Hook-up/Lead - UL AWM Style 1015 Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient. 39 amps Put Ups and Colors: Item # Putup Ship Weight Color 8916 001100 100 FT 2.700 LB BROWN Notes Item Desc 8916 0014000 4,000 FT 80.000 LB BROWN 8916 001500 500 FT 10.500 LB BROWN 8916 002100 100 FT 2.700 LB RED 8916 0024000 4,000 FT 80.000 LB RED 8916 002500 500 FT 10.500 LB RED 14 STR PVC RED 8916 003100 100 FT 2.700 LB ORANGE 14 STR PVC ORG 8916 003500 500 FT 10.500 LB ORANGE 14 STR PVC ORG 8916 004100 100 FT 2.700 LB YELLOW 14 STR PVC YEL 8916 004500 500 FT 10.500 LB YELLOW 14 STR PVC YEL 8916 005100 100 FT 2.700 LB GREEN, DARK 8916 0054000 4,000 FT 80.000 LB GREEN, DARK 8916 005500 500 FT 10.500 LB GREEN, DARK 8916 007500 500 FT 10.500 LB VIOLET P '14 STR PVC VIO 8916 008500 500 FT 10.500 LB GRAY P #14 STR PVC GRY 8916 009100 100 FT 2.700 LB WHITE 14 STR PVC WHT 8916 009500 500 FT 10.500 LB WHITE 14 STR PVC WHT 8916 010100 100 FT 2.700 LB BLACK 8916 0104000 4,000 FT 80.000 LB BLACK 8916 010500 500 FT 10.500 LB BLACK 14 STR PVC BLK 8916 013100 100 FT 2.700 LB BLUE, DARK 14 STR PVC D BLU 8916 013500 500 FT 10.500 LB BLUE, DARK 8916 189100 100 FT 2.700 LB GREEN/YELLOW A 14 STR PVC GRN/YEL 8916 189500 500 FT 10.500 LB GREEN/YELLOW A 14 STR PVC GRN/YEL 14 STR PVC BRN CP 14 STR PVC BRN 14 STR PVC BRN 14 STR PVC RED CP 14 STR PVC RED 14 STR PVC D GRN CP 14 STR PVC DGRN 14 STR PVC D GRN 14 STR PVC BLK C #14 STR PVC BLK 14 STR PVC D BLU Notes: A = STOCKED STRIPE COLORS. C = CRATE REEL PUT-UP. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 1 Revision Date: 04-23-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8916 0014000 价格&库存
很抱歉,暂时无法提供与“8916 0014000”相匹配的价格&库存,您可以联系我们找货
