9659 010U500
9659 010U500
    BELDEN
    RG59/U TYPE COAX
9659 010U500 数据手册
Part Number: 9659 Analog Video, RG59, #22 Str BC, 95% BC Braid, PVC Jacket, CMX Product Description 22 AWG stranded (7x30) .030" bare copper conductor, foam polyethylene insulation, bare copper braid shield (95% coverage), PVC jacket. Technical Specifications Product Overview Environmental Space: Indoor/Outdoor Physical Characteristics (Overall) Conductor AWG Stranding 22 7x30 Material Nominal Diameter No. of Coax BC - Bare Copper 0.03 in 1 Conductor Count: 1 AWG Size: 22 Insulation Material Nominal Diameter FPE - Foamed Polyethylene 0.146 in Outer Shield Material Type Material Coverage [%] Braid BC - Bare Copper 95 % Outer Jacket Material Material Nominal Diameter PVCNC - Polyvinyl Chloride Non-Contaminating 0.242 in Electrical Characteristics Conductor DCR Nominal Conductor DCR 15 Ohm/1000ft Nominal Conductor DCR Conductor Resistance Nominal Outer Shield DCR Outer Conductor DCR 15 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 17.3 pF/ft Inductance Nominal Inductance 0.09 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] Minimum Return (RL) 5-450 MHz 23 dB 2.6 Ohm/1000ft 2.6 Ohm/1000ft High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.3 dB/100ft 10 MHz 0.9 dB/100ft 50 MHz 2.1 dB/100ft 100 MHz 3 dB/100ft 200 MHz 4.5 dB/100ft 400 MHz 6.6 dB/100ft 700 MHz 8.9 dB/100ft 900 MHz 10.1 dB/100ft 1000 MHz 10.9 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.3 ns/ft 78 % Voltage Non-UL Voltage Rating UL Voltage Rating 300 V RMS 150 V RMS Temperature Range Operating Temp Range: -40°C To +80°C Mechanical Characteristics Bulk Cable Weight: 35 lbs/1000ft Max Recommended Pulling Tension: 65 lbs Min Bend Radius/Minor Axis: 2.5 in Standards NEC/(UL) Specification: CMX CEC/C(UL) Specification: CMX UL AWM Style: UL Style 1354 (30 V 60°C) RG Type: RG-59/U Type Series Type: Series 59 Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-10-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: VW-1 CSA Flammability: FT1 Part Number Plenum (Y/N): Product Notes No Notes: For CCTV Applications. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
9659 010U500 价格&库存
很抱歉,暂时无法提供与“9659 010U500”相匹配的价格&库存,您可以联系我们找货
