1592A 0021000
1592A 0021000
    BELDEN
    CAT5E PATCH U/UTP CM REEL
1592A 0021000 数据手册
1592A Paired - Category 5e Unbonded-Pair Cable For more information please call 1-800-Belden1 See Put-ups and Colors Color Code Chart : No. 8 for DataTwist Cables (Modified Western Electric).pdf Description: 24 AWG stranded (7x32) bare copper conductors, non-plenum, Polyolefin insulation, twisted pairs, RJ-45 compatible, see color code chart (below), PVC jacket (red, orange, yellow, green, blue, purple, light gray, white or black). SUITABLE APPLICATIONS: Suitable Applications Premise Patch Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422 PHYSICAL CHARACTERISTICS: CONDUCTOR: Number of Pairs 4 Total Number of Conductors 8 AWG 24 Stranding 7x32 Conductor Material BC - Bare Copper INSULATION: Insulation Material PO - Polyolefin Pair Color Code Chart : Number 1 2 Color White/Blue Stripe & Blue White/Orange Stripe & Orange Number 3 4 OUTER SHIELD: Outer Shield Material Unshielded OUTER JACKET: Outer Jacket Material PVC - Polyvinyl Chloride OVERALL NOMINAL DIAMETER: Overall Nominal Diameter .213 in. Page 1 of 4 Color White/Green Stripe & Green White/Brown Stripe & Brown 1592A Paired - Category 5e Unbonded-Pair Cable MECHANICAL CHARACTERISTICS: Operating Temperature Range -20°C To +75°C Bulk Cable Weight 21 lbs/1000 ft. Max. Recommended Pulling Tension 25 lbs. Min. Bend Radius (Install) 0.8 in. APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE: APPLICABLE STANDARDS: NEC/(UL) Specification CM, UL444 CEC/C(UL) Specification CM IEC Specification 11801 Category 5 Patch EU CE Mark (Y/N) Yes EU RoHS Compliant (Y/N) Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 TIA/EIA Specification 568-B.2 Cateory 5e Patch Other Specification NEMA WC-63.1 Category 5e Patch, ICEA 661 Category 5 Patch, UL verified to Category 5e FLAME TEST: UL Flame Test UL1685 UL Loading CSA Flame Test FT1 PLENUM/NON-PLENUM: Plenum (Y/N) N ELECTRICAL CHARACTERISTICS: Nom. Mutual Capacitance @ 1 KHz 15 pF/ft Maximum Capacitance Unbalance (pF/100 m) 330 pF/100 m Nominal Velocity of Propagation 69 % Maximum Delay (ns/100 m) 510 @ 100MHz ns/100 m Typical Delay Skew 12 ns/ft Maximum Delay Skew (ns/100m) 45 ns/100 m Maximum Conductor DC Resistance @ 20 Deg. C 9.38 Ohms/100 m Maximum DCR Unbalance @ 20 Deg. C 3% Max. Operating Voltage - UL 300 V RMS ELECTRICAL CHARACTERISTICS - PREMISE: Premise Cable Electricals Table 1 : Page 2 of 4 1592A Paired - Category 5e Unbonded-Pair Cable Frequency (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT Min. ACR (dB) Min. PSACR (dB) (dB) Min. Return Loss (dB) 1 4 8 10 16 20 25 31.25 62.5 100 155 200 2.5 4.9 6.9 7.8 9.9 11.1 12.5 14.1 20.4 26.4 33.7 38.9 65.3 56.3 51.8 50.3 47.3 45.8 44.3 42.9 38.4 35.3 32.5 30.8 62.3 53.3 48.8 47.3 44.3 42.8 41.3 39.9 35.4 32.3 29.5 27.8 20.0 23.0 24.5 25.0 25.0 25.0 24.3 23.6 21.5 20.1 15.8 15.0 62.8 51.4 44.9 42.5 37.4 34.7 21.8 28.8 18.0 8.9 59.8 48.4 41.9 39.5 34.4 31.7 28.8 25.8 15.0 5.9 Min. Structural Return Loss (dB) 23.0 23.0 24.5 25.0 25.0 25.0 24.3 23.6 21.5 20.1 Premise Cable Electricals Table 2 : Frequency (MHz) 1 4 8 10 16 20 25 31.25 62.5 100 155 200 Input (Unfitted) Impedance (Ohms) 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 25 100 ± 25 Fitted Impedance (Ohms) 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 100 ± 15 Min. ELFEXT (dB) Min. PSELFEXT (dB) 63.8 51.7 45.7 43.8 39.7 37.7 35.8 33.9 27.8 23.8 19.9 17.7 60.8 48.7 42.7 40.8 36.7 34.7 32.8 30.9 24.8 20.8 16.9 14.7 NOTES: Notes Jacket sequentially marked at 2 ft. intervals. Third party verified to TIA/EIA-568B.2, Category 5e. PUT-UPS AND COLORS: Item Description Put-Up (ft.) 1592A 0021000 4 PR #24 PP FR PVC 1000 Ship Weight (lbs.) 23 Jacket Color RED 1592A 002U1000 4 PR #24 PP FR PVC U1000 22 RED 1592A 0031000 4 PR #24 PP FR PVC 1000 23 ORANGE 1592A 003U1000 4 PR #24 PP FR PVC U1000 22 ORANGE Page 3 of 4 Notes C C 1592A Paired - Category 5e Unbonded-Pair Cable 1592A 0041000 4 PR #24 PP FR PVC 1000 23 YELLOW 1592A 004U1000 4 PR #24 PP FR PVC U1000 22 YELLOW 1592A 0051000 4 PR #24 PP FR PVC 1000 23 GREEN, DARK 1592A 005U1000 4 PR #24 PP FR PVC U1000 22 GREEN, DARK 1592A 0061000 4 PR #24 PP FR PVC 1000 23 BLUE, LIGHT 1592A 006U1000 4 PR #24 PP FR PVC U1000 22 BLUE, LIGHT 1592A 0071000 4 PR #24 PP FR PVC 1000 23 VIOLET 1592A 007U1000 4 PR #24 PP FR PVC U1000 22 VIOLET 1592A 0091000 4 PR #24 PP FR PVC 1000 23 WHITE 1592A 009U1000 4 PR #24 PP FR PVC U1000 22 WHITE 1592A 0101000 4 PR #24 PP FR PVC 1000 23 BLACK 1592A 010U1000 4 PR #24 PP FR PVC U1000 22 BLACK 1592A F2V1000 4 PR #24 PP FR PVC 1000 23 GRAY, DEC 1592A F2VU1000 4 PR #24 PP FR PVC U1000 22 GRAY, DEC C C C C C C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 06-09-2005 © 2005 Belden Wire & Cable Company All Rights Reserved. Although Belden Electronics Division ("Belden") makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden CDT Electronics Division believes this product to be in compliance with the following environmental regulations: California Proposition 65 Consent Judgment For Wire & Cable Mfgs.(San Francisco Superior Court Nos. 312962 And 320342); EU RoHS (Directive 2002/95/EC, 27-Jan-2003); EU ELV (Directive 2000/53/EC, 18-Sept-2000); EU WEEE (Directive 2002/96/EC, 27-Jan-2003); And EU BFR (Directive 2003/11/EC, 6-Feb-2003). The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information and belief at the date of its publication. The information provided in the Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden CDT Electronics Division declares this product to be in complaince with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 4 of 4
1592A 0021000
物料型号: - 型号:Belden 1592A Paired - Category 5e Unbonded-Pair Cable
器件简介: - 描述:24 AWG(美国线规)的无绞线裸铜导体,非增塑性聚烯烃(Polyolefin)绝缘,RJ-45兼容,PVC外护套(颜色包括红色、橙色、黄色、绿色、蓝色、紫色、浅灰色、白色或黑色)。
引脚分配: - 导体数量:4对,总共8根导体。 - 导体材料:裸铜(BC - Bare Copper)。 - 绝缘材料:聚烯烃(PO - Polyolefin)。 - 对色码:白色/蓝条纹和蓝色,白色/绿条纹和绿色,白色/橙条纹和橙色,白色/棕条纹和棕色。
参数特性: - 工作温度范围:-20°C至+75°C。 - 电缆重量:21磅/1000英尺。 - 最大推荐拉力:25磅。 - 安装时最小弯曲半径:0.8英寸。 - 符合TIA/EIA-568B.2 Cat 5e标准。 - 电性能参数包括:电容、传播速度、延迟、直流电阻等。
功能详解: - 适用应用:适用于局域网布线、千兆以太网、100BaseTX、155M ATM、622M ATM、NTSC/PAL视频、AES/EBU、数字视频、RS-422等。
应用信息: - 适用于局域网布线,提供高速数据传输。
封装信息: - 包装方式:1000英尺卷装。 - 包装重量:约23磅(标准卷装),22磅(U1000卷装)。 - 颜色选项:红色、橙色、黄色、绿色(深)、蓝色(浅)、紫罗兰色、白色、黑色、灰色(淡)。
其他信息: - 符合欧盟CE标志、ROHS指令。 - 产品符合低烟无卤(LSZH)要求,但未明确标注为增塑性聚氯乙烯(PVC)。
1592A 0021000 价格&库存
很抱歉,暂时无法提供与“1592A 0021000”相匹配的价格&库存,您可以联系我们找货
1592A 0021000
  • 1000+5.929991000+0.76941
