9318-0500
9318-0500
    BELDEN
    TEMP & HUMIDITY MONITOR MINI
9318-0500 数据手册
Part Number: 9318 300V PLTC, (1 pr) 18 AWG (19x30) TC, PVC/PVC, Foil Shld, CMG Product Description One 18 AWG pair stranded (19x30) tinned copper conductors, PVC insulation, overall Beldfoil® shield (100% coverage), PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 18 19x30 Material No. of Pairs TC - Tinned Copper 1 Conductor Count: 2 Total Number of Pairs: 1 Total Number of Triads: N/A Conductor Size: 18 AWG Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.017 in Color Chart Number 1 Color Black & Red Outer Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 20 19x32 mm Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness Ripcord PVC - Polyvinyl Chloride 0.233 in 0.037 in Yes Construction and Dimensions LEGEND: BELDEN 9318 E34972 1PR18 SHIELDED (UL) CL3R 105C OR PLTC OR ITC SUN RES OR AWM 2464 80C 300V ----FT4 (2 FT, 7 DIGIT SEQUENTIAL NUMBER) FEET Print Legend: Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 5.96 Ohm/1000ft 9 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Shield 54 pF/ft Shielding: Inductance Nominal Inductance 0.17 µH/ft 100 pF/ft Foil(s) or Copper Tape(s) Current Max. Recommended Current [A] 5.5 Amps per conductor @ 25°C A Voltage UL Description UL Voltage Rating PLTC, CMG 300V RMS ITC 150 V RMS Temperature Range UL Temp Rating: 105°C Operating Temp Range: -30°C To +105°C Mechanical Characteristics Bulk Cable Weight: 32 lbs/1000ft Max Recommended Pulling Tension: 26 lbs Min Bend Radius/Minor Axis: 2.23 in Standards NEC/(UL) Specification: CMG, ITC-ER, PLTC-ER CEC/C(UL) Specification: CMG UL AWM Style: UL Style 2464 (300 V 80°C) Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Sunlight Resistance: Yes Flammability, LS0H, Toxicity Testing C(UL) Flammability: FT4 UL Flammability: UL1685 UL Loading IEEE Flammability: 1202 UL Voltage Rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # Color Footnote 9318 0601000 CHROME 9318 06010000 CHROME C Z 9318 06015000 CHROME C Y 9318 0605000 CHROME C Z 9318 060U1000 CHROME 9318 060U500 CHROME Footnote: C - CRATE REEL PUT-UP. Footnote: Z - FINAL PUT-UP MAY VARY (= OR -) 10% FOR SPOOLS OR REELS AND (+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Footnote: Y - FINAL PUT-UP LENGTH MAY VAR -10% TO +20% FROM LENGTH SHOWN. MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
9318-0500 价格&库存
很抱歉,暂时无法提供与“9318-0500”相匹配的价格&库存,您可以联系我们找货
