1701A B02U1000
1701A B02U1000
    BELDEN
    CAT5E+ 4PRB U/UTP CMP BOX
1701A B02U1000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1701A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e+ (350MHz), 4-Bonded-Pairs, U/UTP-Unshielded, Plenum-CMP, Premise Horizontal Cable, 24 AWG Solid Bare Copper Conductors, FEP insulation, Ripcord, Flamarrest® PVC jacket. Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material FEP - Fluorinated Ethylene Propylene Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (mm) 4.953 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 4.953 mm Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: +5°C To +50°C Page 1 of 5 01-10-2014 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1701A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 32.740 Kg/Km Max. Recommended Pulling Tension: 177.928 N Min. Bend Radius/Minor Axis: 12.700 mm Min. Bend/Installation: 50.800 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Other Specification: NEMA WC-63.1 Category 5e, UL Verified to Category 5e Applicable Patents: Country Patent US 5606151 Flame Test UL Flame Test: NFPA 262 C(UL) Flame Test: FT6 CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Suitability - Aerial: No Suitability - Burial: No Sunlight Resistance: No - Indoor Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 1700A Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/m) 49.215 Maximum Capacitance Unbalance (pF/100 m): 66 Nominal Velocity of Propagation: VP (%) 72 Page 2 of 5 01-10-2014 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1701A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable Maximum Delay: Delay (ns/100 m) 510 Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. PSNEXT (dB) Min. PSACR (dB) Min RL (dB) 1 2.000 69.3 67.3 20.000 4 4.000 60.3 56.3 23.000 8 5.700 55.8 50.1 24.500 10 6.400 54.3 47.9 25.000 16 8.100 51.2 43.1 25.000 20 9.100 49.8 40.7 25.000 25 10.200 48.3 38.2 25.000 31.25 11.400 46.9 35.5 25.000 62.5 16.400 42.4 26.0 25.000 100 21.000 39.3 18.3 25.000 155 26.600 36.4 9.8 19.000 200 30.400 34.8 4.4 19.000 250 34.400 32.3 >0 18.000 300 38.000 28.1 18.000 350 41.400 27.1 17.000 400 44.500 26.3 17.000 450 47.600 25.5 17.000 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. PSACRF (dB) 1 100 ± 12 105 ± 10 65.8 4 100 ± 12 100 ± 10 53.8 8 100 ± 12 100 ± 10 47.7 10 100 ± 12 100 ± 10 45.8 16 100 ± 12 100 ± 10 41.7 20 100 ± 12 100 ± 10 39.8 25 100 ± 15 100 ± 10 37.8 31.25 100 ± 15 100 ± 10 35.9 62.5 100 ± 15 100 ± 10 29.9 100 100 ± 15 100 ± 10 25.8 155 100 ± 18 100 ± 10 22.0 200 100 ± 20 100 ± 10 19.8 250 100 ± 20 100 ± 10 17.8 300 100 ± 20 100 ± 10 14.3 350 100 ± 22 100 ± 10 12.9 400 100 ± 22 100 ± 10 11.8 450 100 ± 22 100 ± 10 10.7 Premise Cable Electrical Table 4: Frequency (MHz) Min. TCL (dB) Min. ELTCTL (dB) Page 3 of 5 01-10-2014 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1701A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable 1.000 40.000 35.000 4.000 40.000 23.000 8.000 40.000 16.900 10.000 40.000 15.000 16.000 38.000 10.900 20.000 37.000 9.000 25.000 36.000 7.000 31.250 35.100 62.500 32.000 100.000 30.000 155.000 28.100 200.000 27.000 250.000 26.000 Notes (Overall) Notes: Belden IBDN. Jacket sequentially marked at 2 ft. intervals. Third party verified to ANSI/TIA-568-C.2, Category 5e. Values above 350 MHz are for Engineering Information Only. Put Ups and Colors: Item # Putup Ship Weight Color 1701A B02U1000 305 MT 10.433 KG PURPLE Notes Item Desc 1701A B021000 305 MT 10.886 KG PURPLE 1701A D15U1000 305 MT 10.433 KG BLUE 1701A D151000 305 MT 10.886 KG BLUE C CAT5E+ 4PRB U/UTP CMP REEL 1701A D153000 914 MT 31.298 KG BLUE C CAT5E+ 4PRB U/UTP CMP REEL 1701A 002U1000 305 MT 10.433 KG RED 1701A 0021000 305 MT 10.886 KG RED 1701A 003U1000 305 MT 10.433 KG ORANGE 1701A 0031000 305 MT 10.886 KG ORANGE 1701A 004U1000 305 MT 10.433 KG YELLOW 1701A 0041000 305 MT 10.886 KG YELLOW 1701A 005U1000 305 MT 10.433 KG GREEN, DARK 1701A 0051000 305 MT 10.886 KG GREEN, DARK 1701A 008U1000 305 MT 10.433 KG GRAY 1701A 0081000 305 MT 10.886 KG GRAY 1701A 009U1000 305 MT 10.433 KG WHITE 1701A 0091000 305 MT 10.886 KG WHITE C CAT5E+ 4PRB U/UTP CMP REEL 1701A 010U1000 305 MT 10.433 KG BLACK C CAT5E+ 4PRB U/UTP CMP BOX 1701A 0101000 305 MT 10.886 KG BLACK 1701A 877U1000 305 MT 10.433 KG NATURAL 1701A 8771000 305 MT 10.886 KG NATURAL C CAT5E+ 4PRB U/UTP CMP REEL 1701A 8773000 914 MT 31.298 KG NATURAL C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX CAT5E+ 4PRB U/UTP CMP BOX C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX C CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX CAT5E+ 4PRB U/UTP CMP REEL CAT5E+ 4PRB U/UTP CMP BOX Notes: C = CRATE REEL PUT-UP. Revision Number: 10 Revision Date: 01-07-2014 © 2014 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not Page 4 of 5 01-10-2014 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1701A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 5 of 5 01-10-2014
1701A B02U1000 价格&库存
很抱歉,暂时无法提供与“1701A B02U1000”相匹配的价格&库存,您可以联系我们找货
1701A B02U1000
  • 1000+5.815561000+0.75332
