C624106001M
C624106001M
    BELDEN
    C624106001M
C624106001M 数据手册
Part Number: CAT6+ UTP LSZH PATCH CORDS CAT6+ Patch Cord, UTP, LSZH Product Description CAT6+ Copper Patch Cord, UTP, LSZH Technical Specifications Product Overview Environmental Space: Indoor Rated (Not Riser or Plenum) Suitable Applications: Horizontal and building cabling. Support current and future Category 6 and 5e applications, such as: 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI, ATM Physical Characteristics (Overall) Conductor AWG Stranding Material Nominal Diameter No. of Pairs 23 Solid Copper 6.1 mm 4 Total Number of Pairs: 4 Conductor Size: 23 AWG Insulation Material Polyethylene Inner Jacket Material Material No inner Jacket Outer Jacket Material Material Nominal Diameter LSZH - Low Smoke Zero Halogen 6.1 mm Wiring Scheme: T568A/B-T568A/B Packaging: Individually packaged in a clear plastic bag. Connectors Materials Description Material Type Plug Polycarbonate RJ45 Boot PVC Snagless Front Connection Phosphor Bronze with 50u inch Gold over Nickel Plating Blades Construction and Dimensions Cabling Filler Cross Web Electrical Characteristics Dielectric Strength: 2.5 kV DC Current Rating: 1A Insulation Resistance: 5000 MOhm*km Max Contact Resistance: 20 mOhm Voltage Voltage Rating [V] 72 V DC Performance Footnote1: There is 1dB margin on NEXT and RL guaranteed compared to ISO/IEC 11801-1:2017 Performance Footnote2: The performance data below 4Mhz or above 500Mhz are for information only. Temperature Range Installation Temp Range: 0°C To +50°C Operating Temp Range: -20°C to +60°C Mechanical Characteristics Min Bend Radius (Overall Cable): 25 mm Plug /Jack Compatibility: RJ45 Termination Interface Termination RJ45 Connection Durabilities Mated Connection 750 Cycles Standards ISO/IEC Compliance: ISO/IEC 11801-1:2017 Data Category: Category 6+ Telecommunications Standards: ISO/IEC 11801-1:2017; EN 50173-1 Amd 1 Caregory 6; ANSI/TIA/EIA 568 C.2 Category 6 Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2013-01-25 Suitability Suitability - Indoor: Yes Part Number Related Parts: CAT6+ Modular Jacks, CAT6+ Patch Panels Variants Item # Color Length C624100001M Black 1m C624100002M Black 2m C624100004M Black 4m C624100005M Black 5m C624100008M Black 8m C624100010M Black 10 m C6241000D5M Black 0.5 m C6241001D5M Black 1.5 m C624106001M Blue 1m C624106002M Blue 2m C624106003M Blue 3m C624106004M Blue 4m C624106005M Blue 5m C624106008M Blue 8m C624106010M Blue 10 m C624106015M Blue 15 m C624106016M Blue 16 m C624106020M Blue 20 m C624106022M Blue 22 m C624106024M Blue 24 m C624106025M Blue 25 m C624106026M Blue 26 m C624106027M Blue 27 m C624106029M Blue 29 m C624106030M Blue 30 m C624106032M Blue 32 m C624106050M Blue 50 m C624106060M Blue 60 m C624106062M Blue 62 m C6241060D5M Blue 0.5 m C6241061D5M Blue 1.5 m C604106010 Blue C604106010 Blue C604106005 Blue C604106004 Blue C604106004 Blue C604106003 Blue C604106003 10 ft 4 ft Blue 3 ft C624108002M Gray 2m C624108001M Gray 1m C624108002M Gray 2m C624108003M Gray 3m C624108004M Gray 4m C624108005M Gray 5m C624108008M Gray 8m C624108010M Gray 10 m C624108012M Gray 12 m C624108015M Gray 15 m C624108020M Gray 20 m C624108025M Gray 25 m C624108030M Gray 30 m C624108040M Gray 40 m C624108050M Gray 50 m C624108060M Gray 60 m C6241080D5M Gray 0.5 m C6241081D5M Gray 1.5 m C6241082D5M Gray 2.5 m C6241087D5M Gray 7.5 m C604108005 Gray C604108005 Gray 5 ft C624108002M Gray C604108010 Gray C604108010 Gray C604108015 Gray C604108015 Gray 10 ft 15 ft C624105001M Green 1m C624105002M Green 2m C624105003M Green 3m C624105004M Green 4m C624105005M Green 5m C624105010M Green 10 m C624105015M Green 15 m C6241050D5M Green 0.5 m C6241051D5M Green 1.5 m C604105005 Green C604105005 Green C604105004 Green C604105004 Green C604105003 Green C604105003 Green 5 ft 4 ft 3 ft C624103001M Orange 1 m C624103002M Orange 2 m C624103003M Orange 3 m C624103005M Orange 5 m C624103010M Orange 10 m C624102001M Red 1m C624102002M Red 2m C624102003M Red 3m C624102004M Red 4m C624102005M Red 5m C624102010M Red 10 m C6241020D5M Red 0.5 m C6241021D5M Red 1.5 m C624107001M Violet 1m C624107002M Violet 2m C624107003M Violet 3m C624107005M Violet 5m C624107010M Violet 10 m C624107020M Violet 20 m C624109001M White 1m C624109002M White 2m C624109003M White 3m C624109005M White 5m C624109010M White 10 m C624109015M White 15 m C624109020M White 20 m C624109025M White 25 m C624109030M White 30 m C6241090D5M White 0.5 m C6241091D5M White 1.5 m C6241092D5M White 2.5 m C624104001M Yellow 1m C624104002M Yellow 2m C624104003M Yellow 3m C624104004M Yellow 4m C624104005M Yellow 5m C624104006M Yellow 6m C624104010M Yellow 10 m C624104015M Yellow 15 m C624104025M Yellow 25 m C624104050M Yellow 50 m C6241040D5M Yellow 0.5 m C6241041D5M Yellow 1.5 m © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
C624106001M 价格&库存
很抱歉,暂时无法提供与“C624106001M”相匹配的价格&库存,您可以联系我们找货
