1855ECH.00500
1855ECH.00500
    BELDEN
    BELDEN - 1855ECH.00500 - Coaxial Cable, RG59U Mini, 22 AWG, 75 ohm, 1640 ft, 500 m
1855ECH.00500 数据手册
Part Number: 1855ECH COAX MINI RG59/U LSZH-C PRECISION VIDEO Product Description COAX [0.6/2.8] MINI RG59/U LSZH-C CLASSICS PRO Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Cca Suitable Applications: Low loss HDTV/SDI Digital coax used in critical analog and digital video circuits and high quality applications such as live broadcast in network studios and pre- or post-production facilities; Cable is suitable for indoor and outdoor use Physical Characteristics (Overall) Conductor AWG Stranding 22 Solid Material Nominal Diameter Diameter +/- Tolerance No. of Coax BC - Bare Copper 0.65 mm Conductor Count: 0.02 mm 1 1 Insulation Type Material Nominal Diameter Diameter +/- Tolerance Dielectric FPE - Foamed Polyethylene 2.9 mm 0.15 mm Outer Shield Material Type Layer Material Coverage [%] Min. Overlap Nominal Diameter Coverage +/- Tolerance Tape 1 Aluminum/Polyester/Aluminum Braid 2 TC - Tinned Copper 2 mm 90 % Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance LSZH / FRNC 4.6 mm 0.1 mm OuterJacket1, Table Note: According to EN 50290-2-20 Construction and Dimensions Min Elongation at Breakof Jacket: 125 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max. Shield DCR 55 Ohm/km 17 Ohm/km Capacitance Nom. Capacitance Capacitance Tolerance 53 pF/m 2 pF/m Impedance Nominal Characteristic Impedance Nominal Characteristic Tolerance 3.45 mm 5% 75 Ohm 3 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 1.7 dB/100m 3.6 MHz 2.5 dB/100m 5 MHz 2.8 dB/100m 6 MHz 3 dB/100m 7 MHz 3.2 dB/100m 10 MHz 3.7 dB/100m 12 MHz 4 dB/100m 25 MHz 5.4 dB/100m 67.5 MHz 8.3 dB/100m 71.5 MHz 8.6 dB/100m 88.5 MHz 9.5 dB/100m 100 MHz 10 dB/100m 135 MHz 11.5 dB/100m 143 MHz 11.9 dB/100m 180 MHz 13.2 dB/100m 270 MHz 16.1 dB/100m 360 MHz 18.6 dB/100m 540 MHz 22.8 dB/100m 720 MHz 26.4 dB/100m 750 MHz 26.9 dB/100m 1000 MHz 31.3 dB/100m 1500 MHz 38.7 dB/100m 2000 MHz 45 dB/100m 2250 MHz 48 dB/100m 2500 MHz 50.8 dB/100m 3000 MHz 56.1 dB/100m 4000 MHz 65.7 dB/100m 4500 MHz 70.2 dB/100m Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] Velocity of Propagation Tolerance 400 ns/ft 84 % 2% High Freq Frequency [MHz] Min. RL (Return Loss) [dB] 5 - 1600 MHz 23 dB 1600 - 4500 MHz 21 dB Screening Frequency [MHz] Min. Screening Attenuation After Flexing 30 - 1000 MHz 85 dB 1000 - 2000 MHz 85 dB 2000 - 3000 MHz 85 dB 3000 - 4500 MHz 80 dB Screening Class: B Transfer Impedance Frequency [MHz] Transfer Impedance 5-30 MHz Max. 15 mOhm/m Temperature Range Installation Temp Range: -5°C To +50°C Storage Temp Range: -30°C To +70°C Operating Temp Range: -30°C To +70°C Mechanical Characteristics Max Recommended Pulling Tension: 160 N Min Bend Radius (W/o Pulling Strength): 45 mm Standards CPR Euroclass: Cca-s1,d1,a1 CENELEC Compliance: EN 50117-1 and EN 50290-2-20 RG Type: Mini 59/U Type Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2005-01-01 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 and IEC 60332-3-24 Other Flammability: CEI 20-22-3 Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Item # 1855ECH.00500 Color Length Green 500 m 1855ECH.001000 Green 1,000 m History Update and Revision: Revision Number: 0.158 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1855ECH.00500 价格&库存
很抱歉,暂时无法提供与“1855ECH.00500”相匹配的价格&库存,您可以联系我们找货
