9708 368U500
9708 368U500
    BELDEN
    2#18 PVC PARALLEL
9708 368U500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9708 Multi-Conductor - High-Conductivity Copper Speaker Cable Parallel Zip Const For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) ETP high-conductivity copper conductors, PVC insulation, parallel: (1) tinned, (1) bare. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 16x30 High Conductivity TC - Tinned Copper 1 18 16x30 High Conductivity BC - Bare Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .032 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.110 x 0.220 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 19 lbs/1000 ft. Max. Recommended Pulling Tension: 50 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9708 Multi-Conductor - High-Conductivity Copper Speaker Cable Parallel Zip Const Inductance (µH/ft) .22 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.48 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Max. Recommended Current: Current 4.2 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 9708 368U1000 1,000 FT 21.000 LB CLEAR, TRANSPARENT Notes 9708 368U500 500 FT 11.000 LB CLEAR, TRANSPARENT 9708 3681000 1,000 FT 21.000 LB CLEAR, TRANSPARENT 9708 368500 500 FT 10.500 LB CLEAR, TRANSPARENT Item Desc 2#18 PVC PARALLEL 2#18 PVC PARALLEL C 2#18 PVC PARALLEL 2#18 PVC PARALLEL Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 06-29-2011 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
9708 368U500
PDF文档中包含了以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为集电极,6脚为发射极。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:常用于电源、通信、工业控制等领域。
7. 封装信息:EL817采用DIP-6封装。
9708 368U500 价格&库存
很抱歉,暂时无法提供与“9708 368U500”相匹配的价格&库存,您可以联系我们找货
