19217 01050
19217 01050
    BELDEN
    CBL 4COND 14AWG EPDM
19217 01050 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 19217 Portable Cordage - UL/CSA Types: SVT, SO For more Information please call 1-800-Belden1 General Description: 4-conductor SO oil-resistant rubber jacket, 600V, 90ºC, paper tape separator, smooth jacket, UL/CSA listed, color code: black, white, green, red. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 14 41x30 BC - Bare Copper Total Number of Conductors: 4 Type of Cordage: SO Insulation Insulation Material: Insulation Material Wall Thickness (in.) EPDM - Ethylene Propylene Diene Monomer Rubber 0.048 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) Rubber .087 Overall Cable Overall Cabling Fillers: Jute Overall Cabling Color Code Chart: Color Black White Green Red Overall Cabling Separator Material: Paper Tape Overall Nominal Diameter: 0.603 in. Mechanical Characteristics (Overall) Bulk Cable Weight: 202 lbs/1000 ft. Min. Bend Radius/Minor Axis: 6.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: SO CSA Specification: SO EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 19217 Portable Cordage - UL/CSA Types: SVT, SO CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test CSA Flame Test: FT2 Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 600 V RMS Max. Recommended Current: Current 15 Amps per conductor @ 25°C 10 Amps per conductor @ 25°C (over 50 ft.) Dielectric Withstand Voltage: 3000 V AC Applied for 1 Min. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 19217 010200 200 FT 43.600 LB BLACK C 4 #14 EPDM CPE TYPE SO 19217 01050 50 FT 11.800 LB BLACK C 4 #14 EPDM CPE TYPE SO Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 10-16-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
19217 01050 价格&库存
很抱歉,暂时无法提供与“19217 01050”相匹配的价格&库存,您可以联系我们找货
