1227A1 008U1000
1227A1 008U1000
    BELDEN
    CAT3 2PR U/UTP CMR BOX
1227A1 008U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1227A1 Multi-Conductor - Category 3 Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT3 (16MHz), 2-Pair, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 24 AWG solid bare copper conductors, Polyolefin insulation, PVC jacket Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 24 Solid BC - Bare Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material PP - Polypropylene Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.173 Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 75°C Bulk Cable Weight: 13 lbs/1000 ft. Max. Recommended Pulling Tension: 15 lbs. Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 1.700 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR, UL444 EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: 802.3 10BaseT, 100BaseT4 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1227A1 Multi-Conductor - Category 3 Nonbonded-Pair Cable EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63 Category 3 Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1243A2 Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Nominal Delay: Delay (ns/ft) 1.5 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 28.0 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 5 Electrical Characteristics-Premise (Overall) Premise Cable Elelctricals: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. SRL (dB) Fitted Imp. (Ohms) 1 2.56 41.0 No Spec 12.0 100 ± 15% 4 5.58 32.0 No Spec 12.0 100 ± 15% 8 8.50 27.0 No Spec 12.0 100 ± 15% 10 9.71 26.0 No Spec 12.0 100 ± 15% 16 13.10 23.0 No Spec 9.96 100 ± 15% Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Third party verified to TIA/EIA-568-B.2, Category 3 Put Ups and Colors: Item # Putup Ship Weight Color 1227A1 Q5HU1000 1,000 FT 14.000 LB WHITE, NEUTRAL Notes CAT3 2PR U/UTP CMR BOX 1227A1 008U1000 1,000 FT 14.000 LB GRAY CAT3 2PR U/UTP CMR BOX Page 2 of 3 Item Desc 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1227A1 Multi-Conductor - Category 3 Nonbonded-Pair Cable Revision Number: 2 Revision Date: 08-14-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1227A1 008U1000
物料型号:STM32F103RB 器件简介:STM32F103RB是ST公司的一款基于ARM Cortex-M3内核的32位MCU,主频为72MHz,具有多种内存配置和丰富的外设。
引脚分配:该芯片有85个引脚,包括GPIO、ADC、USART、SPI、I2C等。
参数特性:工作电压2.0V-3.6V,工作频率72MHz,内置64KB-512KB的闪存和20KB-64KB的RAM。
功能详解:具有多种通信接口,支持多种外设,提供多种定时器和ADC通道。
应用信息:广泛应用于工业控制、消费电子、医疗设备等领域。
封装信息:LQFP48封装。
1227A1 008U1000 价格&库存
很抱歉,暂时无法提供与“1227A1 008U1000”相匹配的价格&库存,您可以联系我们找货
