Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
89248 Coax - 75 Ohm Coax
For more Information
please call
1-800-Belden1
General Description:
18 AWG solid .040" bare copper conductor, plenum, foam FEP insulation, Duofoil® + tinned copper braid
shield (65% coverage), FEP jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
1
18
Solid
BC - Bare Copper
.040
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
FFEP - Foam Fluorinated Ethylene Propylene .170
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Duofoil®
2
Coverage (%)
Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100
Braid TC - Tinned Copper
65
Outer Jacket
Outer Jacket Material:
FEP - Fluorinated Ethylene Propylene
Overall Cable
Overall Nominal Diameter:
0.222 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-70°C To +200°C
Non-UL Temperature Rating:
200°C
Bulk Cable Weight:
30 lbs/1000 ft.
Max. Recommended Pulling Tension:
45 lbs.
Min. Bend Radius/Minor Axis:
3 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMP
CEC/C(UL) Specification:
CMP
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
6/U
Page 1 of 3
01-05-2017
Flame Test
UL Flame Test:
NFPA 262
CSA Flame Test:
FT6
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Suitability - Aerial:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
Yes
Non-Plenum Number:
9248
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
.09
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
16.5
Nominal Velocity of Propagation:
VP (%)
82
Nominal Delay:
Delay (ns/ft)
1.24
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
6.4
Nominal Outer Shield DC Resistance:
5.1
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
.3
10
.7
50
1.5
100
2.1
200
3.1
400
4.5
700
6.0
900
6.9
1000
7.3
Max. Operating Voltage - UL:
Voltage
300 V RMS
Minimum Return Loss:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5
450
23
Notes (Overall)
Notes: 100% Sweep tested 5 MHz to 450 MHz.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
89248 0101000
1,000 FT
33.000 LB
BLACK
C
#18 FFEP RG 6/U COAX
89248 0102000
2,000 FT
64.000 LB
BLACK
C
89248 010500
500 FT
16.500 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Page 2 of 3
01-05-2017
Revision Number: 1
Revision Date: 05-14-2007
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“89248 0102000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+76.411162000+9.88495
