Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1673A Coax - 50 Ohm Microwave Cable
For more Information
please call
1-800-Belden1
General Description:
RG-402/U type, 19 AWG solid .036" silver-plated copper-covered steel conductor, TFE Teflon® insulation,
copper-tin composite shield (100% coverage), unjacketed.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
19
Solid
Dia. (in.)
SPCCS - Silver Plated Copper Covered Steel .036
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Teflon®
Dia. (in.)
TFE - Tetrafluoroethylene .116
Outer Shield
Outer Shield Material:
Layer # Type Outer Shield Material Coverage (%)
1
Tape Copper Foil
100
2
Braid Tin-Filled Composite
100
Overall Cable
Overall Nominal Diameter:
0.138 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-70°C To +200°C
UL Temperature Rating:
105°C
Non-UL Temperature Rating:
200°C
Bulk Cable Weight:
26 lbs/1000 ft.
Max. Recommended Pulling Tension:
70 lbs.
Min. Bend/Installation:
0.250 in.
Min. Flexing Radius:
0.750 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
AWM Specification:
UL Style 10245
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
402/U
Flame Test
Other Flame Test:
Horizontal Wire
Suitability
Suitability - Indoor:
Yes
Page 1 of 3
01-05-2017
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
0.070
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
29.5
Nominal Velocity of Propagation:
VP (%)
69.5
Nominal Delay:
Delay (ns/ft)
1.46
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
20.5
Nominal Outer Shield DC Resistance:
4.5
Maximum VSWR:
Description
Freq. (MHz) Max. VSWR
Ramp Function, End Points 500
20000
1.1
1.3
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
500
8.0
1000
12.0
2000
18.1
3000
22.9
5000
31.0
7000
37.8
10000
46.6
15000
59.1
18000
65.8
20000
70.0
Max. Attenuation:
500
9.5
1000
14.5
3000
26.5
5000
36.0
10000
54.0
20000
84.0
Nom. Power Rating:
Freq. (MHz) Rating (W)
500
600
1000
401
2000
268
3000
211
5000
157
7000
129
10000
105
15000
83
18000
74
20000
70
Max. Operating Voltage - UL:
Page 2 of 3
01-05-2017
Voltage
30 V RMS
Max. Operating Voltage - Non-UL:
Voltage
1900 V RMS
Misc. Information (Overall)
Notes (Overall)
Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1673A TIN100
100 FT
3.100 LB
TIN - COLOR
C
#19 TFE BRD TINNED COAX
1673A TIN250
250 FT
7.250 LB
TIN - COLOR
CV
1673A TIN50
50 FT
1.800 LB
TIN - COLOR
1673A TIN500
500 FT
14.000 LB
TIN - COLOR
Notes:
C = CRATE REEL PUT-UP.
V = 250' PUT-UP EXACT LENGTH MAXIMUM OF 3 PIECESMINIMUM LENGTH 50'500' PUT-UP EXACT LENGTH MAXIMUM OF 5 PIECESMINIMUM LENGTH 50'
Revision Number: 4
Revision Date: 01-15-2014
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1673A TIN500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+95.76407500+12.01363
