C10GB-BC50
C10GB-BC50
    BELDEN
    BELDEN - C10GB-BC50 - Multicore Cable, Unscreened, 10 Core, 0.75 mm², 164 ft, 50 m
C10GB-BC50 数据手册
Technical Data Sheet – Unshielded (YY) PVC Control Cable MachFlex 375 YY FlexibleColour Coded PVC Control Cables Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • • DIN VDE 0295, IEC 60228, BS 6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 IEC 60227-5, EN 50525-2-51, VDE 0281-13 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS, REACH & CE Directives Construction & Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5 / IEC 60228 class 5) 2. Insulation Material & Colour PVC (polyvinyl chloride), VDE 0293-308 (colour) up to 5 cores: colour-coded according to VDE 0293-308, From 6 cores : Belden MachFlex colour code A) G = with GN-YE protective conductor OR B) X = without protective earth conductor 3. Jacket / Sheath Material PVC (polyvinyl chloride) 4. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 5. Voltage Rating (Uo/U) Up to 1.5 mm²: 300 / 500 V From 2.5 mm²: 450 / 750 V 6. Oil Resistant DIN EN 50290-2-22 (TM54) 1 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 7. Temperature Range -5°C TO +70°C (Occasional movement) -40°C TO +80°C (Fixed installation) 8. Bending Radius 15 x OD (Occasional movement) 4 x OD (Fixed installation) 9. Other Properties Good UV resistance, chemical resistance & flexibility TABLE A Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) C2XA 2 X0.5 2 0.5 4.8 30 C3XA 3 X0.5 3 0.5 5.1 38 C3GA 3 G0.5 3 0.5 5.1 38 C4XA 4 X0.5 4 0.5 5.6 48 C4GA 4 G0.5 4 0.5 5.6 48 C5XA 5 X0.5 5 0.5 6.2 59 C5GA 5 G0.5 5 0.5 6.2 59 C7XA 7 X0.5 7 0.5 6.8 74 C7GA 7 G0.5 7 0.5 6.8 74 C9XA 9 X0.5 9 0.5 8.4 99 C9GA 9 G0.5 9 0.5 8.4 99 C10XA 10 X0.5 10 0.5 8.8 109 C10GA 10 G0.5 10 0.5 8.8 109 C12XA 12 X0.5 12 0.5 9.1 125 C12GA 12 G0.5 12 0.5 9.1 125 C14XA 14 X0.5 14 0.5 9.6 143 C14GA 14 G0.5 14 0.5 9.6 143 C16XA 16 X0.5 16 0.5 10.2 162 C16GA 16 G0.5 16 0.5 10.2 162 C18XA 18 X0.5 18 0.5 10.8 183 C18GA 18 G0.5 18 0.5 10.8 183 C20XA 20 X0.5 20 0.5 11.4 203 C20GA 20 G0.5 20 0.5 11.4 203 C2XB 2 X0.75 2 0.75 5.3 39 C3XB 3 X0.75 3 0.75 5.6 49 2 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable C3GB 3 G0.75 3 0.75 5.6 49 C4XB 4 X0.75 4 0.75 6.2 62 C4GB 4 G0.75 4 0.75 6.2 62 C5XB 5 X0.75 5 0.75 6.8 77 C5GB 5 G0.75 5 0.75 6.8 77 C7XB 7 X0.75 7 0.75 7.5 98 C7GB 7 G0.75 7 0.75 7.5 98 C9XB 9 X0.75 9 0.75 9.3 131 C9GB 9 G0.75 9 0.75 9.3 131 C10XB 10 X0.75 10 0.75 9.8 144 C10GB 10 G0.75 10 0.75 9.8 144 C12XB 12 X0.75 12 0.75 10.1 165 C12GB 12 G0.75 12 0.75 10.1 165 C14XB 14 X0.75 14 0.75 10.7 190 C14GB 14 G0.75 14 0.75 10.7 190 C16XB 16 X0.75 16 0.75 11.3 216 C16GB 16 G0.75 16 0.75 11.3 216 C18XB 18 X0.75 18 0.75 12.0 243 C18GB 18 G0.75 18 0.75 12.0 243 C20XB 20 X0.75 20 0.75 12.7 270 C20GB 20 G0.75 20 0.75 12.7 270 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) C2XC 2 X1.0 2 1.0 5.7 47 C3XC 3 X1.0 3 1.0 6.1 60 C3GC 3 G1.0 3 1.0 6.1 60 C4XC 4 X1.0 4 1.0 6.7 77 C4GC 4 G1.0 4 1.0 6.7 77 C5XC 5 X1.0 5 1.0 7.4 95 C5GC 5 G1.0 5 1.0 7.4 95 C7XC 7 X1.0 7 1.0 8.1 122 C7GC 7 G1.0 7 1.0 8.1 122 C9XC 9 X1.0 9 1.0 10.1 163 C9GC 9 G1.0 9 1.0 10.1 163 C10XC 10 X1.0 10 1.0 10.5 180 C10GC 10 G1.0 10 1.0 10.5 180 C12XC 12 X1.0 12 1.0 10.9 208 C12GC 12 G1.0 12 1.0 10.9 208 3 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable C14XC 14 X1.0 14 1.0 11.5 239 C14GC 14 G1.0 14 1.0 11.5 239 C16XC 16 X1.0 16 1.0 12.3 271 C16GC 16 G1.0 16 1.0 12.3 271 C18XC 18 X1.0 18 1.0 13.0 306 C18GC 18 G1.0 18 1.0 13.0 306 C20XC 20 X1.0 20 1.0 13.8 340 C20GC 20 G1.0 20 1.0 13.8 340 C2XD 2 X1.5 2 1.5 6.2 58 C3XD 3 X1.5 3 1.5 6.6 75 C3GD 3 G1.5 3 1.5 6.6 75 C4XD 4 X1.5 4 1.5 7.3 96 C4GD 4 G1.5 4 1.5 7.3 96 C5XD 5 X1.5 5 1.5 8.1 119 C5GD 5 G1.5 5 1.5 8.1 119 C7XD 7 X1.5 7 1.5 8.9 154 C7GD 7 G1.5 7 1.5 8.9 154 C9XD 9 X1.5 9 1.5 11.0 204 C9GD 9 G1.5 9 1.5 11.0 204 C10XD 10 X1.5 10 1.5 11.6 226 C10GD 10 G1.5 10 1.5 11.6 226 C12XD 12 X1.5 12 1.5 12.0 261 C12GD 12 G1.5 12 1.5 12.0 261 C14XD 14 X1.5 14 1.5 12.7 300 C14GD 14 G1.5 14 1.5 12.7 300 C16XD 16 X1.5 16 1.5 13.4 342 C16GD 16 G1.5 16 1.5 13.4 342 C18XD 18 X1.5 18 1.5 14.3 385 C18GD 18 G1.5 18 1.5 14.3 385 C20XD 20 X1.5 20 1.5 15.1 429 C20GD 20 G1.5 20 1.5 15.1 429 C2XC 2 X2.5 2 2.5 9.1 114 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) C3XE 3 X2.5 3 2.5 9.8 147 C3GE 3 G2.5 3 2.5 9.8 147 C4XE 4 X2.5 4 2.5 10.9 189 C4GE 4 G2.5 4 2.5 10.9 189 4 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable C5XE 5 X2.5 5 2.5 12.0 234 C5GE 5 G2.5 5 2.5 12.0 234 C7XE 7 X2.5 7 2.5 13.3 301 C7GE 7 G2.5 7 2.5 13.3 301 C9XE 9 X2.5 9 2.5 16.6 401 C9GE 9 G2.5 9 2.5 16.6 401 C10XE 10 X2.5 10 2.5 17.4 447 C10GE 10 G2.5 10 2.5 17.4 447 C12XE 12 X2.5 12 2.5 18.1 516 C12GE 12 G2.5 12 2.5 18.1 516 C1FXE 14 X2.5 14 2.5 19.1 594 C1FGE 14 G2.5 14 2.5 19.1 594 C1GXE 16 X2.5 16 2.5 20.3 677 C1GGE 16 G2.5 16 2.5 20.3 677 C18XE 18 X2.5 18 2.5 21.6 764 C18GE 18 G2.5 18 2.5 21.6 764 C20XE 20 X2.5 20 2.5 22.9 852 C20GE 20 G2.5 20 2.5 22.9 852 C2XF 2 X4 2 4 10.5 165 C3XF 3 X4 3 4 11.3 216 C3GF 3 G4 3 4 11.3 216 CFXF 4 X4 4 4 12.6 278 CFGF 4 G4 4 4 12.6 278 C5XF 5 X4 5 4 13.9 346 C5GF 5 G4 5 4 13.9 346 C7XF 7 X4 7 4 15.4 450 C7GF 7 G4 7 4 15.4 450 C9XF 9 X4 9 4 19.3 597 C9GF 9 G4 9 4 19.3 597 C10XF 10 X4 10 4 20.2 667 C10GF 10 G4 10 4 20.2 667 C12XF 12 X4 12 4 21.0 772 C12GF 12 G4 12 4 21.0 772 C2XG 2 X6 2 6 11.9 224 C3XG 3 X6 3 6 12.8 297 C3GG 3 G6 3 6 12.8 297 CFXG 4 X6 4 6 14.2 384 CFGG 4 G6 4 6 14.2 384 C5XG 5 X6 5 6 15.8 478 5 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable C5GG 5 G6 5 6 15.8 478 C7XG 7 X6 7 6 17.4 625 C7GG 7 G6 7 6 17.4 625 C3XE 9 X6 9 6 21.9 828 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) C9GG 9 G6 9 6 21.9 828 C2XH 2 X10 2 10 14.3 335 C3XH 3 X10 3 10 15.3 447 C3GH 3 G10 3 10 15.3 447 C4XH 4 X10 4 10 17.1 580 C4GH 4 G10 4 10 17.1 580 C5XH 5 X10 5 10 19.0 723 C5GH 5 G10 5 10 19.0 723 C7XH 7 X10 7 10 21.0 950 C7GH 7 G10 7 10 21.0 950 C9XH 9 X10 9 10 26.4 1256 C9GH 9 G10 9 10 26.4 1256 C2X1G 2 X16 2 16 18.2 547 C3X1G 3 X16 3 16 19.6 730 C3G1G 3 G16 3 16 19.6 730 C4X1G 4 X16 4 16 21.9 949 C4G1G 4 G16 4 16 21.9 949 C5X1G 5 X16 5 16 24.3 1186 C5G1G 5 G16 5 16 24.3 1186 C7X1G 7 X16 7 16 26.9 1559 C7G1G 7 G16 7 16 26.9 1559 C2XJ 2 X25 2 25 20.8 776 C3XJ 3 X25 3 25 22.3 1048 C3GJ 3 G25 3 25 22.3 1048 C4XJ 4 X25 4 25 24.9 1367 C4GJ 4 G25 4 25 24.9 1367 C5XJ 5 X25 5 25 27.7 1709 C5GJ 5 G25 5 25 27.7 1709 6 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable Sheath / Jacket Colour 1) 2) 3) 4) 5) Colour Grey (RAL 7001) Black Blue Orange Violet Colour Code G8U 010 006 003 007 Packaging *Belden can offer these cables with various packing options like coiled, plastic or wooden reels. This will be decided at the discretion of Belden based on the cable design and structure. Put-up Length Putup Length 1) 50 Meters 2) 100 Meters 3) 200 Meters* 4) 300 Meters* Putup Length Code 050M 100M 200M 300M *Applicable only for certain part codes, please check with Belden for more information. Stock Code Selection Procedure: C 5 G 1 . 5 Select the part code from Table A G 8 U Select the sheath / jacket color code 1 0 0 M Select the putup length code 7 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable C 5 G 1 . 5 G 8 U 1 0 0 M Cable Stock Code = C5G1.5 G8U100M 8 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.
C10GB-BC50 价格&库存
很抱歉,暂时无法提供与“C10GB-BC50”相匹配的价格&库存,您可以联系我们找货
C10GB-BC50
  • 1+27.252681+3.53690
  • 25+22.5509425+2.92670
  • 50+20.2871450+2.63290
  • 100+17.84920100+2.31650
库存:10
