9572.00305
9572.00305
    BELDEN
    BELDEN - 9572.00305 - Multipair Cable, Unscreened, 1 Pair, 16 AWG, 305 ft, 93 m
9572.00305 数据手册
Part Number: 9572 Power-Limited Fire Protective, (2) 16 AWG Solid BC, PVC/PVC, CMR Product Description Two 16 AWG solid bare copper conductors, PVC insulation, PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 16 Solid Material No. of Conductors BC - Bare Copper 2 Conductor Count: 2 Total Number of Pairs: 1 Conductor Size: 16 AWG Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.016 in Color Chart Number Color 1 Black 2 Red Outer Shield Material Material Unshielded Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.238 in 0.036 in Construction and Dimensions Cabling Lay Direction Twists Left Hand 6 twist/ft Electrical Characteristics Conductor DCR Nominal Conductor DCR 4.1 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor 28 pF/ft Shielding: Inductance Nominal Inductance Unshielded 0.15 µH/ft Current Element Max. Recommended Current [A] 35C Temperature Rise 11 Amps per conductor @ 25°C Voltage UL Voltage Rating 300 V RMS Temperature Range UL Temp Rating: 105°C Operating Temp Range: -40°C To +105°C Mechanical Characteristics Bulk Cable Weight: 31 lbs/1000ft Max Recommended Pulling Tension: 78 lbs Min Bend Radius/Minor Axis: 2.5 in Standards NEC Articles: 760, 800 NEC/(UL) Specification: CMR, FPLR CEC/C(UL) Specification: FAS105 UL AWM Style: UL Style 2464 (300 V 80°C) CPR Euroclass: Eca Other Specification: California State Fire Marshall Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1666 Vertical Shaft CSA Flammability: FT4 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # Color 9572.00305 Red 9572.00U305 Red 9572 002U1000 Red 9572 002U500 Red © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
9572.00305 价格&库存
很抱歉,暂时无法提供与“9572.00305”相匹配的价格&库存,您可以联系我们找货
