Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
1192A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable
For more Information
please call
1-800-Belden1
Description:
24 AWG stranded (42x40) high-conductivity bare copper conductors, polyethylene insulation, tinned
copper braid shield (95% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
4
24
42x40
Dia. (mm)
SBC - Soft Bare Copper 0.6096
Insulation
Insulation Material:
Insulation Material Wall Thickness (mm) Dia. (mm)
PE - Polyethylene
0.4064
1.4224
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid TC - Tinned Copper
95
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (mm)
PVC - Polyvinyl Chloride 1.143
Overall Cabling
Overall Cabling Color Code Chart:
Number Color
1
Blue
2
White
3
Blue w/White Stripe
4
White w/Blue Stripe
Overall Nominal Diameter:
6.223 mm
Mechanical Characteristics (Overall)
Operating Temperature Range:
-30°C To +75°C
Non-UL Temperature Rating:
75°C
Bulk Cable Weight:
49.111 Kg/Km
Max. Recommended Pulling Tension:
93.412 N
Min. Bend Radius (Install)/Minor Axis:
62.230 mm
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
Page 1 of 3
05-10-2011
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
40
Nom. Inductance:
Inductance (µH/m)
0.68901
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/m)
128.615
Nom. Cap. Between Cond. in a Quad Config.:
Capacitance (pF/m)
188.329
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/km)
87.2746
Nominal Outer Shield DC Resistance:
DCR @ 20°C (Ohm/km)
23.2951
Max. Operating Voltage - UL:
Voltage
100 V RMS
Max. Operating Voltage - Other:
Voltage Description
18.0 kV Nom. breakdown voltage between conductors
16.9 kV Nom. breakdown voltage conductors to shield
Max. Recommended Current:
Current
2.9 Amps per conductor @ 25°C
Other Electrical Characteristic 1:
2/c 21 AWG equivalent DCR when connected to a 3-pin XLR
Notes (Overall)
Notes: Quad connection scheme: The two blue wires (or wires directly opposite one another) are connected together to form one
conductor, and similarly the two white wires (or remaining wires) are connected together to form the second conductor.
Related Documents:
No related documents are available for this product
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Page 2 of 3
Item Desc
05-10-2011
1192A B59100
30 MT
1.860 KG
BLACK, MATTE
1192A B591000
305 MT
16.783 KG
BLACK, MATTE
C
4 #24 PE SH PVC BLK MTT
1192A B59500
152 MT
7.484 KG
BLACK, MATTE
C
1192A G7V1000
305 MT
16.783 KG
RED, MATTE
C
4 #24 PE SH PVC RED MTT
1192A G7W1000
305 MT
16.783 KG
GREEN, MATTE
C
4 #24 PE SH PVC GRN MTT
1192A G7X1000
305 MT
16.783 KG
BLUE, MATTE
C
4 #24 PE SH PVC BLU MTT
1192A G7X500
152 MT
7.484 KG
BLUE, MATTE
1192A G8M1000
305 MT
16.783 KG
YELLOW, MATTE
1192A U901000
305 MT
16.783 KG
GRAY, MATTE
4 #24 PE SH PVC YEL MTT
C
4 #24 PE SH PVC GRY MTT
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 05-14-2007
© 2011 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications
described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not
ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the
compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and
the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide
for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not
to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
Page 3 of 3
05-10-2011
很抱歉,暂时无法提供与“1192A B59100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+39.81417100+5.15733
