9412 0601000
9412 0601000
    BELDEN
    CBLE 1PR 12AWG
9412 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9412 Multi-Conductor - 300V Power-Limited Tray Cable For more Information please call 1-800-Belden1 General Description: 12 AWG pairs stranded (65x30) tinned copper conductors, twisted pairs, PVC insulation, unshielded, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 12 65x30 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PVC - Polyvinyl Chloride .143 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .042 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.370 in. Pair Pair Color Code Chart: Number Color 1 Black & Red Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 76 lbs/1000 ft. Max. Recommended Pulling Tension: 197 lbs. Min. Bend Radius/Minor Axis: 3.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL3R, ITC-ER, PLTC-ER EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: 1202 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9412 Multi-Conductor - 300V Power-Limited Tray Cable MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading C(UL) Flame Test: FT4 Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 25 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.8 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Operating Voltage - Other: Voltage Description 25 KV RMS Nominal breakdown voltage between conductors Max. Recommended Current: Current 17 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9412 0601000 1,000 FT 84.000 LB CHROME C 2 #12 PVC PVC 9412 0602500 2,500 FT 207.500 LB CHROME Z 2 #12 PVC PVC 9412 060500 500 FT 42.000 LB CHROME C 2 #12 PVC PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 05-17-2015 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
9412 0601000
物料型号:9412 Multi-Conductor - 300V Power-Limited Tray Cable
器件简介: - 电缆由12 AWG的65x30股镀锡铜导体构成,成对绞合,PVC绝缘,无屏蔽,PVC外护套。
引脚分配: - 电缆总导体数为2对,颜色编码为黑色和红色。
参数特性: - 工作温度范围:-30°C 至 +105°C - 电缆重量:76磅/1000英尺 - 最大推荐拉力:197磅 - 最小弯曲半径/次轴:3.750英寸
功能详解: - 适用标准和机构合规性: - NEC/(UL)规范:CL3R, ITC-ER, PLTC-ER - 欧盟指令2011/65/EU(ROHS II):是 - IEEE规范:1202 - 欧盟CE标志:是 - 欧盟指令2000/53/EC(ELV):是 - 欧盟指令2002/95/EC(RoHS):是 - 欧盟RoHS合规日期:04/01/2005 - 欧盟指令2002/96/EC(WEEE):是 - 欧盟指令2003/11/EC(BFR):是 - 加州65号提案(CJ for Wire & Cable):是 - 电气特性: - 标称电感:未提供具体数值 - 标称电容:未提供具体数值 - 标称导体直流电阻:在20°C下,每1000英尺的电阻值未提供具体数值 - 最大工作电压 - UL:300 V RMS - 最大推荐电流:25°C时每导体17安培
应用信息: - 电缆适用于多种环境,包括阳光照射下,但不适合作为管道电缆。
封装信息: - 电缆的包装和颜色:有1000英尺、2500英尺和500英尺的包装,重量分别为84.000磅、207.500磅和42.000磅,颜色为铬色。
9412 0601000 价格&库存
很抱歉,暂时无法提供与“9412 0601000”相匹配的价格&库存,您可以联系我们找货
