10GD-BC50
10GD-BC50
    BELDEN
    BELDEN - 10GD-BC50 - SHLD FLEX CABLE, 10COND, 1.5MM2, 50M
10GD-BC50 数据手册
Technical Data Sheet – Unshielded (YY) PVC Control Cable MachFlex 350 YY VDE Registered Flexible PVC Control Cables Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • • DIN VDE 0295, IEC 60228, BS 6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 IEC 60227-5, EN 50525-2-51, VDE 0281-13 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS, REACH & CE Directives Construction & Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5 / IEC 60228 class 5) 2. Insulation Material & Colour PVC (polyvinyl chloride), DIN VDE 0293-1 (colour) A) All black colour with number coding = without protective earth conductor. OR B) Black colour with number coding and 1 green & yellow colour conductor = with protective earth conductor. 3. Jacket / Sheath Material PVC (polyvinyl chloride) 4. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 5. Voltage Rating (Uo/U) 300 / 500 V 6. Oil Resistant DIN EN 50290-2-22 (TM54) 1 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 7. Temperature Range 8. Bending Radius 9. Other Properties -30°C TO +70°C (Occasional movement) -40°C TO +80°C (Fixed installation) 10 x OD (Occasional movement) 4 x OD (Fixed installation) Good UV resistance, chemical resistance & flexibility TABLE A Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 2XA 2 X0.5 2 0.5 4.6 28 3XA 3 X0.5 3 0.5 4.9 35 3GA 3 G0.5 3 0.5 4.9 35 4XA 4 X0.5 4 0.5 5.3 44 4GA 4 G0.5 4 0.5 5.3 44 5XA 5 X0.5 5 0.5 5.9 53 5GA 5 G0.5 5 0.5 5.9 53 7XA 7 X0.5 7 0.5 6.4 68 7GA 7 G0.5 7 0.5 6.4 68 9XA 9 X0.5 9 0.5 7.9 90 9GA 9 G0.5 9 0.5 7.9 90 10XA 10 X0.5 10 0.5 8.3 100 10GA 10 G0.5 10 0.5 8.3 100 12XA 12 X0.5 12 0.5 8.6 114 12GA 12 G0.5 12 0.5 8.6 114 14XA 14 X0.5 14 0.5 9.1 131 14GA 14 G0.5 14 0.5 9.1 131 16XA 16 X0.5 16 0.5 9.6 148 16GA 16 G0.5 16 0.5 9.6 148 18XA 18 X0.5 18 0.5 10.2 167 18GA 18 G0.5 18 0.5 10.2 167 20XA 20 X0.5 20 0.5 10.8 186 20GA 20 G0.5 20 0.5 10.8 186 2XB 2 X0.75 2 0.75 5.0 36 3XB 3 X0.75 3 0.75 5.4 46 3GB 3 G0.75 3 0.75 5.4 46 4XB 4 X0.75 4 0.75 5.9 58 4GB 4 G0.75 4 0.75 5.9 58 2 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 5XB 5 X0.75 5 0.75 6.5 70 5GB 5 G0.75 5 0.75 6.5 70 7XB 7 X0.75 7 0.75 7.2 91 7GB 7 G0.75 7 0.75 7.2 91 9XB 9 X0.75 9 0.75 8.9 120 9GB 9 G0.75 9 0.75 8.9 120 10XB 10 X0.75 10 0.75 9.3 134 10GB 10 G0.75 10 0.75 9.3 134 12XB 12 X0.75 12 0.75 9.6 154 12GB 12 G0.75 12 0.75 9.6 154 14XB 14 X0.75 14 0.75 10.2 176 14GB 14 G0.75 14 0.75 10.2 176 16XB 16 X0.75 16 0.75 10.8 199 16GB 16 G0.75 16 0.75 10.8 199 18XB 18 X0.75 18 0.75 11.4 225 18GB 18 G0.75 18 0.75 11.4 225 20XB 20 X0.75 20 0.75 12.1 251 20GB 20 G0.75 20 0.75 12.1 251 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 2XC 2 X1.0 2 1.0 5.4 44 3XC 3 X1.0 3 1.0 5.8 57 3GC 3 G1.0 3 1.0 5.8 57 4XC 4 X1.0 4 1.0 6.4 72 4GC 4 G1.0 4 1.0 6.4 72 5XC 5 X1.0 5 1.0 7.1 89 5GC 5 G1.0 5 1.0 7.1 89 7XC 7 X1.0 7 1.0 7.8 115 7GC 7 G1.0 7 1.0 7.8 115 9XC 9 X1.0 9 1.0 9.6 151 9GC 9 G1.0 9 1.0 9.6 151 10XC 10 X1.0 10 1.0 10.1 169 10GC 10 G1.0 10 1.0 10.1 169 12XC 12 X1.0 12 1.0 10.5 195 12GC 12 G1.0 12 1.0 10.5 195 14XC 14 X1.0 14 1.0 11.0 224 14GC 14 G1.0 14 1.0 11.0 224 16XC 16 X1.0 16 1.0 11.7 255 16GC 16 G1.0 16 1.0 11.7 255 3 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 18XC 18 X1.0 18 1.0 12.4 287 18GC 18 G1.0 18 1.0 12.4 287 20XC 20 X1.0 20 1.0 13.2 319 20GC 20 G1.0 20 1.0 13.2 319 2XD 2 X1.5 2 1.5 6.0 55 3XD 3 X1.5 3 1.5 6.4 71 3GD 3 G1.5 3 1.5 6.4 71 4XD 4 X1.5 4 1.5 7.0 91 4GD 4 G1.5 4 1.5 7.0 91 5XD 5 X1.5 5 1.5 7.8 112 5GD 5 G1.5 5 1.5 7.8 112 7XD 7 X1.5 7 1.5 8.5 145 7GD 7 G1.5 7 1.5 8.5 145 9XD 9 X1.5 9 1.5 10.6 191 9GD 9 G1.5 9 1.5 10.6 191 10XD 10 X1.5 10 1.5 11.1 213 10GD 10 G1.5 10 1.5 11.1 213 12XD 12 X1.5 12 1.5 11.5 247 12GD 12 G1.5 12 1.5 11.5 247 14XD 14 X1.5 14 1.5 12.2 284 14GD 14 G1.5 14 1.5 12.2 284 16XD 16 X1.5 16 1.5 12.9 323 16GD 16 G1.5 16 1.5 12.9 323 18XD 18 X1.5 18 1.5 13.7 364 18GD 18 G1.5 18 1.5 13.7 364 20XD 20 X1.5 20 1.5 14.5 405 20GD 20 G1.5 20 1.5 14.5 405 2XC 2 X2.5 2 2.5 7.7 91 Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 3XE 3 X2.5 3 2.5 8.3 118 3GE 3 G2.5 3 2.5 8.3 118 4XE 4 X2.5 4 2.5 9.2 152 4GE 4 G2.5 4 2.5 9.2 152 5XE 5 X2.5 5 2.5 10.1 188 5GE 5 G2.5 5 2.5 10.1 188 7XE 7 X2.5 7 2.5 11.2 244 7GE 7 G2.5 7 2.5 11.2 244 9XE 9 X2.5 9 2.5 13.9 322 4 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 9GE 9 G2.5 9 2.5 13.9 322 10XE 10 X2.5 10 2.5 14.6 360 10GE 10 G2.5 10 2.5 14.6 360 12XE 12 X2.5 12 2.5 15.2 417 12GE 12 G2.5 12 2.5 15.2 417 1FXE 14 X2.5 14 2.5 16.0 481 1FGE 14 G2.5 14 2.5 16.0 481 1GXE 16 X2.5 16 2.5 17.0 548 1GGE 16 G2.5 16 2.5 17.0 548 18XE 18 X2.5 18 2.5 18.1 618 18GE 18 G2.5 18 2.5 18.1 618 20XE 20 X2.5 20 2.5 19.2 688 20GE 20 G2.5 20 2.5 19.2 688 2XF 2 X4 2 4 9.1 137 3XF 3 X4 3 4 9.8 182 3GF 3 G4 3 4 9.8 182 FXF 4 X4 4 4 10.9 235 FGF 4 G4 4 4 10.9 235 5XF 5 X4 5 4 12.0 292 5GF 5 G4 5 4 12.0 292 7XF 7 X4 7 4 13.3 383 7GF 7 G4 7 4 13.3 383 9XF 9 X4 9 4 16.6 504 9GF 9 G4 9 4 16.6 504 10XF 10 X4 10 4 17.5 564 10GF 10 G4 10 4 17.5 564 12XF 12 X4 12 4 18.1 655 12GF 12 G4 12 4 18.1 655 2XG 2 X6 2 6 11.0 202 3XG 3 X6 3 6 11.8 269 3GG 3 G6 3 6 11.8 269 FXG 4 X6 4 6 13.1 349 FGG 4 G6 4 6 13.1 349 5XG 5 X6 5 6 14.5 434 5GG 5 G6 5 6 14.5 434 7XG 7 X6 7 6 16.0 570 7GG 7 G6 7 6 16.0 570 3XE 9 X6 9 6 20.1 751 5 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable Part Code Cable Description No. Of Cores Nom. Conductor Size (mm²) Nom. Cable Diameter (mm) Nom. Cable Weight (kg/km) 9GG 9 G6 9 6 20.1 751 2XH 2 X10 2 10 13.8 320 3XH 3 X10 3 10 14.8 427 3GH 3 G10 3 10 14.8 427 4XH 4 X10 4 10 16.5 555 4GH 4 G10 4 10 16.5 555 5XH 5 X10 5 10 18.3 692 5GH 5 G10 5 10 18.3 692 7XH 7 X10 7 10 20.3 910 7GH 7 G10 7 10 20.3 910 9XH 9 X10 9 10 25.5 1198 9GH 9 G10 9 10 25.5 1198 2X1G 2 X16 2 16 16.8 497 3X1G 3 X16 3 16 18.1 668 3G1G 3 G16 3 16 18.1 668 4X1G 4 X16 4 16 20.2 870 4G1G 4 G16 4 16 20.2 870 5X1G 5 X16 5 16 22.4 1086 5G1G 5 G16 5 16 22.4 1086 7X1G 7 X16 7 16 24.8 1433 7G1G 7 G16 7 16 24.8 1433 2XJ 2 X25 2 25 20.8 770 3XJ 3 X25 3 25 22.3 1038 3GJ 3 G25 3 25 22.3 1038 4XJ 4 X25 4 25 24.9 1354 4GJ 4 G25 4 25 24.9 1354 5XJ 5 X25 5 25 27.7 1693 5GJ 5 G25 5 25 27.7 1693 7XJ 7 X25 7 25 30.6 2229 7GJ 7 G25 7 25 30.6 2229 Sheath / Jacket Colour Colour 1) Grey (RAL 7001) 2) Black Colour Code G8U 010 6 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 3) Blue 4) Orange 5) Violet 006 003 007 Packaging *Belden can offer these cables with various packing options like coiled, plastic or wooden reels. This will be decided at the discretion of Belden based on the cable design and structure. Put-up Length Putup Length 1) 050 Meters* 2) 100 Meters* 3) 200 Meters* 4) 300 Meters Putup Length Code 50M 100M 200M 300M *Applicable only for certain part codes, please check with Belden for more information. Stock Code Selection Procedure: 5 G 2 . 5 G Select the part code from Table A 5 G 2 . 8 U 2 Select the sheath / jacket color code 5 G 0 0 M Select the putup length code 8 U 2 0 0 M Cable Stock Code = 5G2.5 G8U200M 7 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Technical Data Sheet – Unshielded (YY) PVC Control Cable 8 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.
10GD-BC50 价格&库存
很抱歉,暂时无法提供与“10GD-BC50”相匹配的价格&库存,您可以联系我们找货
