9907 E4X2500
9907 E4X2500
    BELDEN
    RG-58 TYPE COAX
9907 E4X2500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9907 Coax - Coaxial Cable - Thinnet 10Base2 Ethernet For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (19x32) .037" tinned copper conductor, foam polyethylene insulation, Duobond® II (100% coverage) plus an overall tinned copper braid shield (93% coverage), PVC jacket. Usage (Overall) Suitable Applications: Thin Ethernet Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 20 19x32 TC - Tinned Copper 0.9398 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) FHDPE - Foam High Density Polyethylene 2.5908 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 93 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 4.699 mm Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 60°C (UL AWM Style 1354) Bulk Cable Weight: 34.229 Kg/Km Max. Recommended Pulling Tension: 200.169 N Min. Bend Radius/Minor Axis: 50.800 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2, CM CEC/C(UL) Specification: CM AWM Specification: UL Style 1354 (30 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9907 Coax - Coaxial Cable - Thinnet 10Base2 Ethernet IEEE Specification: IEEE802.3 10Base2 Other Standards: ISO8802.3 10Base2 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: DEC Part No. 17-01248-00 RG Type: 58A/U Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 82907, 89907 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) Tolerance (Ohms) 50 +/- 2 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 83.3374 Nominal Velocity of Propagation: VP (%) 80 Nominal Delay: Delay (ns/m) 4.16687 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 28.8728 Maximum Loop Resistance: Resistance (Ohm/km) 50.0024 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 19.0298 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 1.41083 10 4.2653 50 9.54771 100 13.7802 200 20.0141 400 29.2009 700 39.7001 Page 2 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9907 Coax - Coaxial Cable - Thinnet 10Base2 Ethernet 900 45.6059 1000 48.5588 Max. Operating Voltage - UL: Voltage Description 300 V RMS 30 V RMS UL AWM Style 1354 Notes (Overall) Notes: Tape to bond at overlap area only. Tape is not designed to bond to dielectric core. Put Ups and Colors: Item # Putup Ship Weight Color 9907 E4XU1000 305 MT 10.886 KG GRAY, LIGHT DEC Notes Item Desc 9907 E4X1000 305 MT 11.340 KG GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X1640 500 MT 18.597 KG GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X2500 762 MT 28.350 KG GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X3280 1,000 MT 37.195 KG GRAY, LIGHT DEC C RG-58 TYPE COAX 9907 E4X500 152 MT 5.670 KG GRAY, LIGHT DEC RG-58 TYPE COAX 9907 E4X5000 1,524 MT 56.699 KG GRAY, LIGHT DEC RG-58 TYPE COAX RG-58 TYPE COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 09-25-2012 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
9907 E4X2500 价格&库存
很抱歉,暂时无法提供与“9907 E4X2500”相匹配的价格&库存,您可以联系我们找货
