AX101046
AX101046
    BELDEN
    CAT5E JACK MDVO WHITE
AX101046 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101046 Modular Connectors - CAT5E Modular Jack - MDVO style For more Information please call 1-800-Belden1 General Description: CAT5E Modular Jack, RJ45, MDVO style, White Usage (Overall) Suitable Applications: IBDN System 1200, TIA Category 5E, ISO Class D, 1000 BASE-T Related Parts: Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels Physical Characteristics (Connectivity) Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 0.765 0.770 1.290 Materials Materials: Description Type Material Front Connection Lead Frame Copper Allow with 50u inch Gold over Nickel Rear Connection IDC Copper Allow with Nickel Plating Connector Boby Plastic - UL940V-0 Color Color: White Wiring Scheme Wiring Scheme: T568A/B Weight Weight: 0.014 lbs. Included Parts Included Parts: 1 T-Bar + 1 Dust Cap Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Mechanical Characteristics (Connectivity) Footprint/Type: MDVO-Style Plug / Jack Compatibility: RJ45, RJ11 Termination Interface: Termination Connection Durabilities Front Mated Connection 1,000 cycles Rear Gas Tight IDC Connection 20 terminations Connector/Hardware Retention: 20 lbs. Plug/Connector Retention: 11.250 lbs. Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Tool Compatibility: Belden 110 Connecting Tool, MediaFlex Termination Station Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 MII Order #39 (China RoHS): EUP 50 Page 1 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101046 Modular Connectors - CAT5E Modular Jack - MDVO style Telecommunications Standards: Category 5e - TIA 568.B.2, Category 5 - ISO/IEC 11801:2002 Ed.2 Third Party Performance Verification: ETL - Verified Category 5e Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Mated Connection Table 1: Max. Min. Min. Min. Min. Frequency Max. Insertion Loss Insertion Loss NEXT NEXT FEXT FEXT (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 0.100 0.100 65.000 77.000 65.000 77.000 4.000 0.100 0.100 65.000 73.800 63.100 74.800 8.000 0.100 0.100 64.900 67.700 57.000 68.700 10.000 0.100 0.100 63.000 65.800 55.100 66.800 16.000 100.000 0.100 58.900 61.700 51.000 62.700 20.000 0.100 0.100 57.000 59.800 49.100 60.800 25.000 0.100 0.100 55.000 57.800 47.100 58.800 31.250 0.110 0.100 53.100 55.900 45.200 56.900 62.500 0.160 0.120 47.100 49.900 39.200 50.900 100.000 0.200 0.160 43.000 45.800 35.100 46.800 160.000 0.210 41.700 Mated Connection Table - Footnote: 42.700 * TIA/EIA-568-C.2 Category 5E Standard. ** Worst-case performance for a CAT5E mated connection using CAT5E modular plugs. Mated Connection Table 2: Min. Min. Frequency Min. Return Loss Return Loss Balanced TCL (MHz) TIA* (dB) Belden** (dB) Belden** (dB) 1.000 30.000 32.000 42.000 4.000 30.000 32.000 42.000 8.000 30.000 32.000 42.000 10.000 30.000 32.000 42.000 16.000 30.000 32.000 42.000 20.000 30.000 32.000 42.000 25.000 30.000 32.000 42.000 31.250 30.000 32.000 42.000 62.500 24.100 31.100 36.100 100.000 20.000 27.000 32.000 22.900 27.900 160.000 Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: Please see Installation Guide PX103329 Notes (Cont'd.): IDC Wire Gauge: 22~24 AWG Product Family Part Number List: Item Number Color AX101044 Gray AX101045 Almond AX101046 White AX101047 Black AX101048 Orange (TIA 606) AX101049 Red (TIA 606) AX101050 Yellow (TIA 606) AX101051 Green (TIA 606) AX101052 Blue (TIA 606) AX101053 Purple (TIA 606) Put Ups and Colors: Page 2 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101046 Modular Connectors - CAT5E Modular Jack - MDVO style Item # Putup Ship Weight AX101046 1 EA 0.024 LB Revision Number: 1 Color Notes Item Desc CAT5E JACK MDVO WHITE Revision Date: 08-14-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-27-2017
AX101046 价格&库存
很抱歉,暂时无法提供与“AX101046”相匹配的价格&库存,您可以联系我们找货
