A0644492
A0644492
    BELDEN
    2U ORGANIZER PANEL
A0644492 数据手册
O P E N F R A M E R A C K S & A C C E S S O R I E S 12.6 Open Frame Rack Accessories & Cable/Cord Management Units Extender Brackets, Filler Panels, Patch Cord Organizers Rack Extenders Open Frame Rack Extender Brackets The Open Frame Rack Extender Brackets are used to extend a 19″ Panel/Equipment Mounting for 23″. Description 19″ Filler Panels 1U 23″ EIA To 19″ EIA Extender Bracket 2U 23″ EIA To 19″ EIA Extender Bracket 3U 23″ EIA To 19″ EIA Extender Bracket 4U 23″ EIA To 19″ EIA Extender Bracket Belden Part Number B9810-0100 B9811-0200 B9812-0300 B9813-0400 Filler Panels Filler Panels are available in solid or vented for improved air flow. B9511-1902 Description B9510-1901 B9512-1901 1U 19″ Solid Filler Panel, Gray 2U 19″ Solid Filler Panel, Gray 1U 19″ Solid Filler Panel, Black 2U 19″ Solid Filler Panel, Black 3U 19″ Solid Filler Panel, Black 4U 19″ Solid Filler Panel, Black 2U 19″ Vented Filler Panel, Black 3U 19″ Vented Filler Panel, Black 4U 19″ Vented Filler Panel, Black Belden Part Number A0644497 A0644499 B9910-0100 B9911-0200 B9912-0300 B9913-0400 B9914-0200 B9915-0300 B9916-0400 Patch Cord Organizers The Patch Cord Organizers keep wires and cable under control. Among the many features of the Patch Cord Organizers are: ■ Horizontal / Vertical Patch Cord Management ■ Front / Rear Management ■ Removable Covers ■ Bend Radius Control Top: B9512-1902 Bottom: B9512-1902 Description 1U 19″ Cable Organizer 2U 19″ Cable Organizer with Saddle Rings 1U 19″ Rack Mount Cable Organizer with Finger Stock and Cover (1.5″ x 2″) 2U 19″ Rack Mount Cable Organizer with Finger Stock and Cover (3″ x 3″) 2U 19″ Cable Organizer with Finger Stock and Cover Front and Rear 2U 19″ Cable Organizer with Quick Touch (2″ X 3″) 1U 19″ Cable Organizer with Radius (Waterfall) 1U 23″ Cable Organizer 2U 23″ Cable Organizer with Saddle Rings Belden Part Number B9510-1901 B9511-1902 B9512-1901 B9512-1902 B9512-1902-FR B9513-1902 B9514-1901 B9610-2301 B9611-2302 These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m O P E N F R A M E R A C K S & A C C E S S O R I E S 12.7 Open Frame Rack Accessories & Cable/Cord Management Units Ring Panels, Organizer Trays, Brackets & Patch Cord Channel AX100249 Organizer Tray, 3U Open Frame Rack Cable and Patch Cord Management The Open Frame Rack Cable and Patch Cord Management accessories can be used with patch panels in open frame racks for distribution cable and patch cord organization, routing and protection. They allow easier cord access and simplify moves, additions and changes. Description AX100463 Rear Cable Bracket AX101173 Cable Tie Bar AX100789 Cable Support Bracket Organizer Ring Panel, Gray Organizer Ring Panel, Black Organizer Panel, Gray Organizer Panel, Black Organizer Panel, Gray Organizer Panel, Black Organizer Tray, Gray Organizer Tray, Black Rear Cable Bracket, Gray Rear Cable Bracket, Black Cable Support Bracket, Gray Cable Support Bracket, Black Patch Cord Organizer Channel, Gray Patch Cord Organizer Channel, Black Patch Cord Organizer Channel, Gray Patch Cord Organizer Channel, Black Patch Cord Organizer Channel, Gray Patch Cord Organizer Channel, Black Cable Tie Bar, Black Mounting Belden Part Number 2U 2U 1U 1U 2U 2U 3U 3U A0396695 A0403977 A0644488 A0644489 A0644490 A0644492 AX100248 AX100249 AX100462 AX100463 AX100788 AX100789 AX100792 AX100793 AX100794 AX100795 AX100796 AX100797 AX101173 0U 0U 1U 1U 2U 2U 4U 4U 0U These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. AX100793 Patch Cord Organizer Channel AO396695 Organizer Ring Panel, 2U 12 • Open Frame Racks AO644488 Organizer Panel, 1U F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m
A0644492
PDF文档包含了以下信息: - 物料型号:LT8610HV#PBF - 器件简介:LT8610HV 是一款具有集成 MOSFET 的同步降压型 DC/DC 转换器,适用于需要高效率和高电流输出的应用。
- 引脚分配:详细列出了各个引脚的功能和用途。
- 参数特性:包括输入电压范围、输出电压范围、最大输出电流等。
- 功能详解:介绍了LT8610HV的功能特点,如可调输出电压、可编程软启动等。
- 应用信息:提供了该器件适用的应用场景,如工业控制、医疗设备等。
- 封装信息:LT8610HV采用热增强型 16 引脚 3mm x 3mm QFN 封装。
A0644492 价格&库存
很抱歉,暂时无法提供与“A0644492”相匹配的价格&库存,您可以联系我们找货
