9V28026 000H100
9V28026 000H100
    BELDEN
    CBL RIBN 26COND VARI-TWIST
9V28026 000H100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9V28026 Flat - Vari-Twist® 9V280XX Series For more Information please call 1-800-Belden1 General Description: Belden^s PVC Vari-Twist series was designed to reduce crosstalk in the balanced mode by twisting the pairs, but can be mass-terminated in the flat sections with standard IDC connectors. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 13 28 7x36 TC - Tinned Copper Total Number of Conductors: 26 Conductor Spacing Center to Center Flat Section: .050 +/- .005 Conductor Spacing Outside Center to Outside Center: 1.25 +/- .015 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.018 Substrate Thickness and Material: .010 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Overall Cable Overall Nominal Thickness Flat Section: .042 +/- .003 Overall Nominal Thickness Twisted Section: .080 Overall Nominal Width: 1.326 Overall Flat Section Length: 2 Overall Twisted Length: 18 in. Flat Section Center to Center Spacing: 20 +/- .50 Pair Pair Color Code Chart: Number Color 1 Brown/Tan 2 Red/Tan 3 Orange/Tan 4 Yellow/Tan 5 Green/Tan 6 Blue/Tan 7 Purple/Tan 8 Gray/Tan 9 White/Tan 10 Black/Tan Over 10 pair Repeat as required Spacing Twisted Pair Spacing Center to Center: .100 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +105°C Bulk Cable Weight: 42 lbs/1000 ft. Min. Bend Radius/Minor Axis: 1.250 in. Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9V28026 Flat - Vari-Twist® 9V280XX Series Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: UL AWM Styles 1731, 2693, & 2697 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Description Inductance (µH/ft) @ 1 MHz .24 Nom. Capacitance Conductor to Conductor: Description Capacitance (pF/ft) @ 1 kHz 20 @ 1 MHz 16 Nominal Velocity of Propagation: Description VP (%) 64 Nominal Delay: Delay (ns/ft) 1.6 NS/FT. Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 68.2 OHMS/1000 FT. MAX. Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 10 3.5 20 5.5 30 7.2 40 8.8 50 10.2 60 12 70 13 80 14.2 90 15 100 16 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 1 Amp per conductor @ 20°C Nominal Balanced Characteristic Impedance: Description Impedance (Ohm) 115 Nominal Unbalanced Characteristic Impedance: Description Impedance (Ohm) 100 Dielectric Withstand Voltage: 2, 000 V RMS Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9V28026 Flat - Vari-Twist® 9V280XX Series Dielectric Withstand Voltage: 2, 000 V RMS Typical Balanced Crosstalk - dB Suppression: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Crosstalk (dB) 10 ft. sample length 10 100 35 Typical Unbalanced Crosstalk: Description Pulse Rise Time (NS) (MHz) Near End % (MHz) Far End % (MHz) 10 ft. sample length all grounds connected together. 3 5.8 5.2 10 ft. sample length all grounds connected together. 5 4 3.2 10 ft. sample length all grounds connected together. 7 2.5 2.8 Notes (Overall) Notes: The transition area is included in the twisted length to assure a full 2 inches of flat termination area. Kennedy Information (Overall) Construction: 18" of Twisted Pairs, 2" of Flat Section Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9V28026 000H100 100 FT 4.300 LB NONE E 13 PR #28 PVC VARI-TWIST Notes: E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25' Revision Number: 3 Revision Date: 11-08-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9V28026 000H100 价格&库存
很抱歉,暂时无法提供与“9V28026 000H100”相匹配的价格&库存,您可以联系我们找货
