1172A B59500
1172A B59500
    BELDEN
    BELDEN - 1172A B59500 - SHLD MULTICOND CABLE, 4COND, 26AWG, 500F
1172A B59500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1172A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 26 AWG stranded (30x40) high-conductivity BC conductors, polyethylene insulation, tinned copper "French Braid" shield (95% coverage), BC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 26 30x40 Dia. (in.) SBC - Soft Bare Copper .021 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene .045 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) French Braid TC - Tinned Copper 95 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 28 Stranded BC - Bare Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Cabling Color Code Chart: Number Color 1 Blue 2 White 3 Blue w/White Stripe 4 White w/Blue Stripe Overall Nominal Diameter: 0.190 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 25 lbs/1000 ft. Max. Recommended Pulling Tension: 37 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1172A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 40 Nom. Inductance: Inductance (µH/ft) .21 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 39.2 Nom. Cap. Between Cond. in a Quad Config.: Capacitance (pF/ft) 57.4 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 36 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.8 Max. Operating Voltage - UL: Voltage 100 V RMS Max. Recommended Current: Current 1.9 Amps per conductor @ 25°C Other Electrical Characteristic 1: 2/c 23 AWG equivalent DCR when connected to a 3-pin XLR Notes (Overall) Notes: Quad connection scheme: The two blue wires (or wires directly opposite one another) are connected together to form one conductor, and similarly the two white wires (or remaining wires) are connected together to form the second conductor. Put Ups and Colors: Item # Putup Ship Weight Color 1172A B59N1000 1,000 FT 28.000 LB BLACK, MATTE Notes Item Desc 1172A B591000 1,000 FT 26.000 LB BLACK, MATTE 1172A B59500 500 FT 13.500 LB BLACK, MATTE 4 #26 PE FBRD PVC 1172A G7V1000 1,000 FT 26.000 LB RED, MATTE 4 #26 PE FBRD PVC 1172A G7W1000 1,000 FT 26.000 LB GREEN, MATTE 4 #26 PE FBRD PVC 1172A G7X1000 1,000 FT 26.000 LB BLUE, MATTE 4 #26 PE FBRD PVC 1172A G7Y1000 1,000 FT 26.000 LB WHITE, MATTE 4 #26 PE FBRD PVC 1172A G8C1000 1,000 FT 26.000 LB PURPLE, MATTE 4 #26 PE FBRD PVC 1172A G8M1000 1,000 FT 26.000 LB YELLOW, MATTE 4 #26 PE FBRD PVC 1172A U901000 1,000 FT 26.000 LB GRAY, MATTE 4 #26 PE FBRD PVC 4 #26 PE FBRD PVC C 4 #26 PE FBRD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 10-04-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1172A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1172A B59500 价格&库存
很抱歉,暂时无法提供与“1172A B59500”相匹配的价格&库存,您可以联系我们找货
