9223 010500
9223 010500
    BELDEN
    CABLE COAX RG-R8/U 22 AWG 500
9223 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9223 Coax - Low Noise For more Information please call 1-800-Belden1 General Description: Low noise, RG-58/U Type, 22 AWG stranded (7x30) .030" TC conductor, polyethylene insulation, conductive layer, Duobond® II + TC braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 22 7x30 TC - Tinned Copper .030 Total Number of Conductors: 1 Insulation Insulation Material: Layer # Insulation Material Dia. (in.) 1 CPE - Conductive Polyethylene 0.036 2 PE - Polyethylene 0.112 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.195 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 24 lbs/1000 ft. Max. Recommended Pulling Tension: 8.850 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 58/U Flame Test UL Flame Test: UL1685 UL Loading, VW-1 Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9223 Coax - Low Noise Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 37.0 Nominal Velocity of Propagation: VP (%) 56 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.8 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.1 Other Electrical Characteristic 1: NBS Low Noise Test (Modified), MIL-C-17 Paragraph 4.8.14, 8 mV Peak to Peak Max Max. Noise Level (Peak to Peak): 8 mV Notes (Overall) Notes: Not recommended for RF use Put Ups and Colors: Item # Putup Ship Weight Color 9223 010100 100 FT 3.100 LB BLACK Notes Item Desc 9223 0101000 1,000 FT 26.000 LB BLACK C #22 LOW NOISE COAX CABLE 9223 010500 500 FT 13.500 LB BLACK C #22 LOW NOISE COAX CABLE #22 LOW NOISE COAX CABLE Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 04-24-2008 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
9223 010500
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管集电极,6脚光电晶体管发射极。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备等领域。
7. 封装信息:采用DIP6封装形式。
9223 010500 价格&库存
很抱歉,暂时无法提供与“9223 010500”相匹配的价格&库存,您可以联系我们找货
